How to Use UniFab Video Upscaler AI (Formerly DVDFab Enlarger AI) 2025
Summary: DVDFab Enlarger AI, part of the DVDFab series product lineup, has become a preferred choice for millions of users. In October 2023, DVDFab Enlarger AI underwent a significant upgrade and was rebranded as UniFab Video Upscaler AI.
Upscale low-res videos into 720p/1080p/4k content
Enhance video clarity to a more realistic and vivid visual effect
Support video editing to meet your personalized demands
Get 50x faster speed with GPU acceleration
šAs of October 2023, DVDFab Enlarger AI underwent an upgrade and was reborn as UniFab Video Upscaler AI. The technology and enhancement mechanism employed by UniFab considerably outperforms its previous version in DVDFab.
* As a loyal patron of DVDFab Enlarger AI, you are eligible for complimentary access to the upgraded UniFab Video Upscaler AI.
What's New with UniFab Video Upscaler AI?
- Enhanced Quality: New AI models intelligently detects and corrects issues like compression artifacts, detail loss, noise, halo effects from over-sharpening, and jagged edges or blurriness, significantly enhancing overall video quality.
- Faster Performance: Efficiency is up by 40-50% with our advanced AI models, speeding up the enhancement process.
- Expanded AI Features: Access HDR Upconverter AI, Video Background Remover AI, Vocal Remover AI, and Smoother AI in the new standalone AI client.
- Unified Experience: UniFab's all-in-one client simplifies video enhancement with user-friendly navigation and added features like trimming, cropping and audio quality improvement.
UniFab Video Upscaler AI: AI-Powered Video Upscaling Solution
UniFab Video Upscaler AI (previous name: DVDFab Enlarger AI) is a complete 4k upscaling solution to provide you with the best results. Its deep learning-based Super-Resolution technology can enhance your 480p/720p video to 1080p full HD and from 1080p resolution to 4K/8K quality.
Exclusive features
Unlike traditional methods that just add pixels, AI-driven upscaling generates new pixels that match the original, improving detail and clarity. UniFab Video Upscaler AI employs advanced deep learning algorithms to train its models, delivering a lifelike and immersive visual experience. The AI’s algorithm performs effectively across all types, including black-and-white films, low-resolution TV shows, homemade videos, and animations.
Here is a host of features of the video upscale online solution, UniFab Video Upscaler AI:
- Super Resolution: Upscale Videos by Up to 300%
Effortlessly upgrade your videos from 480p/720p to 1080p/4K/8K. Using neural networks, the AI refines pixel data, making enlarged images up to 300% sharper and clearer. It also removes film grain, artifacts, and distortions, preserving sharpness and detail in every frame.
- Noise Reduction: Clearer, Cleaner Visuals
Videos often suffer from grain, artifacts, and compression issues due to age or low quality. UniFab AI’s sophisticated denoising technology tackles these problems by smoothing out imperfections while preserving essential details. This results in a refined, high-definition look.
- Presents true colors with great details
Advanced color correction algorithms accurately restore original hues and refine image details. By balancing saturation, brightness, and contrast, it ensures realistic visuals without noticeable color shifts. This feature effectively preserves details in clothing textures, facial expressions, and background elements, even in dynamic scenes, while maintaining high clarity.
System Requirements
Ensure your Windows system is equipped with the below-given minimum requirements to install and enjoy this video upscaler software free trial smoothly.
Ryzen 7 or greater (4GHz and above)
How to Upscale Video Using UniFab Video Upscaler AI
After learning about the UniFab Video Upscaler AI, if you are thinking about how to upscale video to 1080p, don't forget to check out the below quick steps:
Choose 'Upscaler' Module
Click 'All Features', and seclect 'Upscaler' from 'Video AI' section.
Load the video to upscale your file
Click the '+' button to add your video, or drag and drop the file directly.
Customize Output Settings and Start Processing
Customize the resolution, codec, frame rate, and other output parameters as needed. Finally, tap the Start button to upscale your video conversion.
Frequently Asked Questions
It provides a free trial for 3 videos without function limits. During the free trial, you can experience all features for free. No limits on any quality, video length, and output options.
YES. UniFab (DVDFab) Video Enlarger AI is absolutely safe to use, but the prerequisite is to install enlarger ai from the official site.
Final Verdict
UniFab Video Upscaler AI is the new generation of DVDFab Enlarger AI. It is a perfect tool to effortlessly upscale video online. It enlarges your videos beautifully by up to 300%, giving you accurate colors and a real-life image without compromising on the video quality.
Moreover, it uses advanced technologies to bring you the best user experience. Read this guide about how to sharpen video quality with AI tools. And if you are looking for a comprehensive video enhancer, UniFab Video Enhancer is your savior.
