DVD Flick Review: Download, Safety, and Alternatives in 2026
Summary: DVD Flick remains a free Windows DVD authoring tool for turning common video files into playable DVDs, VIDEO_TS folders, or ISO images with basic menus and subtitle support. Its value is zero cost, no ads, and broad import support, but the 2009 build is slow to encode and may run into audio sync, import, or Windows 10/11 compatibility issues. Download it from the official site or SourceForge, and choose maintained software like DVDFab for repeated DVD projects.
DVD Flick remains available for download, but its latest official build dates to 2009 and Windows 11 is not officially listed. This DVD Flick review explains where to get the authentic installer, what reliability problems to expect, and when a maintained DVD Flick alternative makes more sense.
What Is DVD Flick
DVD Flick is a free, open-source DVD burning software for the Windows platform, developed by Dennis Meuwissen. Its core function is to convert various video files on a computer (such as AVI, MP4, WMV, MOV, FLV, MPEG, etc.) into the standard DVD-Video structure, creating DVD discs or ISO images that can be played directly on DVD players or home theater systems.
Working together with external components like FFmpeg to handle encoding and multiplexing, it is often regarded as a "free yet relatively powerful" DVD authoring tool, mainly aimed at users who have some basic understanding of DVDs and audio-video formats and need to create playable DVD discs.
Key Features of DVD Flick
Wide Format Support
In terms of format support, DVD Flick's key strength is that it can import many commonly used video files. Relying on FFmpeg for decoding and encoding, it supports a broad range of listed containers, video codecs, and audio codecs, although successful import still depends on the streams inside each file. Mainstream formats such as MP4, MKV, AVI, WMV, MOV, MPG, and FLV can all be used as source files, which makes it very suitable for handling video collections with mixed and varied formats. For movies, TV episodes, or home DV recordings that were saved in DivX in the early days, DVD Flick can also copy DivX to DVD. This is more than sufficient for everyday use by ordinary users.
Basic Menu Creation
DVD Flick comes with basic DVD menu creation features and supports creating simple title menus and chapter menus for the whole disc. It offers a few clean preset templates that can display the thumbnail and title of each Title. In the menu settings, users can choose a template, set a background image, and adjust the button layout, so a remote-control-friendly menu can be generated quickly. However, the overall style is quite simple, making it more suitable for projects where visual appearance is not a high priority. Users who need more templates or detailed navigation controls may prefer a current DVD menu maker.
Burning Capabilities
In terms of output, DVD Flick can not only create a standard DVD folder structure (VIDEO_TS), but also generate ISO image files and integrate with ImgBurn to burn the encoded project directly onto blank DVD±R/±RW discs. This means that from adding videos and encoding to final burning, users can basically complete the workflow within the same process, without manually using additional burning software. You need to have ImgBurn installed, then choose in the final step whether DVD Flick should hand the completed project to ImgBurn. In practical terms, DVD Flick converts the source files into a DVD-Video structure, adds optional menus and subtitles, and then saves a VIDEO_TS folder or ISO image or sends the project to ImgBurn.
Subtitle Support
DVD Flick supports adding multiple external subtitle tracks for each title and is compatible with common subtitle formats such as SRT, ASS, and SSA. In the "Subtitles" tab of the title properties, users can import, sort, and manage subtitle files. In the subtitle editing interface, users can also adjust subtitle language, font, font size, position, and margins so that the subtitles display more appropriately on TVs or players, meeting the needs of making DVDs with different language versions or custom subtitles.
DVD Flick Pros, Cons, and Reliability
Free and no watermarks:DVD Flick is free and open source, with no built-in output watermark, making it practical for occasional projects and users who prioritize zero software cost.
User-friendly: Its basic workflow is direct: add the source videos, configure titles and menus, encode the project, and save or burn the resulting DVD-Video structure.
Easy DVD menu creation: Although the templates are simple, DVD Flick can quickly generate usable title and chapter menus.
Good format compatibility:It supports many common containers and codecs, although files with newer or unusual internal streams may still fail during import.
Audio sync issues and slow encoding:Audio delay, dropouts, or stutter can appear with long or complex sources. Check the source frame rate and audio first, then remux or convert it with a current tool; switch authoring software if the problem remains.
Import errors and unusable video tracks:Error 48, missing thumbnails, or a no-usable-video-track message can indicate that a stream was parsed poorly. Inspect or remux the source, and use another authoring tool if repeated conversions do not help.
Oversized projects and failed burns:If the project exceeds the selected disc capacity or a dual-layer burn stops, reduce the project size, create a folder or ISO first, and check the blank media and drive. Repeated failures are a reasonable point to switch tools.
Standard DVD-Video quality limits:DVD-Video normally uses 720x480 NTSC or 720x576 PAL video, so a 1080p source will be reduced to standard definition. That resolution change is expected and does not by itself indicate a defective encode.
DVD Flick Download, Safety, and Modern Windows Limits
DVD Flick is an early open-source DVD authoring program first released in 2006. Its official DVD Flick download page still provides version 1.3.0.7, released on June 26, 2009. The software is free and open source, and the official requirements list Windows 2000 Professional, Windows XP, and Windows Vista. No newer official build has been released.
Windows 11 is not included in those official requirements. DVD Flick may still launch on some newer Windows systems, but that is different from receiving current compatibility support. Freezes, unresponsive encoding stages, missing previews, or failed burns may depend on the source file, legacy components, permissions, or the local burning setup rather than one universal defect.
Installer-source safety and runtime compatibility are separate questions. Softonic reported a clean VirusTotal result for an installer in July 2024, but that dated result cannot establish the status of every mirror or later download. Use the official DVD Flick site or its established SourceForge project rather than an unknown third-party package, without treating any download source as an absolute guarantee.
The authentic installer is straightforward to find, but choosing DVD Flick for a new workflow requires more caution than downloading it. A maintained alternative is worth considering when Windows 11 support, macOS access, detailed menu control, built-in editing, or repeated authoring failures matter more than keeping the software fully free.
Best DVD Flick Alternative - DVDFab DVD Creator
DVD Flick is now a legacy option rather than an actively developed DVD authoring tool. If it crashes on a newer version of Windows, if you prefer software that still receives updates, or if you need a DVD creator for macOS, DVDFab DVD Creator is an alternative worth considering. The following section explains its main features, compares it with DVD Flick, and shows how to create a DVD with it.
DVDFab DVD Creator can convert common video formats into playable DVD discs, ISO images, or DVD folders on Windows and macOS. It supports DVD±R, DVD±RW, and dual-layer discs, and includes customizable menu templates, chapter settings, real-time preview, and a built-in editor for trimming, cropping, adding subtitles, and adjusting the image. Hardware acceleration through supported NVIDIA, AMD, Intel, and Apple technologies can reduce encoding time. The software is actively maintained, making it a more suitable option for current Windows and macOS systems.
Supported OS:
Free Download Windows 11/10/8.1/8/
How to Create a DVD with DVDFab DVD Creator:
Step 1: Download and install DVDFab software
Click the official download link and install DVDFab DVD Creator on your computer. Then launch the program and select the Creator module on the main interface.
Step 2: Load your source videos
Load the source video(s) you want to burn with the Add button on the main page, or by simply dragging and dropping the file into the main page.
Step 3: Edit and personalize your video
Before creating the DVD, click the Video Edit icon to trim or crop the picture, remove black bars, adjust the aspect ratio, rotate the video, or add a text or image watermark.
Step 4: Customize your DVD menu and output settings
Click the Wrench icon to configure the DVD size, aspect ratio, and playback settings. Then select Set Menu to choose a template and customize the background image or music, buttons, chapter thumbnails, and chapter names.
Step 5: Choose the destination and start creating
In the Save to section, choose whether to burn to compatible blank DVD media or save the project as a VIDEO_TS folder or ISO image. Click Start to begin creating the DVD. Total processing time depends on the source complexity, output settings, and available hardware even when acceleration is enabled.
Is DVD Flick free?
Yes. DVD Flick is free, open-source DVD authoring software released under the GNU GPL. The official site states that it has no paid limitations, adware, or spyware.
Is DVD Flick safe to use?
DVD Flick is generally safe when downloaded from its official website or established SourceForge project page. However, the latest official version, 1.3.0.7, dates from 2009, so it is no longer actively maintained and may have compatibility or stability issues on newer Windows systems.
How do I use DVD Flick?
Open DVD Flick and click Add title to import your videos. Edit the chapters, audio tracks, and subtitles, then choose the disc size, video format, encoding profile, and menu. Select an output folder, enable disc burning when needed, and click Create DVD to encode and author the project.
Why does DVD Flick show Error 48?
Error 48 or a no-usable-video-track message can occur when DVD Flick cannot correctly parse a video or audio stream inside the source file. Inspect or remux the source with a current converter, then try again. If several converted versions fail, switching authoring software is more practical than assuming one universal cause.
Is DVDStyler still free to use?
Yes. DVDStyler is a free, open-source DVD authoring program for Windows and Linux. It is a practical alternative for users who prioritize zero cost and customizable menus, although it is not the only current option and does not provide the same cross-platform fit as a Windows-and-macOS product.
DVD Flick can still suit a simple project on a legacy Windows system when the source imports cleanly, basic menus are enough, and processing time is not critical. I would choose a maintained alternative for Windows 11, macOS, detailed menu design, built-in editing, or repeated import and burn failures. DVDStyler fits users who require a free, open-source option, while DVDFab DVD Creator is a alternative choice for a maintained cross-platform workflow. Whichever tool you select, confirm the output format, menu structure, subtitles, and disc capacity before you make your own DVD.
![5 Top AVI to DVD Converters for Windows and Mac [2026]](https://images.dvdfab.cn/artifact/2026/10/19/HsCx2t8W3VyD6wHfogzkhte4XqgpBqdz/feature_cover.jpg)
