How to Transfer 8mm Film to DVD: Popular Options in 2025
Summary: This guide provides you with the best way to convert 8mm to DVD. Therefore, keep reading to find the best methods to transfer 8mm film to DVD and watch movies from the 1960s and 1970s without hassle.
Introduction
In the 1960s and 1970s, home-recorded movies were recorded on 8mm film. Later, with technological improvements, 8mm films were replaced by 8mm tapes. Do you have tapes of old and classic home-recorded videos and want to preserve them on DVD? If you wish to transfer 8mm to DVD, this article is for you!
Here, we will help you explore the ways and popular transfer services to convert 8mm film to DVD and store them in a more compact format for straightforward enjoyment. You can convert any film to DVD and enjoy it with your loved ones at your convenience.
Best Method to Convert 8mm to DVD
When you have an 8mm film, you can automatically digitize it in high quality using a trusted solution like Wolverine 8mm & Super 8 Reels to Digital MovieMaker Pro. This fully automated apparatus digitizes 8 and Super 8 movie reels frame-by-frame for high-quality conversion. As it is a standalone machine, you do not require any computer, software, or drivers. Simply scan and directly save digital movies onto your SD cards and convert your 8mm film reels into 1080p MJPEG-4 (MP4) digital video files.
Step 1: Convert 8mm to SD Card with Wolverine MovieMaker
For a seamless conversion, the first step is to load your film onto the Wolverine 8mm and Super 8 Reels to Digital MovieMaker Pro. It will auto-start digitizing your film reel and save your file on your 32GB SD card.
Once you get your digital video in high-quality 1080p full HD in MP4 format, you can proceed to convert MP4 to DVD using powerful DVD Creator software.
Step 2: Use DVDFab DVD Creator to Get Digital File on DVD
DVDFab DVD Creator is a robust and versatile solution for converting 8mm to DVD without any technical expertise or hassle. Using it, you can easily convert 8mm files to DVD on your Windows computer. You can also easily create high-quality DVDs from any video format for a better viewing experience. You can input multiple formats and output them to create DVD discs, ISO files, and folders.
- Makes high-quality DVDs from over 200 video format
- Burn videos to DVD blank disc or save them as ISO files and folders
- Personalize DVD movies via free menu templates
- It offers a built-in menu library with stylish templates and updates regularly
- Enables you to customize menu templates with your own style
How to Convert 8mm to DVD with DVDFab DVD Creator
Step 1: Load your MP4 file (available on SD Memory Card) on your computer.
Step 2: Download and open DVDFab 13 on your system to transfer the digital file onto a DVD.
Step 3: Choose the Creator module and load the video source. You can even drag your video and drop it onto the main user interface.
Step 4: The main UI will now display the video's input and output details. You can choose audio tracks and subtitles or add external subtitles to your video.
Step 5: Move to Advanced Settings to select the size of the output DVD, Menu Properties, Aspect Ratio, and Playback Mode. The Menu Setting option helps you create a personalized DVD menu for better playback control.
Step 6: Load a blank DVD disc on your computer. You can save the output file as an ISO file or folder if you do not have a blank DVD. Finally, touch the Start button to convert 8mm to DVD.
Convert 8mm to DVD with Expert Transfer Services
Besides using 8mm & Super 8 Reels to Digital MovieMaker Pro, you can also use Transfer Service and other popular converters to convert 8mm film to DVD. Let's check.
Leave a Legacy Transfer Service
Leave A Legacy Company developed the 8 mm film transfer service in 1932 for home movie enthusiasts. The 8mm film was created as a cheaper option for capturing and retaining fond memories.
Key Features:
- Scans every individual film frame through a frame-by-frame transfer process
- Offers a range of options to transfer your video
- Takes digitized footage as uncompressed files on the hard drive
- It helps to edit your video in-studio or on a home computer
- Easily handles various film formats
Price: Starts at $10
High Def. 8mm transfer (cleaned) | USD 0.50/ft |
Standard Def. transfer | USD 0.25/ft |
Every Frame File | USD 22 |
Save files to a 1TB external hard drive | USD 80 |
Just8mm Transfer Service
Just8mm transfer service specializes in transferring 8mm and Super 8 films to DVD and digital to capture and retain memories smoothly. It can convert your files to digital formats on DVDs and USB hard drives and digital download files on private cloud backup.
Key Features :
- Most accurate replication of motion, color, and clarity for uncompromised quality
- It easily handles and repairs moldy and damaged reels
- Converts 8mm and Super 8 to DVDs and digital format to preserve special moments from the movie
- Converts 8mm films to digital formats on USB hard drive, DVD, and digital download files on private cloud backup
- Allows 2K high-definition transfers with sound capture on rare reels, syncing magnetic and optical sound
Price: Starts at $19.99 for the first DVD or USB regardless of size
Footage | Diameter | Price |
50 ft. | 3 inch reels | USD 12.99 |
100 ft. | 4 inch reels | USD 18.99 |
200 ft. | 5 inch reels | USD 29.99 |
300 ft. | 6 inch reels | USD 39.99 |
400 ft. | 7 inch reels | USD 49.99 |
Popular 8mm Tape to DVD Converters
When you need to convert 8mm film to DVD near me, you can pick any popular tape-to-DVD converters to watch your recorded home movies in the 1960s and 1970s. Other renowned 8mm tape to DVD converters include:
1. KODAK REELS 8mm & Super 8 Films Digitizer Converter
Price: USD 399.99
The Kodak Reels Digitizer seamlessly converts motion pictures into MP4 files. It can share and save on SD cards for 3" 4", 5", 7", and 9" reels.
Key Features:
- Brings old 8mm and super 8mm films into the state-of-the-art
- Offers frame-by-frame digitizing process
- Equipped with supersized screen and touch buttons
- Ultra compact for travel and storage
- Includes the necessary accessories to record and save film with a convenient device
2. ClearClick Video to Digital Converter 2.0 (Second Generation)
Price: USD 159.95
ClearClick Video to Digital Converter 2.0 is a second-generation converter that converts your old video and audio sources, such as cassette tapes and vinyl records, to digital format at the click of a button.
Key Features:
- Converts your old video and audio sources
- Records and digitizes videos and audio from camcorders, DVD players, VCRs, Hi8, etc.
- It does not require software or a computer
- Records audio and video directly onto a MicroSD card or USB Flash Drive
- Records videos in HD quality and MP4 format
3. Roxio Easy VHS to DVD 3 Plus | VHS, Hi8, V8 Video to DVD or Digital Converter
Price: USD 39.99
Roxio easy VHS to DVD can easily convert 8mm to DVD or digital to improve and retain your favorite movies. You can easily capture analog video from your camcorder and burn it to DVD.
Key Features
- Converts VHS tapes to DVD and digital formats
- Enables recording videos directly using a VCR or camcorder
- Quickly edits and trim videos
- Enhance colors, reduce noise, and add transitions
- Offers creative, selective, and customizable DVD menu templates
4. Wolverine TransMedia- Home Movies Digitizer Scanner and Converter
Price: USD 199.00
Wolverine TransMedia is another fantastic converter that can convert and transfer 8mm to DVD without hassle. It also allows you to copy all your music CD collections into MP3 and WAV files on SD cards and USB Flash Drives.
Key Features:
- Offers several recording options
- Converts AV-in camcorder and VCR to DVD
- Converts DVDs or CDs to SD cards or Flash Drives and Hard Drive
- Uses USB and HDMI connectivity technology
- Works even on Windows 7
Many 8mm to DVD converters are available to help you convert your tape to DVD discs. You can use LegacyBox or Kodak Digitizing Box's disc transfer services to convert your film to DVD or a digital download format. You can also use free DVD burning software to convert your video to DVD discs and ISO files or folders.
While a camcorder is the best way to transfer 8mm to DVD, you may get stuck when you don't have an 8mm or Hi8 camcorder. Here are a few options to try.
1. Temporarily borrow a Hi8/8mm camcorder from a friend or other loved ones. This is definitely a free option.
2. To play the tapes, purchase a cheaper Hi8/Digital camcorder or MiniDV camcorder. Second-hand or refurbished units are available on Amazon or eBay.
3. Take your tapes to a video duplicator, who will professionally transfer them to a DVD. However, this option is a bit expensive.
The Bottom Line
Many 8mm film to DVD converters are available in the digital market. However, choosing the right one can be challenging as each program has a different output DVD disc. You must focus on factors like conversion speed, input and output formats, output quality, menu templates, price, and ease of use. Ensure your chosen software has rich features, technical support, and customization options to create your desired DVD content. Feel free to use DVD Creator, which syncs seamlessly with your needs and matches your preferred criteria.
