Introduction
Have you heard of AI video restoration services? Old videos feature considerably low resolution out of various factors such as dust-busting and de-flickering, making them distorted-looking. Without proper video restoration software, many valuable pieces of video content could be lost forever.
The importance of video restoration cannot be overstated, especially when preserving historical and cultural artifacts. Luckily, this post has collected and analyzed the top 12 best video restorers and AI video enhancer to meet your needs.
video restoration
Top 12 Video Restoration Software You Shall Try
Among the given list, let's look at the top AI-based video restoration software that stands out from the rest. The automatic restoring video process and unexpected output video quality are the captivating features of the best video restoration software. Feel free to digitally remaster old videos with easy clicks.
1. UniFab Video Upscaler AI (Best Recommended)
UniFab Video Upscaler AI, previously named DVDFab Video Enlarger AI is a newly released AI video restoration software. With such a tool like UniFab Video Upscaler AI, transforming low-resolution homemade videos or vintage footage from 480p up to 4K/8K/16K becomes a straightforward task.
video restoring: unifab
This is a professional AI-based video restoration tool designed to enhance video quality from all aspects for personal and business uses.
Features:
  • Restore your low-res videos into 720p/1080p/4k/8k/16K content
  • Enhance video clarity to a more realistic and vivid visual effect
  • Support video editing to meet your personalized demand
  • Get 50x faster speed with GPU acceleration
By the way, if you are seeking for a more comprehensive video enhancing solution, UniFab All-in-One will be your better choice. Besides the features including in Upscaler, All-in-One offers more video restoration tools, which can improve the quality of old videos more effectively.
 Main Functions
  • • HDR Upconverter AI: Upgrade videos from SDR to HDR10/Dobly Vision.
  • • Video Upscaler AI: Enhance videos resolution to 720P/1080P/4k/8k/16K.
  • • Denoise AI: Remove video noise caused by low conditions or other issues.
  • • Deinterlace AI: Converts interlaced scanning video into progressive one.
  • • Smoother AI: Boosts frame rate to 120 fps for high-quality videos.
  • • Stabilizer AI: Remove the shaking to achieve smooth and stable output.
  • • Audio Upmix AI: Enhances audio tracks to EAC3 5.1/DTS 7.1.
  • The UniFab client also provides two Free AI tools:
  • • Video Background Remover AI: eliminates unwanted background and objects.
  • • Vocal Remover AI: Supports removing vocal from your song.
How to restore video quality with this AI video restorer software free and easily? Follow the steps below:
Launch UniFab
Choose the 'Upscaler' module and import video file
Click 'All Features', and seclect 'Upscaler' from 'Video AI' section.
unifab video upscaler-step
Click the Add Video button to select the video you want to restore in the local file.
Customize the restoring video file and Start Processing
Customize the resolution, codec, frame rate, and other output parameters as needed. Then, click the start button to restore your video. UniFab will complete the video restoring task at lightning speed.
Pros Cons
✅Offers comprehensive solution for video and audio restoring ❌No support for Linux
✅Offer a 30-day free trial
✅Very simple and easy UI design, friendly to users
2. Adobe Premiere Pro
Adobe Premiere Pro is a popular video restoration software among professionals within the film, marketing, and advertising sectors. This advanced video editing software not only brings forth innovative features to optimize your video output but also retains the classic nonlinear digital video editing technique much loved by seasoned video editors.
Furthermore, Premiere Pro deviates from conventional video restoration tools by providing a user-friendly experience for novices in the field, thanks to its robust built-in features. One of the distinctive aspects of Adobe Premiere Pro is its ability to handle multiple video restoring concurrently.
video restoration
Pros Cons
✅Offers powerful video restoration features ❌ Expensive for some users
✅Wide range of tools to restore and enhance video quality,
including color correction, noise removal, stabilization, and more
❌ Requires a high-end system to run smoothly
✅Supports a variety of file formats and resolutions ❌ For unprofessional users, it is not the top choice
3. Final Cut Pro X
Final Cut Pro is a proficient video restoration software designed especially for Mac users. In contrast to Video Enhancer AI, implementing FCP requires a foundational understanding of video restoring. Its robust functionalities allow for effortless incorporation of numerous effects and refining of the videos, all while minimizing the potential for restoring errors.
Beyond its standard capabilities, Final Cut Pro also extends support for crafting Virtual Reality videos, ushering in a completely different sensory experience when compared to traditional videos. Another notable feature is its suite of integrated tools which simplify the process of eliminating background noise and fine-tuning audio levels, hence making these tasks considerably easier than in the past.
video restoration Final Cut Pro
Pros Cons
✅A professional video restorer designed for Mac users. ❌ Expensive for some users
✅Offers advanced video restoration features like noise reduction, color grading, and stabilization.
❌ Unavailable for win users
✅Supports a wide range of file formats and resolutions.
4. DaVinci Resolve
Different from the above-mentioned video restoration software, the Blackmagic Design DaVinci Revival Pro is a Linux-based software with automatic restoration and interactive workflow for repairing film originated video files in SD, HD, and data up to 4K.
video restoration DaVinci Resolve
If you use the Manual mode, you are capable of working on individual frames in the region of interest. But given that video restoration work can involve a large amount of film, you can use the automatic modes to handle all the frames with the help of many video restoration tools, including Dirt and Dust, Grain and Noise Reduction, Aperture or Sharpening Correction, Splice Repair, Vertical Scratch.
Pros Cons
✅A professional restorer with high ratings ❌ Too complicated to learn for beginners
✅Offers color correction, noise reduction, and stabilization tools.
❌ Demands high hardware
✅2D and 3D animated titles and text
Core features of this video restoration software:
  • Grain & Noise Reduction
  • Dirt/Dust/Scratch Removal
  • Vertical Scratch Repair
  • Interactive Stabilization
  • Interactive Workflow
  • Grain Sampling & Addition
5. Neat Video
Neat Video is a skillfully developed video restoration software tailored to improve the quality of digital video designs by minimizing apparent noise, stutter, and flaws. It has been created with contemporary digital video cameras, DSLRs, and smartphones in mind, and also works flawlessly with older TV-Tuners and digitized film or VHS.
* Neat Video incorporates seamlessly with multiple video restoration softwares, including Adobe Premiere Pro and Final Cut Pro.
Pros Cons
✅Specilized in video noise reduction ❌ Limited video restoration features outside of noise reduction
✅Integrated into comprehensive video editing modules
❌ Lack of restoring tools for audio
✅User friendly interface to operate ❌ It acts more like a plug in instead of an individual video restorer
6. Topaz Video Enhance AI
Formerly recognized as Topaz Video Enhance AI, Topaz Video AI is an advanced AI video restoration software solution that leverages the power of machine learning technology. This application is adept at not only enhancing the resolution of low-quality videos but also accentuating their sharpness and detailing.
video restoration Topaz Video Enhance AI
Pros Cons
✅High rating AI-powered video restorationtool to restore your old videos ❌ Takes a long time to process video restoring
✅Easy and friendly to use for beginners
❌ Usually crashes with the new version released
✅Supports various file formats and resolutions. ❌ Lack of flexible price plan, which discourage users with limited needs
7. Mercalli V5
Whenever there's a need for video restoration and picture enhancement, both experts and hobbyists turn to ProDAD Mercalli. This tool is celebrated for delivering exceptional outcomes while maintaining simplicity in its usage.
Pros Cons
✅Friendly for video restoration on stabilization and shaky footage elimination ❌ Limited features compared with other restorer
✅Different restoration modes are supported
❌ Outdated UI design and support
✅Compatible with some editor functions
8. Filmora
Wondershare Inc.'s Filmora is a user-friendly AI video restoration software primarily constructed for novices rather than for professionals. The capabilities of the Filmora Video Editor allow users to effortlessly rejuvenate vintage footage by incorporating breathtaking effects, executing color modifications, and eliminating noise.
* However, opting to utilize the complimentary version of this software will result in the addition of a Filmora watermark on your video.
video restoration Filmora
Pros Cons
✅An editor with a video restoring function ❌ Not a professional video restorer in fact
✅Affordable price for most users
❌ The output quality is relatively low
✅Has a variety of filters and effects to restore your videos
9. iMovie
Apple iMovie comes equipped with superior video restoration instruments for streamlining media, enhancing video color quality, controlling speed, incorporating green-screen effects, adding voice-over, and enriching the soundtrack of your digital films.
Although it may not always lead in embracing new formats, it is compatible with 4K and HEVC. Regrettably, the novel features of iMovie, including Storyboards and Magic Movies, are currently exclusive to the mobile version, at the time of penning this.
Pros Cons
✅Safe and verified by Apple ❌ No Windows version to restore videos
✅Store your iMovie library on external hard drive
❌ The quality for video restoring is limited
✅Share your restored videos with others
10. AVCLabs Video Enhancer AI
AVCLabs Video Enhancer AI stands as a globally recognized software for AI video restoration, setting itself apart by relying on advanced artificial intelligence, not just typical editing techniques. This potent technology harnesses an abundant array of training sets within its processing power.
video restoration AVCLabs
💡Related reviews: Pros and Cons Review: Is AVCLabs Video Enhancer Worth It?
Pros Cons
✅Restore your video from 480p to 4K ❌ Expensive and high hardware requirement
✅Get your video upscaled onto a larger screen
❌ Only 3 videos can be restored under the trial period
✅You can trim your video frame by frame ❌ The output quality of restored videos during trial period is limited
11. DIAMANT film restoration
DIAMANT film restoration is a good video restoration solution for automatic, semi-automatic, and interactive film restoration, cleaning enhancement, and repair.
Automotive restoration software to restore films
This professional video restoration tool has the capability of handling various kinds of film defects because it consists of software modules to deal with video restoration issues. This video restoration solution supports real-time viewing and batch rendering and generating restoration reports automatically.
Pros Cons
✅Available on Win and Mac ❌ Quite complicated to use
✅ Comprehensively supported video codecs
❌ Updates slowly
12. Nulightstudios
This video restoration software, Nulightstudios, offers a range of tools to assist in the digital restoration of old or damaged footage. It can be used as an auto video enhancer and a manual.
Video repairing software to improve video quality
As an automotive restoration software video, it can be used to fix the following video defects to improve video quality: Dust, Noise, Dirt, Flicker, Sparkle, and Grain. Besides, when used as a manual video restoration tool, it can deal with complicated damage requiring full-frame digital reconstruction, such as Splice bumps, Hairs, Glue, Warp, Torn frames, Sharpness, Scratches, Flicker, Chroma aberration, and Stability.
Pros Cons
✅Specilized in film restoring ❌ Expensive to use
✅With good support and staff
❌ It takes much longer time than other software
✅Deal with complicated damage requiring full-frame digital reconstruction
1. What is video restoration, and why it is important?
Video restoration refers to the process of repairing or enhancing the quality of damaged, deteriorated, or outdated video footage. It involves several techniques that aim to improve the overall visual and audio experience of the video. Video restoration is essential because it allows us to preserve historical moments, cultural artifacts, and personal memories that would otherwise be lost forever.
2. What are the common video quality issues that require to be restored or fixed?
Some common video quality issues include color fading, flickering, shaky footage, scratches, dirt, and other imperfections. These issues can be fixed using various video restoration techniques, such as color grading, stabilization, scratch removal, and noise reduction. It is better to use specialized tools and software like UniFab Video Upscaler AI to handle with expertise in video restoration.
In conclusion, we have discussed the best 12 video restoration software in total to help you fix video and film defects, thus improving video quality. Among all listed video restoring programs, we highly recommend you the UniFab Video Upscaler AI in that they can restore video automatically and intelligently, producing desirable results than expected.
