A quick and simple solution is creating a copy of DVDs and saving it on your computer digitally as a backup. This can be done using free DVDCloner tools. Before we move on to discuss the top 6 free DVD copy tools, you must be aware that copying a DVD for commercial reasons is against the law in many nations. Hence, we advise you to go through the Copyright Law first and just copy the DVD for your personal use without copyright protection.
6 Best DVD Cloner Free Tools for Mac & Windows
1. DVDFab DVD Copy [Best Free DVDcloner]
DVDFab DVD Copy
DVDFab DVD Copy
DVDFab DVD Copy is the ultimate DVD cloner tool that one can lossless backup or compress any DVD, and output to blank disc or save as ISO/Folder on HDD.
Features:
  • Automatic detection and eradication of the most recent DVD copy protection.
  • 1:1 Copy DVD-9 to DVD-9 and DVD-5 to DVD-5.
  • Copy DVD to blank disc or as ISO/Folder for playback.
  • Copy any DVD in batch at lightning-fast speed.
  • Offer 6 copy modes: Full Disc, Main Movie, Customize, Clone/Burn, Split, Merge.
  • Support customizable options and batch copying at lightning speed.
  • Remove Cinavia and copy DVD as clean audio.
Win Download
100% safe&clean
Mac Download
100% safe&clean
Supported OS: Windows 11/10/8.1/8/7 and MacOS 10.10-14
Pros:
  • Smooth and simple copying process.
  • A clean interface makes copying disk content a speedy job.
  • It can clone all types of discs even those with protection.
  • It is quick and accurate in copying all kinds of discs.
Cons:
  • The free version - DVDFab HD Decrypter has limited functions, including decrypt DVD/Blu-rays released one year ago, copy DVD/Blu-ray under Full Disc and Main Movie mode, and rip DVD/Blu-rays to MKV or MP4 formats only.
How to use DVDFab free DVDCloner to clone a DVD:
Step 1: Download and launch DVDFab 13 on your device. Select the Copy module and choose a copy mode as you need. Then, insert your DVD into the optical drive, or navigate to it through the Add button.
DVDFab DVD Copy - Best Free DVDcloner
Step 2: After loading your source file, you can define the volume label and change other copy options, such as picking the specific chapters, audio tracks, and subtitles that you want to clone.
Step 3: Finally, choose blank disc/ISO file/folder as your output directory. Once done, click the Start option. You can cancel the process at any time.
2. DVD-Cloner
DVD-Cloner is one of the best DVDCloner free tools. It also provides features such as 4K copying, DVD burning, and 6 copying modes, and comes with great decrypting features. In addition to this, it is clear that DVD-Cloner makes sure that you get the best experience using their tool. Users have sufficient features to keep you going, these features are not sufficient for pro uses.
The express mode is the highlight of the tool. It lets the user make copies of their discs without any hassle. The procedure is easy, and simple to use. The 6 copying modes that the tool offers are also exceptional, and lets you to easily select what you need. Coming to the six copying modes, they are also the biggest drawbacks of the tool as anybody without the required information about this tool can get confused easily.
dvdcloner free: DVD-Cloner
Supported OS: Windows 7/10 - Mac OS:10.10 or later versions
Pros:
  • Copying DVDs is a simple process.
  • Support various types of DVD formats, including DVD-5, DVD-9, DVD-R/RW, etc.
  • Offer an intuitive and easy-to-use interface.
  • DVD-Cloner provides customization features.
Cons:
  • Unable to copy or clone copy-protected DVD/Blu-rays
  • Copying modes are confusing for new users.
  • Lack of frequent updates.
  • Does not offer advanced features like video editing or disc authoring.
3. Ashampoo Burning Studio Free
Ashampoo Burning Studio Free comes with different features such as 3-in-1 functionality and the ability to create password-protected backups. In addition to this, it is a great tool for music lovers. When it comes to features, users get all the modern functions that they can expect from a good DVD cloning tool. This tool has a 3-in-1 feature where users can burn the DVDs, copy them, as well as rip them.
Making the entire process super simple and very easy as well. Each feature that users might want to use is right there, which indicates that this tool does not have complicated menus. Also, using it is super easy. Truly speaking, with all the good things at one side, the only drawback about this tool is the fact that it does not offer you as many disc compression features as you might expect from it.
dvdcloner free: Ashampoo Burning Studio Free
Supported OS: Windows 10/11
Pros:
  • Support a wide range of disc formats (CD/DVD/Blu-ray) and supports various file formats.
  • Offer additional features such as creating disc images and erasing rewritable discs.
  • Support burning data discs, audio discs and video discs.
  • Works as the best ISO burner and no convoluted menus.
Cons:
  • It lacks some advanced functionalities.
  • It can not handle newly-released commercial DVDs.
  • The free version often displays promotional pop-ups for their paid products.
4. IQmango DVD Copy
The next DVD cloner tool in our list is IQmango DVD Ripper. In addition to rip DVD, users can also copy DVDs as well without any problem. There are some nice features offered by this tool such as ripping DVDs without any issue, DVD copying and ripping, and tons of customization options. The best feature is that it is very easy to use, and copying is very simple.
The interface is old-fashioned. If the minor problem do not concern you, then this tool is a great option that you must surely look into if you wish to have a good experience while DVD copying.
dvdcloner free: IQmango DVD Copy
Supported OS: Windows 8/7, Windows XP Windows Vista, Windows 2003
Pros:
  • 1:1 copy DVD to a blank DVD disc or folder.
  • Users can adjust the audio, video, and subtitle settings.
  • Rip DVD to video files in DIVX AVI and MP4 formats.
Cons:
  • Unable to clone DVDs with protection mechanisms.
  • Only DIVX AVI and MP4 formats can be converted from DVDs.
  • The interface is outdated.
  • Systems newer than Windows 8 are incompatible with it.
5. 123CopyDVD
123CpoyDVD is a DVD cloner program that allows users to make copies of DVDs, convert DVD content into different formats, and create backups of their DVD collections. It provides tools for ripping, burning, and editing DVD content, as well as the ability to transfer movies to portable devices. The software aims to provide an all-in-one solution for DVD copying and conversion needs.
dvdcloner free: 123CopyDVD
Supported OS: Windows 10/8/7/XP/Vista
Pros:
  • 1:1 DVD copy of any DVDs to DVD+-RW.
  • Copy, backup and burn any DVD disc.
  • Archiving crucial documents, videos, and images onto other discs and DVDs.
Cons:
  • The program doesn't have a help option.
  • The program can't clone copy-protected DVDs.
  • The Blu-ray feature needs you to pay more.
6. WinX DVD Copy Pro
WinX DVD Copy Pro is another excellent DVD cloner on this list. It comes with different features such as 9 DVD backup schemes, 1:1 copying, and support for almost every disc type. As far as the questions remain about features, the tool is good at it.
It lets you efficiently copy DVD to DVD disc, MPEG2 at 1:1 ratio, ISO image, along with options to extract audio tracks and video and burn ISO image to DVD disc. In addition to this, you get absolutely no loss in quality. The tool is a perfect option to back up your scratched and old DVD discs, offering your collection a new lease of life.
dvdcloner free: WinX DVD Copy Pro
Supported OS: Windows 11/10/8/8.1/7, Windows Vista, Windows XP, Windows 2003, Windows 2000
Pros:
  • Maintain the original DVD video and audio quality during the copying process.
  • Use advanced technology to ensure efficient and speedy DVD copying.
  • 1:1 copying means your data is always there.
  • Offer various DVD copying modes, such as full disc backup and main title copy.
Cons:
  • Only available for Windows users.
  • Lack of advanced editing options.
  • No DVD compression function.
FAQs about Free DVD Cloner
How do I clone a DVD disc?
To copy a DVD, the process involves transforming the content of the DVD into a digital file and subsequently recording that data onto a blank DVD. To accomplish this task, you will require the original DVD, a fresh disc, a reliable DVD copy software, and a computer equipped with a DVD player.
How can you select good DVD cloning software?
The best DVD cloning tool allows you easily copy any Blu-ray or DVD to any format you wish for. On the other hand, this is not the only thing to look out for when buying a good ripper. Following are the essential factors that a good DVD cloner must have:
  • The tool must back up any encrypted DVDs, including recent and older ones, and get rid of copy protection from the DVD.
  • It must let you convert video files between many formats easily.
  • It must help you to convert DVD files speedily.
  • It must come at a reasonable cost with a free trial option.
  • A DVD cloner must assist you to convert web videos with some video editing features.
  • DVD cloner tool must also offer rich features such as burning videos to DVD as well as to MP4, MP3, WAV, and other formats.
Can copying damage the physical DVD?
No, copying never erases the content the physical DVD contains or damages it. It just reads and saves encrypted data from a DVD and changes it to copy on a home computer.
This article talks about the best DVDCloner in the market, shows you how to copy DVD to hard drive and offers pros and cons of them to make your decision smoother. From the list mentioned above, clearly, DVDFab DVD Copy software is the ultimate tool that one can have to suffice their DVD cloning needs.
