DVDFab DVD Copy vs DVDFab HD Decrypter: A Detailed Review
Summary: This article provides a detailed comparison between DVDFab DVD Copy and DVDFab HD Decrypter, showing you the difference in functionality od DVDFab free vs paid product. It will help you make an informed decision on which tool best works for you.
Users often have the question:"I found that two of your products, DVDFab HD Decrypter and DVDFab DVD Copy, are similar in features. What is the difference between them? Which one should I choose if I want to backup DVDs?"
In this article we will be comparing DVDFab DVD Copy and DVDFab HD Decrypter. So we start comparing, let's learn what are these software and what purpose they serve. Are they free or paid? You may have questions like this which will be cleared after you read this article completely.
What is DVDFab DVD Copy and What it Does?
As we all knowe, DVDs aren't scratch proof and it will cost you extra money if you want to buy the same DVD when the disc gets scratched. So instead of buying the disc you should make a copy of it and save it on your computer's hard drive.
- A solution for backup and compress all physical DVD disc, ISO, and folder.
- Automatically detect and remove any DVD copy protection, including the latest ones.
- It supports batch copying at a GPU-accelerated speed with 1:1 output quality.
- Produce an copy of a DVD-9 to DVD-9 or a DVD-5 to DVD-5 without any loss of quality.
DVDFab DVD Copy basically provides six copy functions and they are listed below.
- Full Disc: Copy the entire DVD to ISO or folder or directly burn it to a blank DVD5 or DVD9.
- Main Movie: Only copy the main movie and skip the rest.
- Clone/Burn: Make a copy or clone the DVD to ISO in a 1:1 lossless ratio.
- Split: Split a DVD9 disc into two DVD5 discs.
- Customize: Copy any content from the DVD disc you want.
- Merge: Merge multiple DVDs in to one single DVD.
How to backup DVDs with DVDFab DVD Copy?
Step 1: Launch the program and insert the DVD you want to backup into your computer’s DVD drive.
Step 2: Click on the “Copy” option and select “Full Disc” “Main Movie” or other mode depending on your preference. You have the option to customize the volume label and modify copying settings, such as audio tracks, subtitles, and more.
Step 3: Lastly, choose the destination for your files to be saved as either a blank disc, ISO file, or folder.
What is DVDFab HD Decrypter and What It Does?
When DVDFab DVD Copy's 30-day trial period expires, it automatically gets converted to DVDFab HD Decrypter. So the purpose of HD Decrypter is also the same as that of DVD Copy, but with several limitations. First of all, it is free to use DVDFab HD Decrypter for a lifetime, and you won't be asked to forcefully upgrade or pay money to buy it. Use it as long as you want if it fulfills your DVD copy needs. It is currently the best free DVD encryption removal software.
- Freely decrypt and backup DVD/Blu-ray discs from a year ago
- Copy DVD/Blu-ray to DVD-9/BD-50 disc, ISO file, or Folder
- Support Full disc and Main movie copy modes
- Convert DVDs and Blu-rays to MKV & MP4 formats
- Customize output video with a built-in Video Editor
- The output file is compatible with various devices
- Support multitasking mode for DVD/Blu-ray to digital file conversion
DVDFab DVD Copy vs. DVDFab HD Decrypter
In this part we will discuss the main differences between DVDFab DVD Copy and HD decrypter.
Functions | DVDFab HD Decrypter | DVDFab DVD Copy |
Newest released disc | All the content available in HD and 4K | Content available in HD and 4K Quality |
Remove DVD copying protection | DVDs released one year ago | Any DVD copy protection |
DVD copy functions | 6 copy mode | Only Full Disc and Main Movie |
Ouput DVD formats | DVD-5/DVD-9/ISO/Folder | DVD-9/BD-50/ISO/Folder |
DVD copying speed | Fast with GPU acceleration | Medium |
Output DVD quality | 1:1 lossless ratio | No options available |
Metadata Output | √ | √ |
Compress Video Size | × | √ |
Convert DVD/Blu-ray to digital |
- Through the comparison table we can easily notice that although DVDFab HD Decrypter lacks some advanced features, it has unique advantages such as backing up Blu-ray, digitizing DVD and Blu-ray.
So it is clear from the above information that DVDFab DVD Copy software is a fully functional DVD Copy solution and HD decrypter is its simple version. You are free to use DVDFab HD decrypter for lifetime. If you want more DVD copy features and customization options, do not hesitate to upgrade to DVDFab DVD Copy.
