What is Deinterlacing?
Interlaced videos were initially designed for old CRT TVs, where alternate lines were displayed in each frame. However, when viewed on modern progressive scan devices, interlaced video can produce visual artifacts like "jagged lines" or "interlace combing," especially in fast-motion scenes. This is because each frame consists of two fields captured at different times, which may not align properly.
deinterlace video
Understanding what is deinterlacing is essential for ensuring the video displays correctly on progressive scan devices. Deinterlace video technology eliminates these visual distortions by combing or processing the two fields, resulting in a more seamless video experience. By deinterlacing videos, you can remove artifacts and edit videos to improve the visual quality of the final output.
How to Deinterlace Video [Windows & Mac]
It may be daunting to find a good AI video enhancer to deinterlace videos since many self-proclaimed AI-powered tools do not live up to their claims. So we've selected some genuine AI-powered solutions to deinterlace a video clip.
1.UniFab Deinterlace AI
UniFab Deinterlace AI is an advanced AI-powered video enhancement software that converts interlaced video signals into progressive scan format. It accurately eliminates motion artifacts, removes edge blurring, and preserves scene details and textures, significantly improving video quality.
Key Features
  • One-Click to transform interlaced video with AI.
  • Remove motion artifacts to make the video smoother and clearer.
  • Eliminate edge blur to rejuvenate and sharpen video margins.
  • Embedded with video edition function to customize the output.
  • Achieve 50x Faster with GPU Acceleration.
deinterlace video: unifab deinterlace ai
Use AI technology to deinterlace videos, transform interlaced footage, remove motion artifacts, and remove edge blur.
Install UniFab and Launch It
Install UniFab on your device and open the interface
Import Your Interlaced Video
Choose the 'Deinterlacer' module. Click the Add Video button to select the video you want to deinterlace.
Customize the restoring video file
Before deinterlacing the video, you can also customize the video quality, codec, frame rate, resolution, format, etc.
Step 4
Start to finish the video conversion process
After customization, you can click 'Start' immediately.
Deinterlacing video with UniFab
According to our test, UniFab Deinterlace AI performs impressively on deinterlacing video. We make a compare between the before and after effects. Have a look:
performance of deinterlacing video
Effect
  • Sharper Detail: Details are more precise, particularly noticeable in the cheetah's fur and spots.
  • Smoother Image: Motion artifacts or jagged edges are removed, leading to a smoother and more realistic representation of the subject.
  • Improved Clarity: Reduces the blur caused by fast-moving objects, making the cheetah’s features look more distinct, even when in motion.
By the way, if you’re looking for a comprehensive video enhancement solution for your video, we recommend you upgrade to the UniFab All-In-One. It allows you to remove the video noise, upscale video to 720P/1080P/4K/8K, transform SDR to HDR, and support ai frame interpolation, etc. And these products share the same installation package.
Learn more details about UniFab, check this review: Comprehensive UniFab Review for Video & Audio Enthusiasts
2.Topaz Video Enhance AI
Topaz Video Enhance AI Utilizes the most up-to-date deep learning techniques to improve video quality and detail by using temporal knowledge. Compared to conventional deinterlacing, Topaz uses AI model to deinterlace video and greatly reduces visual artifacts.
In addition to deinterlace video, Topaz acts very well on enhancing video quality and upscaling from SD to HD, HD to 4k or 8k, while preserving crisp and natural video data.
Price
  • $299
Supported OS
  • Win & Mac
              Features Video Enhancement; Deinterlacing; Denoising, etc.
Deinterlacing video with Topaz
Effect:
  • Removal of Interlacing Artifacts: Eliminates the horizontal lines, leading to a cleaner image.
  • Sharper Details: Enhance sharpness and clarity, especially in fine details like skin texture, hair, and facial features.
Learn more details about Topaz, check this review: [Review] How to Upscale Videos Using Topaz Video Enhance AI
3.Notch Builder
Notch Builder is a highly versatile and powerful tool often used for creating interactive and video content. However, Notch Builder is not primarily designed for deinterlacing videos; this is usually handled by video editing software prior to importing to Notch. But it works sometime, you can have a try.
deinterlace video
Price £99/base/lifetime | £189/pro/per month.
Supported OS
Windows
Features Workflow for 3D and Animation and effects that are procedural and audio-reactive
How to Deinterlace Video [Online]
1.iSIZE
iSize brings a new dimension to deinterlacing by utilizing cutting-edge AI algorithms. By leveraging advanced machine learning techniques, iSize can analyze and understand the intricate details of interlaced videos, enabling it to predict missing information and recreate a progressive video with remarkable accuracy.
deinterlace video
Price
Varies. You can only get a video with higher specifications rather than higher-quality after an online trial.
Supported OS
Online Web
Features Bitrate Saving - Bitrate reductions of up to 40% are possible with iSIZE precoding and open-source or proprietary encoders.
2.GDFLab Video Upscaler
The GDFLab Video Upscaler is easy to use, making the task of deinterlacing videos user-friendly, irrespective of your technical proficiency. This tool can help produce the best quality videos that stand out for their clarity, sharpness, and overall viewing appeal.
deinterlace video with ai
Price Not specified. You may, however, take an online trial at this site. It will give you an email with a connection that you can use to go to another place for an online trial.
Supported OS Online Web
Features Upscale videos by increasing both the resolution and quality to 4x the size and up to 4K UHD (2160P)
AI Deinterlacing vs. Traditional Methods
Deinterlacing has always been crucial in video editing, as interlaced videos look outdated and lack the desired visual quality. Traditional deinterlacing techniques have been employed for years, and while they have achieved decent results, they often fall short in terms of fine-detail preservation and overall quality. What's more, it hard to learn for beginners or for those who is not so proficient at software.
However, with advancements in artificial intelligence (AI) and machine learning, a new era of deinterlacing has dawned. This is the reason why our editor team decided to recommend top 5 ai solutions to deinterlace video instead of the traditional method.
FAQs about Deinterlacing
1. Is AI-powered deinterlacing accessible to users without technical expertise?
Yes, AI-powered deinterlacing software has made the process much more accessible to individuals without extensive technical knowledge. For example, UniFab Deinterlace AI comes with intuitive interfaces, allowing users to easily deinterlace their videos with just a few clicks.
2. Will deinterlacing affect the aspect ratio or resolution of my videos?
Deinterlacing, when done correctly, should not affect the aspect ratio or resolution of your videos. The primary goal is to maintain the original quality while improving the visual experience.
3. Can AI-based deinterlacing be applied to all types of videos?
Yes, AI-based deinterlacing can be applied to various types of videos, including movies, TV shows, sports events, and even personal recordings. The technology is versatile and adaptable, allowing for effective deinterlacing regardless of the video content or source.
Deinterlacing your videos using AI has revolutionized the way we enhance and optimize video content. This guide has provided a comprehensive overview of the concept of deinterlacing, the benefits it offers, and the various methods and techniques involved.
By choosing the right AI-powered deinterlacing software and following the step-by-step guide outlined in this article, you can easily enhance the quality of your videos by removing interlacing artifacts and achieving smoother, more professional-looking visuals.
