How to Burn Video to DVD with Lossless Quality on Windows & Mac
Summary: Preserving your favorite videos in physical format, like a DVD disc, is a good way for long-term storage or sharing with your friends. This article provides detailed guidance on how to burn videos to DVDs with a personalized DVD menu using the best free DVD creator programs.
- • Burn videos into DVD discs/ISO files/folders
- • User-friendly and easy-to-use
In the age of digital streaming and cloud storage, physical media such as DVDs still hold a unique charm. They offer us tangible control over our cherished memories, favorite movies or significant presentations.
So, burning video to DVD is an essential skill when you want to save your favorite movies or personal videos for future viewing or sharing them with friends. In this article, we'll delve into how to burn your videos to DVDs with the best and free DVD maker.
1. What to Prepare before Burning Video to DVD?
When it comes to burning vide files to a playable DVD, such as burning MKV to DVD, you shall make some preparations in advance. After all, one cannot make bricks without straw.
2. Burn Video to DVD for Windows/Mac Using DVDFab (Video DVD)
2.1 Best Software to Burn Video to Playable DVD | DVDFab DVD Creator
If you are seeking the best video to DVD burning software, you are in the right place. Here comes DVDFab DVD Creator that enables you to create a playable video DVD disc, ISO file or folder from multiple types of video files with fast speed and premium quality.
💻Available on: Win 11/10/8.1/8/7 & Mac 10.10-13
Features:
- Burn video to DVD/ISO image/Folder from all popular formats, such as MKV, MP4, AVI, M2TS, TS, VOB, MOV, WMV, WMA, 3GP, FLV, M4V, Video_TS, etc.
- Support all DVD disc formats, DVD+R/RW, DVD-R/RW, DVD+R DL, DVD-R DL
- Make and customize DVD menu with professional and stylish templates
- Convert MP4 to DVD with 50 times faster speed (GPU hardware acceleration)
- Output lossless-quality DVD playable on home player or media software
- Synchronize all the meta info of the source video
2.2 How to Burn Videos to DVDs in Lossless Quality with DVDFab DVD Creator?
Now let's start to find out how to burn videos, such as iPhone videos to DVD within 3 simple clicks with stunning quality.
Step 1: Download and launch DVDFab, and load video source
Upon free download and pure installation, move to the left pane to select DVD Creator when the program runs. Load video source or simply drag & drop it onto the main UI.
Step 2: Personalize output DVD via Advanced Settings & Menu Setting
Go to "Advanced Settings" to select output DVD size: DVD-9 (8.5G storage capacity) or DVD-5 (4.7G), Menu Properties such as TV Standard (NTSC & PAL) and Aspect Ratio (16:9 & 4:3), and Playback Mode (start from menu or titles). Meanwhile, feel free to add external subtitles to your DVD movie.
Go to "Menu Setting" to create DVD menu as per personal preference for better playback control. You can also adjust the elements or widgets inside the built-in menu templates, such as adding your own image or text to the menu background, changing text size, font, color of the subtitles of control button. The main menu, buttons, theme selection menu are all under your control.
Step 3: Start to burn video to DVD with Turbo Speed
Insert a blank DVD disc into the optical drive of your computer. Alternatively, save the output DVD as ISO file or movie folder if you have no blank DVD disc at hand. Once done, hit the Start button to burn DVD Windows 10 and Mac.
3. Burn Video to DVD Using a Windows (Data DVD)
3.1 Built-in Video to Data DVD Software - Windows Media Player
Windows Media Player is a free and user-friendly multimedia software operated by Microsoft. It provides functionality for playing audio, video, and viewing images on computers running the Windows operating system. In addition, this versatile software allows you to burn your desired songs, pictures, or videos onto a CD or DVD, turning them into data discs for playback on appropriate systems. However, you cannot use Windows Media Player to create video DVDs that you could play on a regular DVD player.
💻Available on: Windows 10/8/8.1/7/Vista/XP
3.2 How to Burn Video Files to a Data DVD with Windows Media Player?
Step 1: Open Windows Media Player and insert a blank DVD
Launch the program either from the shortcut on your desktop or from the programs list in the Start menu. Then place a blank DVD in your DVD writer drive. Ensure that the drive is either a DVD-R or DVD+R as these are typically the formats that are compatible with Windows Media Player.
Step 2: Switch to burn list and add files
At the top right of the player, switch from the 'Play' tab to the 'Burn' tab. Navigate through your folders and find the video files you want to burn. Drag them to the burn list in the right pane of the Windows Media Player.
Step 3: Choose the right burning option and start burning video to data DVD
Click on the 'Burn options' drop-down menu and choose 'Data DVD'. Once you're satisfied with your burn list, click on 'Start Burn'. This feature allows Windows Media Player to start writing the video files onto your DVD.
4. Burn Video to DVD Using a Mac (Data DVD)
4.1 Built-in Video to Data DVD Software - Finder
Finder is the default file manager and graphical user interface shell used on all Macintosh operating systems. Described in layman's terms, Finder facilitates your interaction with your Mac's operating system and files; it helps you organize and access almost everything on your Mac. You can also use Finder to burn your video files to a data DVD, although it does not have features to create a DVD menu or burn a playable video DVD
💻Available on: All macOS versions
4.2 How to Burn Video Files to a Data DVD with Finder?
Step 1: Insert a blank or rewritable disc into your Mac's DVD drive and wait for it to appear on your desktop. Double-click on the DVD, and when it opens, go to Finder.
Step 2: Locate the video files that you wish to burn onto the DVD. You can do this by using Finder's search bar or manually searching through your files. Drag the selected files into the open DVD folder.
Step 3: Once you've relocated all the files, click on "File" in the menu bar at the top of the screen.
Step 4: Choose the 'Burn [disc]' option to start the burning process. A pop-up window will appear asking you to confirm the action. Click 'Burn'.
The following Frequently Asked Questions might be helpful to you when you want to hunt for the best video to DVD burning software.
What type of DVD is best for burning videos?
The type of DVD best for burning videos is a DVDR or DVD+R, as these formats are compatible with the majority of DVD players and computers. These discs typically have a capacity of 4.7GB. If you need to store more data than this, consider using a dual-layer disc such as a DVD+R DL or DVD-R DL, which can store up to 8.5GB.
AWhat does an external DVD burner do?
An external DVD burner is a device that connects to your computer and allows you to record data onto blank DVDs. It's called "external" because it isn't built into the body of the computer itself but instead plugs in through a USB or another type of connection. External DVD burners are useful for creating physical copies of digital media.
AHow to Burn a YouTube Video to DVD?
In order to burn YouTube video to DVD, first, you shall download streaming video with StreamFab, a versatile video downloader that enables you to download your desired videos 1000+ sites with lightning-fast speed and peak quality. Afterwards, import the downloaded video files to the video DVD burner program mentioned above.
AConclusion
This post has given you a clear picture of how to burn video to DVD free, fast and with lossless quality with DVDFab DVD Creator. Bear the tutorial in mind so that you can get a DVD video disc free with amazing quality. Moreover, this versatile program works as Blu-ray burning software, so you can also use it to transfer your videos on to a Blu-ray disc.
