6 Best Free AnyDVD Alternatives for Decrypting DVDs [2024 Latest]
Summary:With the official RedFox site now offline, products like AnyDVD and CloneDVD have become unavailable to users. Don't worry, this article presents the top 6 best AnyDVD alternatives that are potent, safe, and stable.
Remove all known copy protections from DVD and (4K) Blu-ray
Decrypt, convert, copy, rip and burn DVD/Blu-ray/4K UHD discs
Fast DVD decrypting and ripping speed with GPU acceleration
Add or replace audios and subtitles of Blu-ray and UHD
What Happened to AnyDVD?
June. 2024 Update: RedFox (AnyDVD) Is Down!
Slysoft AnyDVD was forbidden in 2016 due to "recent regulatory requirements" and had to operate under a RedFox AnyDVD license in Belize using a new brand. In such situations, general users must subscribe annually and pay one-time, and RedFox AnyDVD license key holders need to update the old version for continuous use.
However, by June 2024, both the official RedFox website and software such as AnyDVD and CloneDVD were gone. The reasons behind this are still unknown, and users from Reddit said that RedFox AnyDVD might not recover or return from this downtime. Meanwhile, if you still want to bypass DVD copy protection for personal backups, DVDFab is recommended as your reliable AnyDVD alternative.
6 Best & Free AnyDVD Alternatives [Windows/Mac/Linux]
Despite AnyDVD HD being a viable solution for backing up DVD and Blu-ray collections, having an alternative to AnyDVD converter can be beneficial when encountering issues such as website downtime, disc recognition failure, drive disabling, incomplete CSS key cracking, as well as IFOProperties 6 errors during DVD/Blu-ray ripping to hard drive. Of course, there are many best free AnyDVD alternatives for your reference. Follow me to see what they are and the main features of each ripping software.
Top 1: DVDFab [All-around AnyDVD Alternative]
DVDFab is a company with over 20 years of experience developing DVD, Blu-ray and UHD copying, ripping and creation solutions. Therefore, among all the best AnyDVD alternatives, DVDFab ranks first on the competitor list unquestionably.
💡RedFox AnyDVD is only available for DVD/blu-ray decryption, but Ripper module of DVDFab allows you to rip copy-protected DVDs, Blu-rays and UHDs into more than 1000 video or audio formats. The Copy module allows you to backup and compress any disc without losing quality. The Create module enables you to create personalized discs using free menu templates.
- Ripping, copying and creating 2D/3D DVD, BD, UHD disc/folder/ISO.
- Decryption types: RC, RCE, APS, UOPs, ARccOS, RipGuard, Fake Playlist (99 titles), etc.
- Keep timely update to support newly released DVDs, Blu-rays and UHDs.
- Decrypt, copy and rip DVD/Blu-ray/UHD in batches with 50x high speed.
- Rip DVD to iPad, Xbox One, PS4, and other 260+ devices.
- Provide an editing tool used to crop, trim, rotate, speed up/down, adjust color, brightness, and saturation, adder text, image, and subtitles.
Operating Systems:
Top 2: Passkey [Best Stable AnyDVD Alternative]
Similar to AnyDVD, DVDFab Passkey is a disc decryption utility for Windows, making it our second recommended AnyDVD alternative. Passkey All-In-One includes 4 products that support the decryption of commercial DVDs, Blu-ray, 4K Ultra HD Blu-ray, and (4K) BDAV discs.
The interface and operation steps of DVDFab Passkey are as user-friendly as AnyDVD. The whole decryption process takes only three steps. Take advantage of our 30-day free trial and give Passkey a try!
- If you just need to quickly remove copy protection, DVDFab Passkey is enough for you. You can play the decrypted DVD/Blu-ray with any player, and rip it to your hard disc or ISO image.
- However, if you would like to back up BD or rip DVD to your computer, you need a more comprehensive tool like DVDFab All-In-One.
Top 3: MakeMKV [One-format-output AnyDVD Alternative]
When it comes to a DVD ripper or Blu-ray ripping software or the alternative of RedFox AnyDVD crack, MakeMKV is one of the free solutions you cannot miss. It is powerful enough to decrypt AACS and BD+ when ripping Blu-rays, but it is a little risky in law so MakeMKV down. But in general, this AnyDVD alternative has an excellent output format - MKV. It is both its pro and con as well, since it cannot rip DVD or Blu-ray to other formats, and MKV is not playable on most devices.
Operating Systems: Windows XP or later & Mac OS X 10.6 and later & Linux x86 or amd64
Features:
- Compatible with Windows, Mac and Linux.
- Convert DVD or Blu-ray to MKV in lossless quality.
- Decrypt some DVD and BD copy protections, such as AACS/BD+.
- Free and easy to use in beta version.
Cons:
- The output MKV file is very large.
- Unable to rip DVD to MP4, AVI, WMV, MP3, etc.
- Not completely free if you want advanced functions.
Top 4: HandBrake [Open-source AnyDVD Alternative]
HandBrake is an open-source video transcoder, aiming to convert videos from nearly any format to a selected codec that has been widely accepted and supported. Also, you can use HandBrake to rip common and homemade DVDs like what AnyDVD HD could do. What's more, a host of preset settings are available to you to rip DVD to multiple formats including MP4 and MKV easily. However, it is impossible for HandBrake itself to decrypt all those copy-protected DVDs.
Operating Systems: Windows 10 and later & macOS 10.13 and later & Linux
Features:
- Rip all non-protected DVDs and CSS-encrypted DVDs with the assistance of libdvdcss.
- Rip Blu-ray and DVD to MP4 and MKV.
- Offer editing tools like cropper, denoiser, and deinterlacer.
- Batch scan and queueing of encodes.
Cons:
- No support for copyright-protected DVDs/Blu-rays.
- Unable to merge multiple DVD video clips.
- It is complex to use for beginners.
Top 5: Leawo DVD Ripper [Region-code-removal AnyDVD Alternative]
Leawo DVD Ripper is a powerful software alternative to RedFox AnyDVD HD crack. It offers functionality to rip and convert region-coded DVDs to different formats suitable for numerous multimedia devices. It supports over 180 video and audio formats including MP4, MKV, AVI, MOV, and WMV. Users can also select episodes for ripping, add subtitles, and customize video effects. Moreover, it allows users to create 3D movies out of 2D DVD sources.
Operating Systems: Windows 7/8/8.1/10/11 and macOS 10.13/10.14.../13/14
Features:
- Back up homemade and commercial disc/ISO/folder.
- Strip off region restrictions on DVD.
- Rip DVD to MP4, FLV, AVI, MKV, WMV, etc.
- Transfer 2D DVD to 3D.
- Work at a fast speed supported by NVIDIA CUDA.
Cons:
- Can't rip newly-released DVDs/Blu-rays.
- Ripping features are limited in Mac system.
- You can only rip up to five minutes of your disc in trial version.
Top 6: WonderFox DVD Ripper [Region-code-removal AnyDVD Alternative]
WonderFox DVD Ripper Pro is another AnyDVD alternative software that has a powerful DVD decoding algorithm technology. It can not only remove region code restrictions and Disney's X-Project protection, but also convert your DVDs to mainstream video formats. The software can compress DVD (7.5 GB to digital video (1.2 GB) with no loss of video quality. WonderFox can also intelligently detect the themes of DVD movies and TV shows, easily find the right titles and remove unwanted ads, trailers, video clips, and some other useless stuff.
Operating Systems: Windows 11/10/8/7/Vista
Features:
- Convert DVD movies to 300+ video or music formats.
- Convert DVD to video for iPhone, ipad, iPod Touch or Apple TV.
- Advanced users can also adjust the fine conversion parameters.
- You can capture the picture or audio track of DVD movies.
- Support Hyper-Threading technology and multi-core CPU to optimize our conversion process.
Cons:
- It doesn't work on Mac system.
- Unable to handle new-released DVD disc with protection mechanism.
- Some users reported program freezing issues, especially when loading a DVD disc via external USB DVD drive, often necessitating process termination and restart.
How to Rip a Copy-Protected DVD with AnyDVD Alternative
AnyDVD vs DVDFab, who wins? The latter distinguishes itself in every aspect, especially in the safety of decryption. So, I will take DVDFab Ripper as the best AnyDVD alternative now to show you how to convert a protected DVD to digital free and fast, and how to edit your DVD videos. After grasping this skill, you will be able to rip Blu ray and UHD files in the same way easily.
Step 1: Download and install DVDFab Ripper Program
It has no virus, so you can use it reliably. Click 'Free Download' > 'Install' and start this best free AnyDVD alternative on Windows or Mac.
Step 2: Select the 'Ripper' module and load your DVD file(s)
In order to rip DVDs or Blu-rays, just select the second module from the left menu - 'Ripper'. You can insert a DVD disc into your optical drive, or just load your DVDs form your computer.
Step 3: Set the output video format and customize the output video
After loading your source, DVDFab will automatically detect and remove all the DVD protection mechanism. You can check it out by clicking the "Info" button. Then you can select the titles, chapter, audio tracks, and subtitles you want to rip.
Next, click "Choose Other Profile" > "Format" > "Video", and there will pop out lots of video formats. Choose MP4, MKV, AVI, WMV, MOV, MPEG, or other formats compatible with your device.
There are also two video editing tools available: Advanced Settings and Video Edit. Use the former to set video, audio and resolution parameters, and use the latter to crop, trim, rotate and customize your videos in other ways.
Step 4: Start to rip a DVD/BD/UHD with the best AnyDVD alternative
Finally, set the output video directory and click the button 'Start', and then it will just take 3 to 5 minutes to complete each DVD ripping task.
FAQs about RedFox AnyDVD HD
Yes, HandBrake and DVDFab HD Decrypter are totally free alternatives to AnyDVD. HandBrake uses libdvdcss to help you decrypt CSS-encrypted DVDs. DVDFab HD Decrypter is a lifetime-free version of DVDFab DVD Ripper that can convert most encrypted DVDs and Blu-rays released one year ago into MP4 or MKV formats.
Honestly speaking, it is not allowed in the United States to use AnyDVD, AnyDVD HD, or Rexfox AnyDVD to back up any file, because it strips off the technological protection measures. But, Belize sells the AnyDVD converter officially.
In conclusion, while AnyDVD provides a reliable platform for backing up DVD and Blu-ray collections, it also presents several safe challenges. Moreover, it was shut down due to unspecified reasons since June, 2024. Therefore, if you still wish to get a seamless DVD decryption and backup experience, just consider the best free AnyDVD alternatives, like DVDFab DVD Ripping software, that offer additional features and more reliability.
