Working professionals often need a reliable converter to file from one format to another without trouble. Zamzar converter performs similarly and provides you with a wide range of file conversions. Zamzar converter offers a wide range of file conversions as an online conversion tool. In the next couple of paragraphs, we will explore its extensive functionality. Let's start exploring.
Zamzar file Converter: Convert any file with Zamzar
Zamzar Converter, or better say Zamzar online file converter is a familiar name among the professionals whose job is to convert files from one format to another. In this context, Zamzar online converter plays a role in converting files, allows you to select the formats from its extensive format list, and after conversion, save the file to your preferred store. Further, it offers a systematic conversion process to go smoothly, and users feel about working with the tool repeatedly. Launched in 2006, file converter Zamzar works seamlessly to provide you with quality conversion and the best conversion experience with it.
The features
  • Convert CAD format to dwg, dxf to pdf, jpg, gif, and other formats
  • Convert zip files to 7z, tar.bz2, cab, lzh, rar, tar, etc
  • You can convert files by email
  • It supports drag and drops files with the fastest speed conversion
  • For Zamzar subscribers, it offers a high-speed download option
  • It provides stream converted videos and audios to your iPhone, iPad, or iPod
  • It's integrated with Integromat, which includes automation and productive tool that ensures the conversion without code
  • It can compress audio, documents, image and video files
  • It gives the popular conversion formats including mp3, MIDI, WAV, OGG, FLAC M4A, etc
Price: It offers 3 tier pricing. Startup $25/month, Growth $99/ month, Scale $299/ month. Test Free option is available to try the tool without a buck with limited file size for conversion
Pros
  • It's an online file converter; no need to download it on your device
  • Integrated with Integromat offers smooth conversion
  • It can convert even audio and video files to any format you want
  • Compression features add benefits for the users
Zamzar online file converter is a new-age converter that widely supports new-age technology and the current workflow. How does a handy online converter convert various files? Let's check its few steps.
Additional tips: There is a free trial if you want to try Zamzar Converter to check its conversion speed and quality. But if you're going for the long run with it, you need to sign up with your valid users' id and password after paying.
How to Convert an MP3 to AAC?
If you are a music lover, you often need to convert your mp3 to an AAC file. Zamzar file converter can help you in the process. Let's check out the steps:
Step 1: Visit Zamzar converter site
Step 2: Select the mp3 file you want to convert with the help of it
Step 3: Tap on AAC format you want to convert your file
Step 4: Finally, hit on Convert button to convert the mp3 file to AAC
It takes minimum time to convert the file with quality retained.
Zamzar Video Converter: How Zamzar convert video file
Zamzar is an online converter that plays a significant role in video conversion issues. You need not download the software to your device. Besides, you can convert the video file, which is not supported by wide devices or browsers. For instance, Youtube stopped using Flash video and accepted html5 video instead. Video converter Zamzar brings you the flexibility to convert any video file to any format you are looking for.
Let's check out how Zamzar video converter converts video files online.
Step 2: Add video files you want to convert
Step 3: In the drop-down, select the conversion format
Step 4: Click Convert Now
Step 5: Check the Email When done box and wait for a few minutes
Step 6: Check your mailbox, and download the output video file.
Note: Zamzar sends the output file to the mail id you entered during sign-up. Use a valid id, or you cannot access the conversion file.
It's an online video converter and easy to convert video files to any other format. Without downloading any software video converter Zamzar can convert video files and mail you. You can download the output file anytime on any device you want to store.
What benefits are you getting from Zamzar Online Converter?
Being an online converter, Zamzar offers the following benefits to its users:
  • No need to install the software on your device, which saves the space of your device
  • The online converter prioritizes your content's security; Zamzar never shares your content, video, or image with any third party. After finishing the conversion, the download file will be available for only 24 hours. After that, it wil be deleted automatically.
  • It deletes all the data from their database, and it's the significant advantage of an online converter.
  • Zamzar mail you the output file link to ensure that you will get access to the output file
Can I use Zamzar to convert a video file size 50MB?
You have to opt out of a video converter that can convert a video file that exceeds 50MB or more. In this context, we cannot recommend the Zamzar video converter as its video file size limit is 50MB.
Even if you want to convert multiple video files in a single go, you need a high-profile video converter to meet the latest requirements.
DVDFab video converter: Convert your video in Ultra High Definition
alternative to zamzar converter dvdfab video converter
DVDFab video converter is a state-of-the-art converter that can meet all your expectations and possibly produce results beyond your imagination. You can convert any video format to the other even with basic editing facilities. Its Enlarger AI technology provides upscale video, reaching up to 4k level. High definition is the newest trend that DVDFab video converter provides you with extremely excellent picture resolution and audio quality.
The features
  • You can convert video and audio in 1000+ formats, including 1080p, 4k, 5k, and up to 8k.
  • You can customize the output video and audio as per your requirements; it can be complete or partial.
  • It offers a built-in non-linear video editor to edit your output video files.
  • Its batch conversion with hardware accelerates technology, provides high speed, and produces results at a 30x faster rate.
  • Enlarger AI empowers it, which helps you upscale video up to 4k without disturbing the quality of the audio-video files.
Compatibility: Windows and Mac
Price: $29.99. Free download option also available
Pros
  • It can support 1000+ video audio formats
  • It offers the batch conversion for which you can convert multiple video files at a time
  • The primary editing option in output files is another great advantage
  • Enlarger AI provides Upscaling video resolution without compromise with the quality
How to Convert video with DVDFab video converter?
You can convert large file sizes and small sizes; there are no limitations. If you want to convert video files using Dvdfab, you must keep the below systems within your reach. They are:
  • Windows 11/10/8.1/8/7 (32/64 bit)
  • Pentium ll 500 MHz
  • RAM of 2 GB
  • 10GB free hard disc
  • Active internet connectivity
Let's check how you can convert video files using a DVDFab video converter.
Step 1: Install DVDFab video converter and upload the source file
After installing the program, double click on Dvdfab 12 and select the converting module. Here you can drag and drop the source file or click on Add button.
Step 2: Select format and device option
From the drop-down menu, select other profiles in the profile library. You can select audio-video output and the device you want to store.
Step 3: Customize the output file
Its built-in editor helps you customize edit, and you can add anything you want to your output file.
Step 4: Click on the Convert Video button.
Once you finish editing, click on the Start button, and the software will immediately start the process.
It takes minimum time to convert video and save it to the device you select. Its high speed and advanced features will smooth the process on quick notes. If you want to converter your favorite YouTube videos to MP3, you can check the post best YouTube to MP3 converter app.
Do you have more questions? Check our FAQs
Frequently Asked Questions
Yes. The online file converter Zamzar is absolutely safe to use
MP4. It's the standard format in that you can watch high-definition videos without glitches. Further, all the latest devices support mp4, which means you can play the video with your available device.
No, there's no file size limit, and you can convert large size as well as small size. Additionally, its batch conversion facility allows you to convert large file sizes to multiple videos at a time.
Final Words
Zamzar converter provides you with an online conversion facility, and you can convert files without downloading any tool to your device. If you go for multiple video files with large sizes, better opt out of DVDFab Video Converter to provide you with a batch conversion facility without any file size limit. With the increasing demand for file conversion in your daily life, you often need a converter tool so that you can finish your job seamlessly. In the end, quality and easy-to-use tools steal the show and win the users' hearts.
