DVD Shrink & Its Best Alternative You Shall Never Miss
Summary: DVD Shrink is out-of-date and unsafe software. Not being compatible with Windows 10 and Mac creates a problem for many, but don't worry, we have brought you the best-ever DVD Shrink alternative. Stick around till the end to find out the optimal solution to resolve the incompatibility issue.
- • Copy DVD to disc (DVD+R/RW, DVD-R/RW, DVD+R DL, DVD-R DL)
- • Copy DVD to ISO on Windows or Mac
- • Copy DVD to folder saved on HDD or Media Player
- • Work at top speed without quality loss
- • Capable of removing Cinavia together with Cinavia Removal
Have you tried DVD shrink? Do you wish to find a better DVD shrinking alternative? If you have software to download videos and save files as backups on your system for free, this must be shocking. DVD Shrink, the free software for backing up files, meets your needs with its updated version.
Most importantly, most people are fond of entertaining movies and videos to kill time when in transit or on travel. DVD Shrink downloads those videos and reduces their data in half, and results in ISO files, which lays a foundation for smooth playback on different devices. Continue reading to learn how to download videos in your system with a backup using DVD Shrink Download version 3.2 for Windows.
Part 1. DVD Shrink: What You Need to Know
DVD Shrink is free software to backup DVD discs, a DVD transcoder for Microsoft Windows. It is an alternative to the system backup that you can download for Windows 10. DVD Shrink is available for Macintosh by copy-compress setting. It reduces the data to download in a single layer DVD of 4.3 GB.
The DVD Shrink uses a DVD ripper to back up the videos on your system. DVD Shrink object’s name hints that it is the amount of data to DVD with shallow loss of quality. However, some loss of quality while downloading for free is inevitable due to the lossy MPEG-2 compression algorithm.
What Is DVD Shrink Used for? - Pros and Cons
As it is free, you will surely rush to buy it and enjoy the video. DVD Shrink helps download videos in your backup system that will save files, but it may affect the minimal quality of the video.
Just because Windows 10 doesn’t support DVD Shrink, it will need compatibility mode for Windows XP.
Pros:
- DVD Shrink Windows 10 is free, available in updated version 3.
- Through DVD Shrink, we can download the video and resulting ISO file in a backup of the system.
- DVD Shrink can be Copied-Compressed to use for Windows and Macintosh.
- DVD shrinks reduce the data in half to a burnt DVD.
Cons:
- DVD Shrink for Windows 10 isn’t supported unless it has any compatibility Mode for Windows XP.
- DVD Shrink Windows 10 isn’t available; you can copy-compress from any application.
- Loss of the quality of the video.
Is DVD Shrink Still Available?
Yes, DVD Shrink is available in the 3.2.0.15 version for Windows. However, it doesn't support Windows 10 and isn't available for Mac, either. Thus, those looking for DVD Shrink for Macintosh and Windows 10 need to blaze a new trial.
Is DVD Shrink Safe and Free?
Certainly, DVD Shrink is safe and free, and you can download videos for free.
It is secure software, but people are creating its copies. This doesn’t ensure the safety of the documents. They can have malware that can affect your system with viruses. DVD Shrink is safe and accessible only when it is original.
Be aware of copies because they are of no use instead of evil for the system. Another reason for usefulness can be your antivirus seeing it as malware and doesn't want to work with it.
Does DVD Shrink Remove Copy Protection?
Of course, DVD Shrink can serve as a DVD decrypter that removes copy protections that the users most demand. Also, DVD Shrink removes protection from data such as CSS, RC, RCE, etc. Although DVD Shrink removes copy protection and processes the video into DVD, the users can compensate for the loss of video quality and ignore useless content. Because the user has it for free so he must ignore some.
Anyway, if you want to remove DVD copy protection completely and thoroughly, you can turn to other professional alternatives like DVDFab Passkey for DVD.
Is DVD Shrink for Macintosh Available?
Unfortunately, it is sad for Mac users. No one has introduced DVD Shrink for Macintosh. However, you can download it from other applications. Mac users also have the right to enjoy the copy, backup, encrypt, compress, or re-author DVDs containing videos.
All for ease of Mac users, we have found a process of the DVD Shrink for Macintosh – Copy and Compress DVDs on Mac.
Here are some steps that you can copy and get compressed DVDs on Mac:
- Download DVD Shrink for Macintosh, then run the program. You can run DVD for Mac.
- Upload the DVD Movie. Before the copy-compress step up, the DVD movie has to load.
- Copy/Compress Setup and step.
- Run to Copy/Compress.
Many companies are still working to introduce DVD Shrink for Macintosh.
Part 2. Tips for Using DVD Shrink for Windows
DVD Shrink Download
DVD Shrink is available in 3.2.0.15 for Windows in the download version. If you want to try DVD Shrink download, you are strongly suggested to download DVD Shrink from its official site. Otherwise, your system may suffer from viruses or malware if you download DVD Shrink from other pirated sites.
Anyway, to download DVD Shrink from its website, you need to tolerate the pop-up business ads, since DVD Shrink charges nothing for free download but it still keeps running via cooperation on ads with third-party businesses.
User Tips
- Open DVD with DVD Shrink. Press the "Open Disc" button on the top, choose the DVD, Drive the disk you place it in, and click "OK."
- Fix the compression ratio and choose the audio track of your choice.
- Start to backup downloaded movies with DVD Shrink.
Part 3. Best DVD Shrink Alternative: DVDFab DVD Copy
DVDFab DVD Copy is the best DVD Shrink alternative. This best ISO burning software helps you to copy and save DVD files in ISO images or Folders in a backup.
The Greatest Boons DVDFab DVD Copy Boasts
- Remove any copy protection from DVDs, even from the newest DVDs
- Copy DVD to a blank disc or as an ISO file and folder in lossless quality
- Copy DVD via 6 Copy Modes (Full Disc, Main Movie, Clone/Burn, Merge, Split, Customize)
- Copy DVDs in batch at a lightning-fast speed (in 3 minutes)
- Copy DVDs with meta info and .nfo file generation
- Remove Cinavia permanently and copy as clean audio
- Free download, a 30-day full trial
It is often the case that when the video compresses, it introduces minor errors that are not acceptable backup quality. This error is an undeniable consequence of the compressed video. DVD Shrink doesn’t have any solution to improve backup quality and stop it from happening. However, it can decrease these artifacts. If you need to compress a video in DVD shrink, then keep in mind the speed of compression is slow. DVD Shrink speed of contraction can take about 1.5 hours to 2 hours.
However, if you use DVDFab DVD Copy, it will read all kinds of DVDs, including the scratched discs. DVDFab DVD Copy will complete the copy task in 3 minutes (for DVD-5 ISO file) or 5 minutes (for a DVD-9 ISO file). Once you copy a DVD physical disc, the whole copy speed depends on your optical drive quality.
How to Copy DVD in Lossless Quality But Fast Speed
Here is how you can copy DVDs with DVDFab DVD Copy Software.
Step 1: Free download and launch DVDFab DVD Copy.
Step 2: Double click DVDFab 12 to launch the program, and choose the Copy Option when it runs. Load the source DVD by inserting the DVD you wish to back up into the optical drive. You can also click the +Add button, or drag & drop the DVD ISO/folder onto the main UI.
Step 3: After loading the source, click the "Copy Mode" tab to choose a copy mode. Here are Full Disc, Main Movie, Customize, Split, Merge, and Clone. Then we will take the main movie mode as an example.
Step 4: Customize the output DVD. Here you can make advanced settings, choose other titles, and select your preferred chapter, audio tracks, and subtitles to copy. After that, move to the bottom part to choose your output directory and start copying DVD by clicking the Start button.
Of course, if you want to rip DVDs into various digital videos for mobile playback, DVDFab DVD Ripper will come in handy. It works with Enlarger AI to upscale video from 480p to 1080p. When rip Blu-rays, the final output video will be upscaled from 1080p to 4K.
Part 4. Conclusion
DVD Shrink is free and safe software, but unfortunately, it is incompatible with Windows 10 and Mac, which makes it challenging to use for many people. That being said, DVD Shrink for Windows 10 and DVD Shrink for Macintosh is still unrealistic. But never give up. Always trying to find a new way out! Here is the good news: DVDFab DVD Copy is the best DVD Shrink alternative. Wait no more and download it now!
