How to Rip 4K Blu-ray Disc with Lossless Quality on Windows & Mac?
Summary: If you want to enjoy 4K UHD movies without investing in a specialized player, then you can choose another way, which is to rip 4K Blu-ray discs and watch them on your existing devices, such as 4K TVs or monitors. What you need is an efficient 4K Blu-ray ripper that allows you to enjoy high-quality movies without purchasing additional equipment.
Ripping 4K Blu-ray discs is becoming increasingly popular as movie lovers want easy access to their collections. 4K Ultra HD has four times the resolution of standard Blu-ray, and movies come to life in detail and sound. However, dedicated players are expensive. Also, as many users have reported, scratched or damaged discs may not play. By ripping 4K UHD movies, you can back up your collection, save on hardware costs, and enjoy the stunning quality on multiple devices.
What Do You Need to Rip 4K Blu-ray
To rip 4K UHD discs losslessly, you'll need to prepare a few tools.
- • 4K Blu-ray Drive: A 4K UHD-friendly Blu-ray drive is required to read the disc and transfer the data to your computer.
- • 4K Blu-ray Ripping Software: You will need a dedicated 4K Blu-ray ripper that can decrypt the content and convert it into a digital format.
- • Hard Drive Space: 4K Blu-ray are quite large, so ensure that you have enough free space on your hard drive to store the ripped files.
There are multiple programs available for ripping 4K Blu-ray discs, but choosing the right one is key to preserving quality and meeting your needs. Below, we'll introduce two powerful and reliable options to help you convert UHD discs losslessly.
How to Rip 4K Blu-ray with DVDFab UHD Ripper [Professional]
This 4K Blu-ray ripping software provides leading cloud decryption service to quickly remove any protection from 4K Ultra HD movie discs. Now, let's learn more about its main features.
- Rip UHD to popular audio and video formats, like MP4, MKV, M2TS, AAC, WMA, etc
- Compress UHD video while preserving high-quality visual and audio effects
- Customizable ripping settings: adjust codecs, frame rates, trim and merge video, etc
- Manage subtitles in a variety of ways, including converting them to SRT files
- Rip large 4K UHD Blu-ray discs at ultra-high speeds with advanced hardware acceleration
- Rip 4K Blu-ray to lossless video (MP4/MKV/M2TS Passthrough) and high-fidelity audio (DTS-HD, TrueHD and DTS:X)
Easy Steps to Rip 4K UHD Blu-ray with DVDFab UHD Ripper
Now that you've learned more about the best 4K Blu-ray Decrypter software, go ahead and check out this quick step-by-step guide to mastering the 4K ripping process.
Step 1: Initiate DVDFab and Import Your 4K Blu-ray
Free download and open DVDFab 13 software. Select the Ripper module from the top menu. Insert a 4K Ultra HD Blu-ray disc and the software should automatically load it. Alternatively, you can click the + icon to load the 4K Ultra HD Blu-ray folder or ISO file.
Step 2: Choose Your Desired Conversion Profile
Find and click the option of Choose Other Profile and then there will be lots of output video formats in sight. Make sure to use the available filters if you're looking for a specific format. Rip 4K Blu-ray movies to your favorite video format for quality backup and playback on mobile devices.
Step 3: Adjust the Settings to Suit Your Needs
Before start ripping 4K Blu-ray movies, you may want to first customize it. For example, you can rename the output, pick the titles you want to rip or add audio tracks and subtitles. You can also use the Advanced Settings and Edit options, to make additional changes like adding watermarks, cropping, or trimming the video, and changing the aspect ratio or the resolution, among others.
Step 4: Select the Output Directory and Start to Rip 4K Blu-ray
Click the folder icon found towards the bottom of the menu to change the default destination if necessary. Once you've made all the necessary changes you can rip 4K Bluray movies by simply clicking the Start button found in the lower-left corner. After converting 4K Blu-ray movies to 4K digital videos, it's time to watch videos on a 4K media player.
How to Rip 4K Blu-ray with MakeMKV [Free But Limited]
MakeMKV is a highly regarded, free software designed for ripping (4K UHD)Blu-ray discs with ease. Unlike many other tools, MakeMKV can handle both unprotected and encrypted Blu-ray discs, allowing you to bypass some copy protections. It rips Blu-ray discs into the MKV format, which retains the full video, audio, and subtitle tracks without any loss of quality.
More than just eliminating the need for additional decryption tools, MakeMKV offers great features for enthusiasts who want a straightforward ripping solution.
- Free for ripping 4K Blu-ray discs (no ongoing costs)
- Available for Windows, and macOS
- Preserves original quality with video, audio and subtitles intact
- Smooth handling of partially encrypted discs
- Beta update has a limited duration
- Limited to MKV format and lack of other output options
- Doesn't support advanced features like editing or menu customization
Detailed Steps for Ripping 4K Blu-ray using MakeMKV
Step 1: Download and Install MakeMKV
Download and install MakeMKV from the official website. Make sure to choose the appropriate version for your operating system. And it is free to use during the beta period, but a small fee may be charged after the beta.
Step 2: Insert Your 4K Blu-ray Disc
- Insert your 4K Blu-ray disc into your computer's Blu-ray drive. The software automatically detects the inserted disc and scans its contents.
- It will display the list of available tracks including video, audio and subtitles. You can uncheck any tracks you don't need.
- If you want to preserve the original quality, make sure to select the highest resolution video stream (usually labeled “Title” with the largest file size) and keep the 7.1 audio tracks (DTS-HD, TrueHD).
Step 3: Begin the Ripping Process
After checking the settings and selecting the location to save your files, click the “Make MKV” button in the upper right corner.
Comparison of the Best 4K Blu-ray Rippers
Features | DVDFab UHD Ripper | MakeMKV |
Rip Encrypted 4k Blu-ray | ✔️ | ✔️ |
Output Formats | MKV, M2TS and MP4 | MKV only |
Retain HDR10/Dolby Vision | ✔️ | ❌ |
Lossless Quality | ✔️ | ✔️ |
Compress Video Size | ✔️ | ❌ |
Ripping Speed | 50X Faster | Moderate |
Built-in Video Editor | ✔️ | ❌ |
DVDFab UHD Ripper is more flexible in terms of output format, compression, and HDR support, while MakeMKV is known for its simplicity and focuses on ripping Blu-rays to MKV, but doesn't offer editing or compression features.
Ripping a 4K Blu-ray disc may be illegal in certain countries, as it involves creating a copy of copyrighted content. In most regions, it’s only legal to rip DVDs and Blu-ray discs for personal use, and any distribution or sharing of those copies is prohibited.
Can you rip 4K Blu-ray with regular Blu-ray drive?
No. To rip 4K Blu-rays, you need a UHD-capable Blu-ray drive that specifically supports 4K UHD content and can handle the increased copy protection measures on 4K discs.
How much space does a ripped 4K Blu-ray take up?
A ripped 4K Blu-ray movie can take up anywhere from 50GB to 100GB of storage space depending on the length of the film and the bit rate at which it's encoded.
Do you need a special Blu-ray player to play 4K UHD?
Yes, you need a 4K Blu-ray player, as regular Blu-ray players cannot support 4K content. Additionally, to fully experience the enhanced resolution, you'll need a 4K-compatible TV or monitor that supports UHD playback.
As you can see, it's not necessary to buy a new player if you want to enjoy 4K UHD Blu-ray movies at home. You can achieve virtually the same results using 4K Blu-ray ripping software, which is a much cheaper option than buying a new player. In addition to excellent video and audio quality, DVDFab UHD Ripper also provides you with plenty of tools that allow you to customize files to suit your specific needs.
