4K Blu-ray movies have been around for a while now. Today, movies on Blu-ray are preferred by everyone around the world to play in their home theaters. But do you know how to rip 4K Blu-ray? Keep reading to learn more.
4K Blu-ray Movies: Everything You Must Know
A 4K Blu-ray movie, also known as Ultra HD Blu-ray movie, is a high-definition optical disc format that is designed to store and play movies in 4K resolution. 4K refers to a resolution of 3840 x 2160 pixels, which is four times the resolution of standard 1080p high-definition video.
A 4K Blu-ray movie typically features a higher bitrate than a standard Blu-ray movie, which allows for greater detail and a wider range of colors. Additionally, 4K Blu-ray movies may include advanced HDR (High Dynamic Range) and wide color gamut support, which provides a more lifelike and immersive viewing experience.
Differences Between 4K Blu-ray and Blu-ray Movie
4k blu ray movies
The main differences between 4K Blu-ray movies and Blu-ray movies are the resolution, color depth, and audio quality.
  • Resolution
4K Blu-ray movies offer a resolution of 3840 x 2160 pixels, which is four times the resolution of standard 1080p Blu-ray movies. This higher resolution results in greater detail and clarity, making the image appear more lifelike and immersive.
  • Color depth
4K Blu-ray movies also offer a wider color gamut and increased color depth compared to standard Blu-ray movies. This allows for more vibrant and accurate colors, with greater contrast and shadow detail.
  • Audio quality
4K Blu-ray movies often feature advanced audio formats such as Dolby Atmos and DTS:X, which provide a more immersive and three-dimensional sound experience. Standard Blu-ray movies may also offer advanced audio formats, but 4K Blu-ray movies typically offer the best audio quality available on physical media.
In addition to these differences, 4K Blu-ray movies often offer additional features such as HDR (High Dynamic Range) support, which further enhances the color and contrast of the image.
Are 4K Movies Better Than Blu-Ray?
Yes, 4K Blu-ray movies are better than the usual movies coming to Blu-ray in terms of picture quality. This is because a 4K Ultra HD Blu-ray disc has a much greater storage capacity than the standard Blu-ray disc. It has a display resolution that is four times greater than that of a regular Blu-ray disc and can display the best 4K Blu-ray movies at Ultra HD resolution. You can watch the best Blu-ray movies and have that cinematographic experience that you desire.
4k blu ray movies
Are 4K Blu-Ray Movies Worth it?
Yes, 4K movies are definitely worth it, with more and more movies coming to Blu-ray every passing day. Today, the best 4K Blu ray movies are usually found on Blu-ray discs available in the market, so 4K Blu-ray movies are definitely worth the investment. A 4K Ultra HD Blu-ray disc has a much greater capacity to vouch for its better resolution.
If you have a 4K TV or display and a high-quality sound system, and you want to experience the highest possible video and audio quality for movies, then 4K Blu-ray movies can provide a superior viewing experience compared to standard Blu-ray or streaming services. The higher resolution, wider color gamut, increased color depth, and advanced audio formats can make the image appear more lifelike and immersive, and the sound more three-dimensional and dynamic.
What is the Best 4K Blu-ray Movie?
The best Blu-ray movies in 4K don’t necessarily have to be new movies on Blu ray. Here’s a list of the best 4K Blu-ray movies that you might find interesting after your heavy investment in a 4K Blu-ray player. Many viewers and CNET.com have vetted this list.
  • Parasite
  • 1917
  • Black Hawk Down
  • Blade Runner 2049
  • Dunkirk
Best Way to Rip 4K Blu-ray Movies Free & Fast
If you want to store your 4K Blu-ray movies on a media server, external hard drive, or cloud storage for playback on multiple devices, then ripping them to digital format is an excellent option.
Rip 4k Blu-ray movies via DVDFab UHD Ripper
DVDFab UHD Ripper
This 4K Blu-ray Ripper allows you to rip any 4K Blu-ray movie to MP4 or MKV format while retaining HDR10/Dolby Vision effect for playback on any media palyer.
Win Download
100% safe&clean
Mac Download
100% safe&clean
DVDFab UHD Ripper is premier Ripping software that convert encrypted 4K Blu-ray movies to digital formats. Listed below are the main features of DVDFab UHD Ripper:
Features of this 4K Blu-ray Ripper
  • Remove protection from newly purchased encrypted 4K Ultra HD movies
  • Utilize advanced GPU acceleration technology, which speeds up the ripping process
  • Also handle 3D Blu-ray discs, allowing users to extract and convert 3D content
  • Personalize the output videos by adjusting numerous settings and built-in editor
  • Remove the Cinavia watermarks by working with DVDFab UHD Cinavia Removal
How to Rip 4K Blu-ray Movies with DVDFab UHD Ripper?
DVDFab UHD Ripper is super easy to use. Just follow these simple steps:
Step 1: Choose the Ripper module in DVDFab 13 and load the 4K Ultra HD Blu-ray source.
DVDFab UHD Ripper
Step 2: To choose from the profiles that are specifically designed for the UHD Ripper, click the Profile Switcher. You may then have different options to modify certain settings based on the profile you select.
Convert 4k Blu-ray to MP4/MKV
Then edit the output video via video edit as you want.
how to rip 4k blu ray discs
Step 3: Select an output directory and click the Start button to rip 4K Blu-ray.
how to rip uhd blu ray movies
Best Solution to Play 4K Blu-ray Movies
To make the most out of the new movies on 4K Blu-ray, you need to gear yourself with the finest movie player that is available in the market. You need to have a media player that can play the best 4k Blu-ray movies seamlessly for an enhanced viewing experience.
PlayerFab Ultra HD Player
PlayerFab Ultra HD Player is a well-known 4K video player that is ranked top among other media players. For 4K Ultra HD Blu-rays, it comes with a menu and HDR10 support. Playing your best 4K Blu-ray movies is an option here.
Play Blu-ray & 4K Blu-ray discs, ISO files and folders with menus and HDR10
Win Download
100% safe&clean
Mac Download
100% safe&clean
Features of this 4K Blu-ray Player
  • Play All (4K) Blu-rays from All Countries and Regions.
  • Exclusive support for all DVDs, Blu-rays, ISO images, and 4K Ultra Blu-rays.
  • Adjustable video thumbnails to get a quick glimpse of the chapters.
  • Overall Support on Discs, ISO Files and Folders.
  • AMD, Intel, and NVIDIA GPU Hardware Decoding.
  • Hi-Res Audio Output Support, up to Dolby Atmos & DTS:X.
  • All-Round Playback Support for All Types of 3D Videos.
  • Play 4K UHD Videos with Stunning HDR10 Effect.
  • Supports almost all popular video and audio formats.
  • Manage the media library efficiently by Poster Walls.
  • Import DVD & Blu-ray Discs to Local Media Library as ISO Files.
Playerfab: 4K blu-ray player
How to play 4K Blu-ray movies with amazing viewing quality
  1. Launch PlayerFab software
  2. Add media to your video library to enrich your library with DVD/Blu-rays/ISO files of your choice.
  3. Find the video (your best 4K Blu-ray movies) of your choice from your created library and play it!
The advent of 4K Blu-ray movies marks a significant leap in home entertainment, delivering unparalleled picture and sound quality. The growing library of available 4K titles further solidifies their place in the market, making them a worthy investment for anyone. Moreover, for those looking to store and access their 4K Blu-ray collections conveniently, tools like DVDFab UHD Ripper make it easy to digitize these films. With PlayerFab Ultra HD Player, you can fully leverage the stunning visuals and immersive audio that 4K Blu-ray offers.
