DVD, featured by its customized characteristics as well as a sense of ceremony, has gained a lot of popularity in today’s market. Looking for a reliable DVD creator software? In this review, we delve into Wondershare DVD Creator and explore its features and performance. Additionally, we’ll introduce you the best alternatives available in the market. Whether you need to burn videos, create custom menu templates, or add subtitles, this article will help you make an informed decision.
wondershare dvd creator review
Wondershare DVD Creator Review
  • Operating system: Windows 10/8/7/Vista/XP, Mac X 10.10 or later
  • User Rating: 2.4 out of 5 (Source: Trustpilot)
Wondershare DVD Creator enables users to burn a wide range of media formats to disc in order to store vital memories or for other purposes. It is a versatile tool for burning videos onto DVDs/Blu-ray Discs/BD Folders/ISO files. It offers a vast collection of over 100 static and dynamic DVD templates with various themes, allowing you to personalize your creation with custom background images, music, title thumbnails, and more.
Main Features of Wondershare DVD Creator
Support all popular formats
It is able to burn videos in 150 formats to DVD/Blu-ray discs, ISO image files or folders. It also supports all popular disc types: DVD-9 and DVD-5; DVD-R/RW, DVD+R/RW, DVD+R DL, DVD-R DL, DVD-RAM; BD-R, BD-RE, BD-25, BD-50, BD-100.
Edit DVD with a built-in video editor
There are a variety of options for users to edit their video to make it more appalling. You can trim the unwanted parts or crop the video to an appropriate size to better fit the screen and remove the blank edge. Adjust brightness, contrast, saturation parameters and use special effects.
Burn music to CD
If you pose high demands to the quality of music, Wondershare DVD Creator may be a good assistant. With a simple and direct process, you can burn music to a CD which can be ripper by CD ripper function. Besides, it could also burn MP3 and all other formats to CD.
Customized DVD menu
Wondershare DVD Creator offers more than 100 DVD templates in different themes, background images or music, title, thumbnail and more such as holiday template, travel templates, birthday templates, sports templates and memory templates.
Pros and Cons of Wondershare DVD Creator
PROS
 Compatible with both Windows and Mac.
 Preserve the original quality when transferring videos onto DVDs.
 It has a practical built-in video editor.
 More formats and popular disc kinds are supported.
CONS
 The free trial version only provides limited functions.
 Blu-ray Discs and BD folders are only available in the Windows version.
 It may occasionally experience freezing or crashing.
 For beginners, it is very complicated to use.
Using Guidance of Wondershare DVD Creator
Step1
First, download and open Wondershare DVD Creator. Drag and drop videos or photos into the application to start your project.
wondershare dvd creator review :Using Guidance
Step2
After importing, set your customized DVD menu templates according to your requirements. You can customize text, background, and layout as desired. If needed, use the editing tools to modify your videos.
How to use Wondershare DVD Creator: best dvd authoring software
Step3
After everything is configured, utilize the preview feature to see how your DVD will seem. Finally, click on the “Burn” button.
Best Wondershare Alternative: DVDFab DVD Creator
  • Operating system: Windows 11/10/8.1/8/7 and Mac 10.10 - 14
  • User Rating: 4.5 out of 5 (Source: Trustpilot)
If you are looking for the best wondershare dvd creator alternative, then DVDFab DVD Creator is there for you. As an all-inclusive and powerful tool, DVDFab Blu-ray Creator provides comprehensive services to users.
Best Wondershare Alternative: DVDFab Blu-ray Creator
DVDFab DVD Creator
DVDFab DVD Creator enables you to create a DVD disc, ISO image, or folder from any video format, as well as create your own DVD menu using stylish templates and customizable options.
Win Download
100% safe&clean
Mac Download
100% safe&clean
 Powerful Features
  • Combine multiple video files into a single disc, supporting 200+ video formats such as MP4, MKV, TS, WMV, MOV, WMA, FLV, 3GP, M4V, and more.
  • Utilize advanced GPU hardware acceleration for faster burning speed & high-quality output.
  • Choose from various output formats including DVD-5, DVD-9, DVD+R/RW, DVD-R DL, DVD-R/RW, DVD+R DL.
  • Integrated menu creator that allows you to select a menu template and customize its background design, text font, size, audio track, subtitles, and more.
  • Enjoy the convenience of previewing the video during the burning process.
  • Automatically synchronizes all meta data from the source videos.
✖️Cons
  • It does not support the Linux operating system.
  • Blu-ray maker is also available but is not free.
Using Guidance of DVDFab DVD Creator
Step 1: Launch this DVD maker and load the source.
Double-click DVDFab 13 and opt for the Creator module when it runs. Click the creator mode switcher to choose DVD Creator. Drag & drop or ‘+Add’ the source video(s) onto the main UI.
Using Guidance of DVDFab Blu-ray Creator
Step 2: Customize your DVD with built-in templates
Click Advanced Settings to choose output size and quality, and the Set Menu icon (Menu Setting) to customize DVD menu from the given templates.
How to Create DVD with wondershare dvd creator alternative
Step 3: start to burn DVD easily
After selecting output directory from the Save to option, click the Start button to create DVD from videos. You can see the detailed progress info during the burning process.
wondershare dvd creator alterrnative
Another Wondershare Alternative: Leawo DVD Creator
  • Operating system: Windows 7/8/8.1/10/11, Mac
Leawo DVD Creator is another top-notch program for creating DVDs from 180+ different video and photo formats with 40+ lovely DVD menu templates. It offers a full range of features and tools for editing films, adding subtitles, and creating personalized DVD menus.
 Main Features
  • Leawo DVD Creator supports 180+ video formats including AVI, MKV, MP4, etc.
  • It is capable of achieving 6X Faster Speed while promising no quality loss.
  • This alternative provides 40+ preset disc menu templates for users to choose.
  • Create unique videos using the built-in editors, including crop, trim, adjust effect, add 3D effect and remove noise.
✖️Cons
  • There is no way to add subtitles in DVDs.
  • Its DVD menu template variety is limited compared to other software.
  • Some files cannot be converted by Leawo DVD Creator.
Using Guidance of Leawo DVD Creator
Step 1: Select DVD Creator module and add the source file
Open Leawo DVD Creator and navigate to Burn module. Click on the “Add Video” button to import the video files you want to burn to DVD.
wondershare dvd creator alternative: Leawo DVD Creator
Step 2: Set output parameters and customize you DVD
You can select disc type between DVD-9, DVD-5 and the video aspect ratio between 4:3 and 16:9. Then you can choose a DVD menu template, add text, and modify other properties.
How to use wondershare dvd creator alternative: leawo
Step 3: Start the Burning process
Click on the green Burn button on the right top of the main interface to start the process. Select your DVD drive and specify the burning speed.
How to use wondershare alternative: Leawo DVD Creator
Is Wondershare DVD Creator free?
No. Though Wondershare DVD Creator offers a free trial, the features are limited compared with its full version.
Can Wondershare burn Blu-ray Disc?
Wondershare DVD Creator is the software on which you can burn files to a Blu-ray disc on any Windows version. Mac version doesn’t support this function.
What's the best DVD authoring software?
To be the best DVD authoring software, a program is supposed to be powerful enough to meet users’ increasing demands. DVDFab DVD Creator is compatible with both Windows and Mac. You can use this DVD burner to convert videos to DVD with your favorite menu template and customize it free based on your preference.
Overall, Wondershare DVD Creator is a powerful solution for users to easily create and customize DVDs from videos. However, for those looking for a more comprehensive alternative tool, DVDFab DVD Creator offers enhancements such as faster processing times, more advanced editing options, and broader compatibility.
