Top 6 AVI to DVD Converters on Windows and Mac [Free & Paid Included]
Summary: Wondering how to burn AVI file to DVD for enjoying on DVD player and large display? This article highlights the best AVI to DVD converter software available for Windows and Mac users, including both free and paid options.
AVI, short for Audio Video Interleave, is a commonly used file format to store both video and audio data. For playback or storage reason, sometimes you may want to convert your AVI video files to DVDs. At this time, an AVI to DVD burner free is necessary.
A host of AVI to DVD Converters are available in the market, and therefore you may need to try out many different converters to find the best one. To save your time and energy, here we have selected top converters that come with powerful features and that can convert AVI to DVD format for free.
Best AVI to DVD Converter for Windows & Mac
How to Convert AVI to DVD with DVDFab DVD Creator?
Step 1: Download and run DVDFab DVD Creator. Choose the Creator module and go to the mode switcher at the top left corner and choose DVD Creator mode. Then click the “+” to load the AVI video you want to convert.
Step 2: Customize the output disc now. You can configure advanced options, select audio tracks, and add external subtitles. You can also create your own DVD menu via stylish templates.
Step 3: Select to burn the AVI video to a blank disc, or convert it to ISO image/folder. Finally, click the “Start” button to start the process of converting AVI to DVD.
Paid AVI to DVD Converter: AVS Video Converter
AVS Video Converter is another AVI to DVD converter for Windows that not only allows you to convert videos to various formats, but also includes a built-in DVD burning feature. Under the brand of AVS, there are plenty of other programs helpful for video, audio and photo editing. Burning AVI flies to DVDs is just one of the jobs it specializes in.
- Supports a wide range of video formats
- Fast and efficient conversion of videos
- Users can convert multiple videos at once
- This AVI Converter includes basic editing tools
- Limited customization options for output settings
- Occasional crashes or stability issues while using AVS
- The free trial version adds a watermark to converted videos
How to burn AVI file to DVD with AVS Video Converter?
Paid AVI to DVD Converter: Xilisoft DVD Creator
Xilisoft DVD Creator is also a good choice when you need to burn AVI to DVD. This DVD authoring software for Windows and Mac can convert and burn all kinds of HD videos like AVI, MKV, MOV, MTS, etc. taken by iPhone, smart phone and camcorder to DVD easily. In addition to providing diversified DVD templates, it comes with a flexible video editor which can be used to adjust video image size, add subtitles, watermark and audio tracks. With it, you can choose the TV standard as NTSC or PAL, and set the aspect ratio.
- It supports 160+ video formats
- Offers various customization options
- Multi-language support and fast burning speed
- Limited support for Blu-ray
- Lack of advanced DVD menu templates
- Crashes or freezing during the burning process
How to convert AVI to DVD with Xilisoft DVD Creator?
AVI to DVD Free Converter: WinX DVD Author
WinX DVD Author is an open source DVD burning software for Windows that allows users to easily convert AVI to DVD format. Whether you want to burn your favorite movies, home videos, or other content onto a DVD for playback on your TV or computer, it is the perfect solution for your DVD conversion needs. This free DVD maker also supports different video formats such as MP4, WMV, and MOV, making it a versatile solution for all your DVD creation needs.
- It has a fast burning speed
- Supports a variety of input formats
- Allows users to customize DVDs with personalized menus
- Lack of support for Blu-ray
- It is only compatible with Windows 10/11
- Compatibility issues with certain file formats
How to burn AVI to DVD with WinX DVD Author?
AVI to DVD Free Converter: Freemake Video Converter
Another free AVI to DVD converter is Freemake which is compatible with Windows and Mac. Users can create high-quality, professional-looking DVDs for playback on any standard DVD player. It also offers a variety of customization options, making it easy for users to tailor their DVD creations to their specific preferences.
- It supports a wide range of input formats
- It features a simple and intuitive interface
- Offers a variety of customization options for DVD output
- Occasional stability issues
- Lack robust customer support
- The free version come with adware or bundled software
How to convert AVI to DVD with Freemake Video Converter?
Online AVI to DVD Converter: ZamZar
ZamZar is an online website for burning AVI to DVD free. It can be used to burn video files to DVD in addition to converting between various file formats. Moreover, it has a desktop application for file conversion. Almost all the online Converter follows three steps to make dvd from avi. For instance, import your files to ZamZar > Select DVD as the output format from the section of “Video Presets” > Tell your E-mail for the file downloading ahead > Convert AVI to DVD immediately.
Online software has the following advantages and limitations compared to offline AVI to DVD converter.
- Without the need to download any software
- Offers convenience and a wide range of supported file formats
- You can only burn AVI to DVD in limited times.
- You have to disclose your personal information like E-mail
- Users may experience slower conversion times or interruptions
No, you need to convert AVI to DVD first. DVDs created from AVI files should be playable on any standard DVD player. However, some older DVD players may have limitations on the types of files they can play, so it’s always a good idea to test your burned DVDs on different players before sharing them with others.
The amount of space needed on a DVD will depend on the size and quality of the AVI file you are trying to burn. A standard single-layer DVD can hold up to 4.7 GB of data, while a dual-layer DVD can hold up to 8.5 GB. It’s a good idea to check the file size of your AVI file and make sure it will fit on the DVD before attempting to burn it.
The quality of your AVI file may be slightly affected when converting it to DVD, as DVD resolution is lower than most digital video files. However, if you choose DVDFab DVD Creator and use the appropriate settings, the difference in quality is almost non-existent.
Finally, when it comes to converting AVI files to DVD, it is important to choose a reliable and efficient converter. Among the AVI to DVD converters mentioned in this article, DVDFab DVD Creator stands out as a highly recommended option. With its fast processing speed and high-quality output, this all-in-one DVD creator ensures a seamless and hassle-free conversion experience.
