How to Rip Audio from DVD with the Best DVD Audio Extractors?
Summary: This guide explores how to rip audio from DVDs with the help of the popular and free DVD audio extractors. Whether you're an audiophile or want to enjoy your favorite movie soundtracks, this guide has everything you need to know about ripping audio from DVD.
Extract audio from encrypted DVDs, ISO files or Folders.
Output lossless audio, such as 5.1 AC3, MP3, WMA, AAC, M4A, FLAC, OGG, etc.
Enjoy DVD audio on mobile devices, media players, or home theaters.
Offer a built-in video editor to customize your DVD audio.
With the trend shifting to the digital world, physical media is becoming obsolete. If you have a stack full of DVDs having your favorite content and want to convert the content into digital format, then you have to take the aid of the best DVD ripper for Mac or Windows.
On top of this, the ripper software allows you to rip audio from DVD. That means you can enhance the audio quality and make custom adjustments with the DVD audio extractor tool. So, let us dive into the list of top software that simplifies the process of extracting audio from DVDs.
Top 5 DVD Audio Extractors to Rip Audio from DVD
When it comes to ripping audio from DVD, you absolutely need professional tools that works in minutes to converting DVD to one of the mainstream audio formats that can be played on mobile device or saved on HDD or onto cloud storage services. Below are the top desktop and online DVD audio rippers.
DVDFab DVD Ripper (Full-featured DVD Audio Extractor)
DVDFab DVD Ripping software is recommended as one of the best DVD audio rippers available on both Windows and Mac. It can rip any copy-protected DVDs, ISO image files or folder into various audio or video formats at blazing fast speed and stunning quality, such as MP3, MP4, FLAC, M4A, WMA, WAV, AAC, DTS, OGG, PCM and AC-3/E-AC-3 5.1, and more, with support for up to 7.1 channels. This powerful software offers ultra-fast processing speed without compromising the impeccable quality of the output.
Moreover, for the discerning audiophile, DVDFab DVD Ripper takes the experience a notch higher by enabling the extraction of Hi-fi audio from DVDs, including formats like Flac Multi-channel, Flac Stereo, Way Multi-channel, and Way Stereo. With its user-friendly interface, it allows you to not only extract audio but also customize it to your preferences, rendering a bespoke DVD audio experience truly tailored to your liking.
💻Available on:
👍Highlighted Features:
- DVDFab's exclusive Cloud Decryption Service makes it the only tool that can decrypt the newest-released encrypted discs quickly and automatically.
- Rips audios/videos from DVD of 1000 formats playable on any device.
- Rip DVDs to lossless Hi-Fi audio with 24-bit detailing and up to 192 kHz for high-definition output.
- Fast and batch DVD audio conversion achieved by GPU hardware acceleration and multi-core CPU.
- Advanced settings and a built-in video editor are applied to customizing output audio, such as trimming and speeding up and down DVD audio, enhancing human voice, and removing background noise.
How to Rip Audio from DVD with DVDFab DVD Ripper?
Step 1: Run DVDFab DVD Ripper and load source DVDs
Download and install this free DVD Ripper (integrated into DVDFab 13), and opt for 'Ripper' module when the program runs. Then insert DVD disc into the optical drive on PC or navigate ISO file or DVD folder from HDD through '+Add' button, or simply drag & drop it onto the main UI.
Step 2: Select one audio profile and customize output audio
Click "Choose Other Profile - Format - Audio" to select your desired audio profile from the profile library. You can rip audio from DVD to MP3, AAC, AC3, m4a, DTS and more. If you want to get lossless Hi-fi audio, just click "Hi-Fi Audio" button to choose a audio profile as you like.
Then tab "Advanced Settings" to set audio parameters such as codec, sample rate, channels, bit rate and volume. Besides, you can choose to split chapters to rip.
Tip: When you choose an audio output format, the option "Video Edit" will not appear on the interface. Therefore, if you wish to edit your DVD audio before ripping, you should firstly select a video format. Afterward, click on the "Video Edit" option to customize and fine-tune your DVD audio.
Step 3: Start to rip audio from DVD
Set file directory to save the output audio on HDD. Once done, tab 'Start' button to wait for the ripping process and check the real-time progress. You can cancel the task of extracting audio from DVD anytime as you want to, set PC to automatically shut down, exit program, hibernate or do nothing when the task is done. More importantly, 'GPU Hardware Acceleration' will speed up the whole conversion.
The above-mentioned steps are how to rip audio from DVD fast and well. In a nutshell, this free DVD Ripper has the ability to rip audio from DVD that can be playable on all devices such as smartphones, tablets, game consoles, 3D devices and TV boxes. You can playback the converted audio whenever and wherever possible.
VLC (Open-source DVD Audio Extractor)
VLC Media Player, a cross-platform and versatile software tool, is widely used for playing various types of multimedia files. Aside from its playback capabilities, a less-known yet significant function of VLC is its ability to rip audio from DVDs. Its support for DVD input and audio output enables users to extract and save audio from DVDs as MP3, OGG, or other formats, making VLC a free DVD audio extractor for both Mac and Windows platforms.
In addition to audio ripping, VLC also serves as a media player, converter, and a recorder. It offers the option to convert DVDs into a range of video and audio formats. However, it should be noted that VLC is unable to decode DVDs with copy protection, and may not be user-friendly for first-time users. There is also no advanced audio/video editor for you to customize and edit your DVD audio.
💻Available on: Windows, Linux, & macOS
How to Extract Audio from DVD with VLC Media Player?
Step 1: Open VLC Media Player on your computer. If you don't have it, you can download it from the official website.
Step 2: Go to the "Media" menu at the top left corner of VLC Player. Select "Convert / Save" from the drop down menu.
Step 3: In the "Open Media" dialog box, go to the "Disc" tab where you can choose "DVD", "Blu-ray" or "Audio CD".
Step 4: Check the "No disc menu" option and set the "Starting Position" to 1. Then select the "Convert / Save" button at the bottom.
Step 5: In the "Convert" dialog box, choose the "Profile" drop down and select an audio format such as "MP3" or "FLAC".
Step 6: Under "Destination", click the "Browse" button to select a location on your computer where you want to save the ripped audio file. Finally click on the "Start" button to begin the DVD audio ripping process.
HandBrake (Free DVD Audio Extractor)
HandBrake is a free and open-source audio extractor that allows you to complete the process of ripping DVD or ISO to MKV, MP4 and other formats easily. The tool supports several predefined samples that speed up the ripping process. You can customize every process according to your preference too. You can extract audio from video Mac, Linux, and Windows OS.
- Different predefined samples is quite helpful
- It is free and support batch conversion
- Provides a very user-friendly interface
- Does not support DRM
- Not all video formats are supported
- There are blunders along the convertion process
How to rip audio from DVD with HandBrake?
Step 1: Download and Install HandBrake. Then insert the DVD into your computer's DVD drive.
Step 2: Select the DVD drive that contains the DVD you want to rip. You can configure various audio settings, such as the audio codec, sample rate, bitrate, and channels.
Step 3: You can configure various audio settings, such as the audio codec, sample rate, bitrate, and channels.
Step 4: Choose a destination folder for the ripped audio file by clicking on the “Browse” button under the “Destination” section. Click on the “Start” button to begin the ripping process.
ZAMZAR (Online DVD Audio Converter)
ZAMZAR is a online DVD audio converter that allows you extract audio from VOB videos in DVD folder to music formats like MP3, AAC, M4A etc. without downloading any software. Moreover, it also supports over 1200 different conversions including video, audio, document, image and more. This is a cloud-ready platform, hence, converted audio files are directly stored in the cloud. You have to upload and download them once the actual conversion is over.
Nevertheless, this program actually cannot rip physical DVDs. It also fails to rip audio from DVDs if the source VOB file is password-protected or restricted by DRM (Digital Rights Management). Meanwhile, its free version has limited features. For example, a converted file shall not exceed 150 MB.
How to Rip Audio from DVD with ZAMZAR?
Step 1: Open your browser and go to ZAMZAR's website: www.zamzar.com.
Step 2: Select the "Convert Files" tab if it's not already selected.
Step 3: Click on "Add Files..." to upload the DVD VOB files you wish to rip. Browse your file system to select files from your DVD folder.
Step 4: In the dropdown menu for "Convert To", select the audio format you wish to save the audio in. For example, you can choose MP3 or WAV among many other audio formats.
Step 5: Click "Convert Now" to start ripping the audio from the DVD. Wait while the conversion process occurs. The length of time this takes will depend on the size of the file and the speed of your internet connection.
Step 6: Once the conversion process is complete, the website will redirect you to the download page. Here, you can download your ripped audio file by clicking on the "Download" button.
These are three recommended DVD audio extractors in different usage scenarios. What to choose depends on your personal use and actual need.
WonderFox DVD Ripper Pro
WonderFox DVD Ripper is a comprehensive tool that offers numerous functionalities, including the ability to extract audio tracks from DVDs. It allows users to convert DVD content into various audio formats such as MP3, FLAC, WAV, AAC, and more. The extracted audio can then be enjoyed on various devices such as smartphones, tablets, MP3 players, or used for other audio-related purposes. It not only ensures high-quality audio extraction but also provides customizable settings for users to adjust audio parameters according to their preferences. This allows users to tailor the output audio quality based on their specific needs.
- Supports all kinds of audio as output formats
- Excellent customization tool for editing
- Easy removal of encrypted DVDs with high quality
- Support Windows operating system only
- Only the pro version offers superior functions
- Provide a misleading assessment of the remaining duration
How to Rip Audio from DVD with WonderFox DVD Ripper?
Step 1: Start by downloading and installing WonderFox DVD Audio Extractor from the official website.
Step 2: Insert the DVD into your computer's DVD drive. After launching the program, click on the “DVD Disc” button to select the DVD source you want to rip the audio from.
Step 3: Click on the Output Format button to choose the audio format you want to convert to. Also, select the output folder where you want the ripped audio files to be saved.
Step 4: You can modify parameters like bitrate, sample rate, audio channel, and more by clicking on the Settings button.
Step 5: After setting up all the options, click on the “Run” button to start ripping the audio from the DVD.
The audio that comes out of a DVD is typically a digital audio signal that has been compressed and encoded. This audio can be stereo (2 channel) or surround sound (multiple channels) and can include different formats such as Dolby Digital or DTS. The specific format and quality of the audio depends on the DVD specifications and the movie or content that is on the DVD.
No, Handbrake cannot directly extract audio from DVDs. But it can only rip DVDs to MP4, MKV, or WebM formats. You can then extract audio from these files using other transcoders like VLC.
FLAC is an audio coding format for lossless compression of digital audio. If you want to convert DVD to FLAC, you can use DVDFab DVD Ripper which supports ripping lossless Hi-Fi audios form DVD.
- Step 1: Download DVDFab DVD Ripper, install and launch the software.
- Step 2: Insert the DVD disc that you want to rip. DVDFab will load it automatically.
- Step 3: Click "Choose Other Profile" to choose FLAC as the output format.
- Step 4: Next, select the audio tracks you want to keep, and adjust the audio settings.
- Step 5: Click the "folder" icon at the bottom to select a directory to save the output FLAC files.
- Step 6: Click the "Start" button to start the ripping process. You will be able to see the progress.
Now you have understood what to choose from an ocean of DVD Audio Extractors to rip audio from DVD with fast speed and nice quality. Anyway, if you are unhappy with the quality of converted audio, you can edit audio with professional audio editing tool, DVDFab Toolkit.
