clonedvd review, download and alternative
What is CloneDVD?
CloneDVD2 is a versatile software tool designed for copying and cloning DVDs with ease.
Overview and History
CloneDVD, developed by Elaborate Bytes, has a longstanding reputation in the DVD copying and cloning industry. It was designed to meet the demands of both casual users and professionals seeking reliable DVD replication software. Over the years, CloneDVD has evolved to incorporate advanced features while maintaining its user-friendly approach to DVD copying.
Elby worked with Slysoft to distribute and market CloneDVD. This partnership helped Elby reach a broader audience, leveraging Slysoft's established presence in the multimedia software market. Unfortunately, both Slysoft and its successor company RedFox are currently shut down and all products are no longer sold.
How to Use CloneDVD for DVD Cloning?
Step 1: Download CloneDVD2 and Insert the DVD
After installing the software on your PC, insert the DVD you want to clone. Select the “Clone DVD” option from the main menu. CloneDVD will automatically recognize the disc, or you can add the VIDEO_TS folder yourself.
Step 2: Customize Settings (Optional)
Use the slider or input the desired compression ratio to ensure optimal quality. You can choose the audio tracks and subtitles you want to include in the cloned DVD before starting the cloning process.
Customize Settings of CloneDVD
Step 3: Select the Output Destination
CloneDVD allows you to choose between different output methods, such as burning directly to a blank DVD, saving as an ISO image, or creating a DVD folder on your hard drive. Then you can copy a DVD on Windows 10.
CloneDVD: Select the Output Destination
Key Features, Pros and Cons of CloneDVD
DVD Copying and Cloning
CloneDVD excels in its ability to copy DVDs efficiently. It allows users to duplicate DVD discs bit by bit, ensuring that the copied disc is identical to the original. This feature is particularly useful for creating backups or distributing multiple copies of the same DVD.
Compression and Quality Options
Without significantly sacrificing quality, users can adjust the compression ratio to fit larger DVD9 discs onto smaller DVD5 discs. This adaptability guarantees that you can effectively manage disc space while maintaining high-quality audio and video.
Supported Formats and Devices
Several output formats, such as DVD-Video, ISO images, and DVD folders, are supported by CloneDVD. It supports both NTSC and PAL video formats and works with a variety of DVD types, so it can serve a global user base. Moreover, CloneDVD guarantees compatibility with standard DVD players and additional playback devices.
avatar
Like any software, CloneDVD2 has advantages and disadvantages of its own that users should weigh before deciding.
Pros of CloneDVD2
  • CloneDVD offers several copy modes such as Full Disc, Main Movie, and Customize
  • Users can adjust compression settings to fit larger DVDs onto smaller discs
  • CloneDVD allows users to select specific audio tracks and subtitles to include in the copied DVD
  • It does not require excessive system resources, allowing users to run the software without experiencing performance issues
Cons of CloneDVD2
  • It is only available as a 21-day free trial
  • Only Video_TS folder is supported as an import file
  • Limited customer support options for troubleshooting issues
  • Occasional compatibility issues with certain DVDs or disc types
  • The software focuses primarily on DVD copying and lacks advanced editing or conversion tools
  • CloneDVD is only available for Windows, which means Mac users have to look for alternative for their DVD cloning needs
Best CloneDVD Alternative: DVDFab DVD Copy
CloneDVD is a reliable DVD copying and cloning tool, but it has some limitations as described above. DVDFab DVD Copy makes up for these shortcomings with its comprehensive features, excellent performance and wide compatibility, making it the best alternative.
CloneDVD alternative: DVDFab DVD Copy
DVDFab DVD Copy
DVDFab DVD Copy is DVD copy software that allows users to easily make backup copies of their DVDs with high quality and customizable settings.
Win Download
100% safe&clean
Mac Download
100% safe&clean
Key Features and Benefits of CloneDVD Alternative
  • • Regularly updated to support the latest media formats and technologie
  • • Offers lossless compression options to fit larger DVD9 content onto DVD5 discs
  • • Provides high-quality output with lossless compression and fast processing speed
  • • Offers 6 copy modes, such as Full Disc, Main Movie, Clone/Burn, Merge, Split, and Customize
  • • Support the latest DVD protection schemes, ensuring that users can backup any commercial DVD
How to decrypt and copy DVD with DVDFab DVD Copy?
Step 1: Download DVDFab DVD Copy and upload the source.
Install the software on your device and select "Copy" functions. Now upload the source file, whether a DVD, ISO, or folder.
How to copy DVD with CloneDVD alternative?
Step 2: Choose the copy mode and personalize the settings.
Visit the left pane of the software and select desired "Copy" mode. Clone or burn a DVD if the copy mode chosen is not lossless. The program also supports defining volume labels and customizing other copy functions. At last, choose the final path to place the output file.
How to use CloneDVD Alternative: DVDFab?
Step 3: Start ripping DVDs to Hard Drive
Once you have done all customizations and settings, click the "Start" button and let the program complete the copying process. You can also cancel the processing at any time.
How to clone DVD with CloneDVD alternative?
What is CloneBD? Is it the same product as Slysoft CloneDVD?
CloneBD is a software application designed specifically for copying, converting, and ripping (3D) Blu-ray discs. No, CloneBD and CloneDVD are not the same product, although they are both developed by Elaborate Bytes (Elby) and share some similarities in terms of user interface and design philosophy.
Is CloneDVD free?
It is not free to use CloneDVD. Although CloneDVD may provide a 21-day free trial, a license is needed to access all of the software's features. Lifetime free updates are priced at EUR 39.
What is CloneDVD Mobile?
Combining the user-friendly interface and careful design of Elby's CloneDVD, CloneDVD Mobile swiftly converts your DVD movies to file formats compatible with your portable devices (Sony PSP, Apple iPod Video, iAudio X5, Creative Labs ZEN Vision, etc.). Moreover, you can convert DVDs to other file formats like MP4, DivX, XviD, AVI, and so forth.
However, RedFox, the company that owned CloneDVD Mobile, has shut down and the availability of the product is in doubt.
CloneDVD is a reliable choice for DVD copying and cloning. But users looking for a comprehensive DVD copying software should consider DVDFab DVD Copy as a strong alternative. DVDFab not only makes up for CloneDVD's shortcomings with advanced features and wider compatibility, but also offers regular updates and excellent performance for seamless DVD copying.
