Convert FLAC to MP3? — Why & How
Summary: Is it really necessary to convert FLAC to MP3? What do I get if I convert FLAC to MP3? In this article, we will try to explain why under certain circumstances, it is necessary, while to some specific users, there is no need to convert FLAC to MP3.
Part 1. Convert FLAC to MP3, does it worth the effort?
As we all know, FLAC is a free and open-source lossless audio format created to compete with other copyrighted lossless audio formats such as the ALAC from Apple, WAV and WMA from Microsoft. While MP3 is a lossy audio format, so why would anyone still wants to convert FLAC to MP3 given the fact that most of the smartphones, tablets and media players already support the playback of this high quality audio file. Yes, it is true that compared with the lossy MP3 audio, FLAC can deliver better audio quality.
However, FLAC also has its limitations. The 1st one goes to its file size. As a lossless format, it means that an FLAC file will be much larger than an MP3 file of the same duration, usually 6 times larger. This is not such a big difference if you are only carrying dozens of songs on your phone, but it will be a problem if you have hundreds of songs. So if you want to make enough room for videos and images on your phone, then converting FLAC audios to MP3 can save you much free space.
The 2nd one goes to the fact that to enjoy the better sound quality that FLAC brings, you will need a premium headphone and also a set of better sound system that is capable of showing you how amazing FLAC can be. If you’re just an average listener who just wants to listen to your favorite music on a smartphone, then you definitely won’t be able to hear a single difference between an FLAC file and an MP3 file, then FLAC file is meaningless to you in this case.
So now you probably already have the idea whether you want FLAC or MP3 files. If you don’t have to worry about the free space on your device, for example if you have a 256GB/512GB smartphone, and you have a top-class headphone, then staying with FLAC files might be your best choice. Otherwise, if you don’t have much free space on your smartphone, and don’t have a better-enough headphone either, then, it is better to convert FLAC files to MP3 files or download streaming video or audio in mp3 files directly are more practical for you.
Part 2. How to Convert FALC to MP3 with an FLAC to MP3 Converter PC Software
Having made your choice of MP3 over FLAC, then here comes the next question — how to convert FLAC to MP3 with an FLAC to MP3 converter on computer? Or how can I convert FLAC to MP3 online with an online FLAC to MP3 converter? Don’t worry, we will solve these problems in the following sections.
2.1 DVDFab Video Converter
Available on: both Windows and macOS
Pricing: 30-day fully-functional free trial; $29.99/mo; $59.99/lifetime
The 1st FLAC to MP3 converter software we’re going to introduce is the video converter software from DVDFab 12, which is one of three products bundled in the Video Converter Pro suite. Being a video converter with its name does not prevent it from also being an advanced audio converter software. Actually, it is capable of converting all the popular audio formats from one to another that includes from FLAC to MP3 of course.
Key Features:
- Convert audios from one format to another, including FLAC to MP3
- Allows for customization of output audio parameters of your preference
- Support to batch convert FLAC to MP3 to save you much valuable time
- Support GPU hardware acceleration to further speed up the conversion
Now refer to the guides below for the detailed information on how to convert FLAC to MP3 with this audio converter software like a Pro guy does.
Step 1 — Download and Installation
Download and install it first, using the two Download buttons below, one for Windows, the other macOS.
Step 2 — Add Your FLAC Files
Once this converter is successfully installed on your computer, double-click its desktop icon to launch the program, navigate to the Converter module, and load your FLAC file(s) using the giant Plus button, the Add from Local button at the upper left corner, or simply drag & drop the FLAC file(s) here.
Additional Tips:
As one of the bonus features of this software, the Add from Mobile button next to the Add from Local button allows you to directly add your FLAC files from a smartphone or tablet, regardless of iOS or Android, with the condition that you install DVDFab Remote to that device, which serves as the virtual data cable via Wi-Fi to transfer the files.
Step 3 — Choose the MP3 Profile
After adding the FLAC file, you will be asked to choose the MP3 conversion profile. To that end, click the “Choose Other Profile” option from the dropdown menu of Profile Selection Box to enter the built-in Profile Library, where you can see hundreds of pre-configured and tested conversion profiles designed for different video containers and all the playback devices. Move to the Format > Audio section, and then select the MP3 format.
As a sidenote: As another bonus feature of this FLAC to MP3 converter, it allows you to batch-convert FLAC to MP3 to save you much of your valuable time. To use the batch-conversion mode, don’t forget to enable the option of “Use for all sources” when you choose the MP3 profile at the profile library, and if you don’t, you will have to manually repeat that process for all the FLAC files you’re added.
Step 4 — Customize Output Parameters (Optional)
To most of the average listeners, having chosen the MP3 conversion means that it’s okay to start the FLAC to MP3 conversion. But if you want something more, then can click the Wrench icon to locate the Advanced Settings panel where you can experiment with different audio channel options including Mono, Stereo, Dolby Surround/ProLogic and Dolby ProLogic II, adjust the volume and the bitrate as well.
Additional Tips: As the conversion from FLAC to MP3 will downgrade the audio quality, so you may want to know how to convert FLAC to MP3 without losing too much quality? The answer is that you can set a higher bit rate level, such as 320 kbps, or even higher is possible to improve the output MP3 audio quality.
Step 5 — Start the FLAC to MP3 Conversion
The last thing regarding converting FLAC to MP3 is to actually start the conversion by hitting the Start button at the bottom right corner of the main interface.
Alright! Above information shows you with great detail of how to convert FLAC to MP3 with DVDFab Video Converter like a pro does. Hope you enjoy the process. Now, let’s move on to another FLAC to MP3 converter which is also bundled in the Video Converter Pro suite, the DVDFab Toolkit.
2.2 DVDFab Toolkit
DVDFab Toolkit is a multimedia conversion and editing suite that contains 28 independent video, audio and image conversion and editing tools. Among those 28 tools, the converter module from the audio tools works as an all-powerful audio converter software that is able to convert FLAC to MP3, and also to a couple of other popular audio formats.
Available on: Windows as of now
Pricing: 30-day fully-functional free trial; $26.99/mo; $79.99/lifetime
Key Features of this FLAC to MP3 Converter:
- Convert FLAC to MP3 at up to 512 kbps
- Customize output audio parameters freely
- Support to batch-convert FLAC to MP3
- Convert audios between other popular formats
Now let’s take a look at this FLAC to MP3 converter helps us do the conversion with ease.
Step 1 — Download and install DVDFab Toolkit, using the download button below. As of now, only the Windows version is available.
Step 2 — Navigate to the Audio Tools section after launch of the program, and then click on the Converter module.
Step 3 — Click the giant plus button to load your FLAC files, or simply drag & drop them here.
Step 4 — When the source FLAC files are here, choose the MP3 format from the output dropdown menu, your favorite audio channel and preferred bitrate of up to 512 kbps. To be noted that, if you want the final MP3 files to maximally preserve the original FLAC quality, you should choose a higher bitrate level.
Additional Tips: This FLAC to MP3 converter also supports batch conversion mode, but you have to select the MP3 output format manually for each FLAC file.
Step 5 — When all you’re done with the settings, click the Start button to trigger the FLAC to MP3 conversion. The time needed for the conversion varies from a few seconds to one minute or so, depending your computer configuration and the size of your source FLAC file.
Okay, here we are! When conversion finishes, transfer the output MP3 file(s) to your smartphone and start enjoying them anytime you are convenient.
2.3 DVDFab Video Editor
So far we’ve learned how to convert FLAC to MP3 with the Video Converter and Toolkit from the Video Converter Pro suite, there is still the last product from this bundle, the Video Editor. Although Video Editor is mainly a video editing software, it does offer the feature to convert FLAC to MP3 in the simplest way.
Pricing: 30-day fully-functional free trial; $54.99/year; $99.99/lifetime
- Convert FLAC to MP3 or AAC at up to 320 kbps
Now let’s walk through the steps to see how Video Editor does that in the simplest way:
Step 1 — Download and install Video Editor to your computer via the Download button below, which is only for Windows platform as of now.
Step 2 — Launch the program, use the Import button at the upper left corner to load the FLAC file (or, you can also use the drag & drop way) to the Media Library, and then click the green plus button that appears when you point your curser to the FLAC file to add it to the timeline of the working area below.
Step 3 — Click the Export button from the top left menu bar, then at the popup window, move to the Audio tab to select MP3 from the video format dropdown menu. The last thing to do is to click the Export button to start the conversion.
Additional Tips: the Gear icon behind the format selection box will take you the audio settings window where you can customize according to your own needs on FLAC to MP3 conversion.
Part 3. How to Convert FLAC to MP3 with an Online FLAC to MP3 Converter
In addition to the FLAC to MP3 converter PC software tools, you can also opt for an online FLAC to MP3 converter. This way, you don’t need to install anything, however, you will still have to upload your FLAC files to such a website and when the conversion gets done, download the converted MP3 files back to your local hard drive.
What’s more, sometimes you may also need to bear with a comparatively slow FLAC to MP3 conversion speed, especially when you want to use the batch-conversion mode to perform multiple FLAC to MP3 conversion instances at one time, because the online version depends a lot on your network speed. Anyway, next we’ll introduce you an online FLAC to MP3 converter website that can help you with your job.
Online-Audio-Converter.com is a free, quick and simple web-based online FLAC to MP3 converter solution. It does not ask you to purchase a subscription nor download and install anything. Everything you need to convert FLAC to MP3 files is right on the main page of this website. As for how it works, refer to the detailed guide below:
Step 1 — Add your source FLAC file. You can use the Add Files button to load files from your local drive, or Google, Dropbox and URL icon to load FLAC file from your Google cloud drive, Dropbox account, or directly from a given URL, respectively.
Step 2 — Click MP3 from the output format bar, use the slider below to choose your wanted bitrate quality, and if you want more settings, click the Advanced Settings button to change relevant settings there according to your specific demand.
Step 3 — Press the Convert button to start the online FLAC to MP3 conversion, which shall take some time depending on your network speed and file size.
Above steps demonstrate how to start an online FLAC to MP3 conversion with an online FLAC to MP3 conversion website. It’s quite easy if you only have several FLAC files to convert, however, if you have a larger collection of FLAC files that you want to convert to MP3, the conversion process might not seem to be a pleasant thing for you.
Final Thought
In this article, we’ve discussed the reason why at times people may want to convert FALC to MP3, how to convert FLAC to MP3 offline with an FLAC to MP3 converter software either on Windows or macOS platform such as the video converter software we've discussed above, and also how an online FLAC to MP3 converter can also help you with your FLAC to MP3 conversion task. As for which way works the best, it is really hard to determine because everyone has different requirement regarding FLAC to MP3 conversion.
So our advice is that, as an average listener, if you just have to occasionally convert at times, then a free online FALC to MP3 converter website is more than enough for you, on the condition that you can stand with the slow conversion speed. However, if you are have heavy user and have large piles of FLAC files waiting for you to convert to MP3, then a PC FLAC to MP3 converter software is still your best shot, both in terms of performance efficiency and output quality. And one last thing, if you are also looking for a way to convert WAV files to MP3, then you can check out our topic on how to convert WAV to MP3 for better compatibility.
Other Articles You May Like:
Convert MP3 to M4A — Is It Really Necessary?
How to Convert WAV to MP4 to Share Your Music to YouTube
What's a Video Converter Android?
How to convert videos to MP3 audios
How to Add Music to YouTube Videos
How to Convert OGG to MP3 for Better Compatibility
Most Competent Video Clip Editors Available in 2020
Top 13 Best Photo Restoration Software 2020
Top 10 Solutions to Convert Low Resolution Image to High Resolution
