Common Types of 4K Blu-ray Burner You Must Know
Summary: This article aims to give you a full picture of the common types of 4K burners intended for personal entertainment. With the best 4K Blu-ray burner, like DVDFab UHD Creator, at hand, you can get standard 4K UHD Blu-rays for a truly immersive viewing experience.
Can You Burn 4K to 4K Blu-ray?
Normally, if you have lots of 4K resolution video clips or movies, you can burn 4K to Blu-ray for better playback on a standard 4K Ultra HD Blu-ray player. After all, everyone yearns for watching 4K Blu-ray movies with families on a grand home theater system at weekends. Meanwhile, burning 4K to Blu-ray helps you store 4K videos or movies for a longer time.
Therefore, you need to resort to 4K Blu ray burner such as professional 4K Blu-ray authoring software, 4K UHD Blu-ray external or internal burner drive which can write 4K data for personal use. With 4K UHD discs, you can enjoy stunning 4K content on the 4K home theater system.
Common Types of 4K Blu ray Burner
Technically, for one thing, a 4K Blu-ray Burner refers to an authoring program that can burn 4K Ultra HD videos into a blank 4K Blu-ray disc for better playback or backups. For another, it might involve external 4K Blu ray drive or internal Ultra HD Blu-ray drive that helps users write 4K data into a hard drive on the computer or save data information.
Warm tips: if you choose to write 4K digital data into blank UHD Blu ray drive, then you shall ensure the quality of 4K Blu ray optical drive. The higher the quality, the faster the writing speed will be.
Now let's dive into the common types of 4K Blu ray burner.
4K Blu-ray Burner Software
Typical example of 4K Blu-ray burner software is DVDFab UHD Creator, which are developed by DVDFab as the world’s best 4K UHD solutions favored by 4K home theater lovers. Detailed information on this 4K Blu-ray burner will be discussed later.
External 4K Blu-ray Drive
The Pioneer 4K UHD Blu-ray Burner (BDR-211UBK model) excels as an external burner solution with its fast writing speed and broad media support. It can read/write single and dual-layer BD-R discs, DVDs, and CDs at speeds up to 16X. With features like Quickplay for faster disc readiness, Auto Quiet mode for optimal speed adaptation, and Peak Power Reducer to minimize power consumption during peak operation, it's a top choice in the market.
- Faster burning speed up to 16x2 on BD-R single-layer discs, 14x on BD-R DL discs and 8x writing on BD-R triple-layer discs
- Support Ultra HD Blu-ray Playback bundled CyberLink software
- Amazing data storage capacity
- Smooth movie playback driven by PowerRead
Nevertheless, if you want to watch 4K UHD movies with this external 4K Blu ray burner, it can only work with Windows 10 and one Intel processor.
Internal 4K Blu-ray Burner Drive
When it comes to best internal Blu-ray drive, LG WH16NS60 shall come at the top of this list. This package comes complete with CyberLink Software and a SATA Cable, allowing for both reading and writing functionalities - effectively serving as a Blu-ray burner. Have a quick look at its features.
- Write and Read Quad, Triple and Double Layer BD-R discs with 16x BD-R writing speed
- Silent Play technology automatically controls disc read speed for optimal noise reduction
- Jamless Play technology automatically skips past damaged parts of a disc and maintain smooth playback
- M-DISC (DVD) Supported and 4K Ultra HD playback
Aside from being an internal Blu-ray or DVD burning software Windows 10 used to read and write 4K media data, it can deliver life-like and accurate colors with 4K resolution playback. But remember it is only available on Windows.
Best Professional 4K Blu-ray Burner
Professional 4K Blu-ray burner software is currently not widely available, despite a high demand from home theater enthusiasts. We're primarily focusing on DVDFab, the leading provider of DVD, Blu-ray and 4K UHD solutions globally. Their premier product is the DVDFab UHD Creator, which specializes in burning 4K Blu-rays with high-quality.
DVDFab UHD Creator
Features:
- Burn 4K videos of 200+ formats to 4K Ultra HD Blu-rays
- Retain premium HDR10/Dolby Vision quality
- Output high-quality video (2016p) & audio (DTS-HD, DTS:X, TrueHD, TrueHD Atmos)
- 20x faster burning speed with GPU Acceleration
- Generate user-friendly .nfo file for Media Server
- Also serve as a UHD Copy program that can losslessly copy UHD disc, ISO file, folder to a blank UHD disc or save as ISO file or folder on hard drive
This most professional 4K Blu-ray burner enables users to create cinema-equivalent 4K UHD Blu-rays that can be played on standard 4K UHD players like 4K Ultra HD TVs, Xbox One S and PlayerFab.
Above all, you can choose to preserve the HDR10 and Dolby Vision image quality of the original content for the purpose of quality playback on 4K UHD TVs. To satisfy your personal needs, you can select output quality as BD-25 2160p, BD-50 2160p, and BD-100 2160p and burn 4K videos to a blank disc. If you don't have a blank disc at hand, you can also save the output 4K Blu-ray as an ISO file or folder saved on your computer's HDD.
How to Burn 4K Blu-rays with DVDFab UHD Creator
With clean and intuitive interface, it's quite easy to burn 4K Blu ray with DVDFab UHD Creator. Refer to the following tips.
Free download, launch DVDFab 12 and go to UHD Creator module
Note that only the 64-bit version of DVDFab 12 contains the UHD Creator module.
Load 4K video source and customize the output 4K Blu-ray
Add or drag & drop 4K video source with or without HDR10/Dolby Vision contents onto the main UI. Then go to 'Advanced Settings (Wrench icon)' to set parameters for the output 4K Blu-ray: Menu Mode, Volume Label, Output (BD-25 2160P, BD-50 2160p, and BD-100 2160p), Processing Mode, and Video Quality.
Start to burn 4K Blu-ray
Set file destination to save the output 4K Blu-ray. Hit the 'Start' button to burn 4K Blu-ray. Detailed processing information will be shown on the progress bar.
Final Thought
Now you have gained a better understanding of the common types of 4K Blu ray burners and mastered how to burn Blu-ray with the world’s only professional 4K Blu-ray burner: DVDFab UHD Creator. This best 4K Blu ray burners can meet all your personal needs to create stunning 4K Blu-ray content playable on the 4K home theater system.
By the way, if you encounter an unfriendly 4K Blu-ray drive when burning 4K Blu-ray, remember to downgrade unfriendly firmware on 4K UHD Blu-ray drive with professional UHD Drive Tool so as to ensure a smooth backup task.
