3GP to MP4 | 5 Best 3GP to MP4 Converters You Need
Summary: Do you want to convert 3GP to MP4 for flexible playback on various mobile devices or for smooth sharing on social networks to engage audience or promote brands? This post collects 5 best 3GP to MP4 converters for your reference. Read on for details and take your best pick!
Do you consider converting 3GP to MP4 for specific uses? What are the best free 3GP to MP4 converters? In the early days of mobile phones, the 3GP format was created that was supported by mobile phones. In those days, bigger formats were not supported by contemporary phones. 3GP is an extremely small format that compresses video to a big extent so that it takes less space on phone’s memory but quality degrades as well. The best thing is that the phones of this generation support almost all known video formats. So, you don’t need to use 3GP format now. MP4 will also work on your smartphone.
However, if you have videos in 3GP format, you can convert them to MP4 using 3GP to MP4 converter tools. In this article, we are going to best 3GP to MP4 converter tools that enable you to convert 3GP to MP4 online or on desktop computers.
1. Basic Information about 3GP?
What is 3GP video format?
3GP is a multimedia container format defined by the Third Generation Partnership Project (3GPP) for 3G UMTS multimedia services. It is widely used on 3G-enabled mobile phones but can also be played on some 2G and 4G phones. 3GP can hold video, audio, and text, of which video streams include H.263 or H.264 codec, AMR or AAC based audio streams, which are perfect for lossy compression of video data. Thus, it is favored by those fond of storing small video files in mobile phones but not carping at video quality.
Can I convert 3GP to MP4?
As the rapid development of multimedia technology, numerous video converter software programs emerge in an endless stream. What you need to do is run a 3GP to MP4 converter, load your 3GP file, and wait for the final converted MP4 video. Most of the 3GP converters can meet your basic needs. But if you want other operation like enhancing video quality via editing features or creative effects, you shall read through this post and choose your favorite 3GP to MP4 converter.
2. Top 5 Best 3GP to MP4 Converters Worth Your Try
When speaking of 3GP to MP4 converter freeware, you can choose from the below list. Because they can meet all your needs if you want to convert converting 3GP to MP4 online or on desktop computers.
DVDFab Video Converter Pro (Recommended)
This powerful yet easy-to-use 3GP to MP4 converter software ranks first on the list because it is a full-featured 3-in-1 video converter and video editor that enables users to convert video or audio between popular formats, and edit video, audio, or image as expected. It can meet all needs of editing multimedia files including videos, audio, or images. Let’s check its three tiny components.
Note that if you want to convert 3GP to MP4 online for free, simply turn to the online video converter.
Video Converter
As a professional video compressor, video converter, and video editor, DVDFab Video Converter is a multi-purpose video editing tool for all users especially those in need of video decoding and encoding. It boasts the following feature highlights.
- Convert video (4K/8K/HDR) to video or video to audio of various popular formats
- Support basic edit features including copping/trimming/merging, rotating, background music, watermarks, brightness & contrast adjustment
- Work with Enlarger AI to upscale video from 480p to 1080p, or from 1080p to 4K
- Advanced Settings to set video or audio parameters as needed
- Rich output profile featured by format & device
- Available on Windows & macOS
How to convert 3GP file to MP4 free and easily?
- Free download, launch DVDFab Video Converter Pro, and choose Video Converter module
- Load 3GP video source and customize MP4 output via Advanced Settings & Video Edit
Click the Advanced Settings (Wrench icon) to set parameters for output video and audio.
Click the Video Edit button (Pen icon) to edit video as needed. For instance, chop off unwanted part of the video, trim the beginning or end of the video and merge the rest as a single clip, add watermark (text or image), backgroung music, credit to the video, rotate video in clockwise or counterclockwise, adjust brightness, contrast, and saturation to make the video in ideal balance.
- Start to convert 3GP to MP4 free
When you choose this handy video converter, do not forget to try out the AI upscaling module to upscale video from 480p to 1080p, or from 1080p to 4K for better image quality.
Toolkit
This multimedia toolbox is small but complete in every detail. It contains over 20+ tiny tools to process video, audio, image, and subtitles. If you anticipate a light-weight multimedia editing tool that poses no system burden to PC, Toolkit will be your first choice. Within a blink of eye, you will get your 3GP to MP4 converted files as desired. Besides, you can try out other features to make your MP4 video more shinning and professional.
- Video tools: convert, trim, speed up/down, mirror/flip, rotate, crop, sharpen/unsharpen, deshake (GoPro), de-interlace, merge, extract videos
- Audio tools: convert, trim, volume adjust, denoise (GoPro), normalization, merge, extract audio, remux audio
- Image tools: video to GIF, video to PIC, PIC to video, GIF to video
- Watermark tools: text, image, times
- Subtitles: render subtitles, extract subtitles
How to convert 3GP to MP4 with Toolkit?
- Free download, launch DVDFab Video Converter Pro, and choose Toolkit module
- Load 3GP video and customize output MP4 via parameter setting
With this tiny but versatile toolbox, you can make a GIF a wallpaper for your mobile phone screensaver.
Video Editor
Compared to the professional video editing software in the market like Premier Pro, Video Editor, as a rising star, allows users to edit video, audio, and image via its powerful editing tools and vivid effects. Be it beginners or professionals, Video Editor will meet all needs as well.
- Comprehensive editing packs including speed & volume change, reverse/rotate/flip, color correction, crop, split, mosaic, zoom, freeze frame, set duration, green screen cutout, speech & text converter,
- Ample effects such as audio, text, filters, transitions, overlays, elements
- Export different video (MP4, AVI, WMV, MKV, MOV, GIF) or audio (MP3 and AAC) formats
How to convert .3GP to MP4 file free with easy clicks
- Free download, launch DVDFab Video Converter Pro, and choose Video Editor module
- Load 3GP video and customize MP4 output via editing tools and creative effects
As long as you choose Premium Quality (for membership), you can convert 3GP to MP4 in 1080p for better playback. But this upscaled feature still fades next to the above-mentioned AI upscaling program.
Sometimes you might wonder the best site to watch anime, download your favorite part, make further editing, and finally upload on your social platforms, thus engaing audience or increasing viewers. This will be a nice choice to kill time and entertain your followers on YouTube or Facebook.
VLC Media Player
VLC Media Player is one of the best free media players in the world because it plays almost all video and audio formats. Apart from this, it has different features that you don’t even get in many premium software.
Features of VLC Media Player
- A free 3GP to MP4 Converter which additionally converts other video and audio files to another as well
- Renowned for playing almost all audio and video formats
- Many adjustments and effects for the videos which enhance your video watching experience
- Take screenshots of the video playing is also possible when you use it
- Set the playing video as your desktop background
- Stream online videos with its inbuilt feature
Video.online-convert.com
This is an online tool to convert 3GP to MP4 free. However, you might think this tool is a bit slow because when you select the file, it first gets uploaded to its server, and then gets converted. So, the uploading time will be your waiting time.
But, that is all fine since it is free and converts 3GP to MP4 without degrading the quality. It offers many options that you can change for the output file. But, they are optional. If you want changes, you can do otherwise leave them. Just upload and convert.
Features of this 3GP to MP4 Converter Online App
- Convert 3GP to MP4 online without the need of a desktop software program
- Apart from 3GP to MP4, it converts various media files to another as well
- Completely free
Cloudconvert.com
This is another online tool that offers convert anything to anything. It does convert 3GP to MP4 media format as well. All you have to do is to visit the website, then click select file then select the output format from the drop-down and convert.
Features of CloudConvert - Convert 3GP to MP4 Online Free
- Apart from converting 3Gp to MP4, it supports 218 formats for conversion
- No need of installing the Desktop software since it converts the file in the cloud
- Upload the source file quickly
- Offer API so that you can integrate it into your application
Handbrake
Handbrake is an open source 3GP converter tool to convert 3GP to MP4 free. The software works well, and it is nowhere less than a premium converter software tool.
Features of Handbrake – Free 3GP to MP4 Converter
- Select title, chapter and range options while conversion
- Offer chapter markers
- No quality degrades in the output file after conversion
- Support for CFR and VFR
- Entirely free 3GP to MP4 converter software
Converting media file formats is one of necessary things because many times you get some files that can’t be played on your existing video player. These above-mentioned free 3GP to MP4 converters are currently the best ones in the business.
Moreover, the most robust tool is DVDFab Video Converter Pro which we have mentioned as the first 3GP to MP4 converter software on this list. This is the best because it has many good features that you can use while converting 3GP to MP4 free. Also, there is no degrading in the quality even a bit. However, it is up to you to as which to choose from the best 3GP to MP4 converter software on the list.
