How to Rip 3D Blu-Ray to Google Cardboard?
Summary: This article gives a brief introduction to Google Cardboard and shows you how to rip and convert 3D Blu-ray to Google Cardboard with ripper tool like DVDFab Blu-ray Ripper.
Introduction to Google Cardboard
Google Cardboard is a virtual reality (VR) platform developed by Google. It offers a very simple and fun way to experience virtual reality and the world of immersive technology that is geared towards games, movies and much more in 3D and not 2D anymore. There are apps that allow you to download 3D content to your device, a smart phone, which you can place it inside the cardboard, fold it, and look into it through the lenses.
This is the a simple device with a pair of lenses that allow you to watch a movie in SBS format, also known as the side-by-side format that allow you watch 3D google cardboard movies. It is immersive and looks very real. Moreover, rip Blu-ray to Google Cardboard compatible file type is simple and straightforward. In order to watch 3d movies on google cardboard, the things you must need are a Cardboard, a smart phone and a blu-ray ripper that will do the conversion from Blu-ray 3D file format to the SBS file format for the smart phone.
What is SBS file type?
A typical side-by-side file or media can look something like this below. It is called SBS because of the split screen viewing type that plays the same media twice placed beside each other horizontally. In order to get the content from your Blu-ray discs to start looking like that you have to do some file conversion using the software. There are good softwares in the market both for free and paid like EaseFab, DVDFab, and much more. These do the following stuff from the encrypted Blu-ray discs you have at home. The Blu-ray file format can be arranged in Blu-ray folders, ISO images and so on to store the 3D movie in a “frame stacked” format as it is called in layman terms. It is not ideal for viewing on a Google Cardboard, so you need to rip Blu-ray to Google Cardboard type.
The ripping process is a simple or complex task depending on the software you are using. It can take somewhere from minutes to hours depending on the length of the movie, the size of the Blu-ray disc (often it can span between 50 GB to 100 GB), the CPU, the GPU and RAM of your computer. Therefore, the computing resources in terms of hardware and the software that can make use of that hardware also count towards the swiftness in decrypting the content from a Blu-ray disc to another file format such s AVI, MKV, FLV etc. but in 3D type.
These files, after the conversion has to be transferred to the MicroSD card, placed inside your smart phone, put the smart phone inside the Google Cardboard flap, and playback the media file using its media player. The charm happens due to the combination of the lenses and the SBS video playback mode.
DVDFab Blu-ray Ripper is an amazing tool that can rip 3D Blu-ray to Google Cardboard at extremely fast speed. It has prepared many 3D profiles like 3D AVI, 3D MKV, 3D MP4 and more for you to choose. After choosing a 3D profile, you can go to “Advanced Settings” panel to set the 3D video as SBS format.
It is available for Windows, Mac and Linux systems. The whole process of ripping 3D Blu-ray to Google Cardboard is pretty easy:
Step 1: After installing DVDFab Blu-ray Ripper, click on the "Ripper" module and upload Blu-ray disc/ISO/folder.
Step 2: Go to “Advanced Settings” to select the 3D format as “split screen”. You can also click Choose Other Profile to convert your Blu-ray to MP4, MKV, AVI, MP3 and many other digital formats. Select the titles, audio tracks, and subtitles you want to retain.
Step 3: After you click the “Start” button, you can get a SBS 3D video within a few minutes. And then you can put the SBS 3D video to your smartphone to enjoy it through the Google Cardboard.
Leawo Blu-ray Ripper
Leawo blu-ray ripper is a wonderful tool to rip Blu-ray files of any size, and allow conversion to other file formats like 3D MKV or 3D AVI and so on. These are available in form of presets and you just have to choose it from a list or drop-down menu, as a user. The end user just has to add the 3D Blu-ray media files from the disc player, after launching the program, preview the movie from the list of titles it can read from that disc, choose which one to convert, select an output file type, and click on “Convert”. You can put your iPhone into the Google Cardboard, and enjoy the google bluray 3D movies.
EaseFab Blu-ray Ripper
To make 3d movies for google cardboard, you can also consider this tool. EaseFab Blu-ray Ripper is a software designed to rip and convert Blu-ray discs into various digital formats. It allows users to extract the content from Blu-ray discs and save it as video files that can be played on different devices such as computers, smartphones, tablets, or media players. With its user-friendly interface and advanced features, this Blu-ray Ripper Mac enables users to customize output settings, edit videos, and preserve the original quality of the Blu-ray content during the ripping process.
In conclusion, there are three ripper tools tell you how to rip Blu-ray for viewing on Google Cardboard. By following these techniques, users can enjoy immersive 3D google cardboard movies on their virtual reality headset, enhancing their entertainment experience.
