Is CloneCD Still Available?
CloneCD, a previously popular software distributed under the RedFox brand, appears to be presently unavailable from its official source. A sudden shutdown of the RedFox official website was observed in June 2024. Unfortunately, the cause behind this abrupt cessation remains unclear.
Furthermore, it is worth noting that other software offered by this company, namely AnyDVD and AnyStream, have been impacted by the recent developments. Consequently, these programs are currently inaccessible for users intending to register for a trial account or make a purchase, with CloneCD falling within the same category. Under such circumstances, if you still aim to clone CDs or DVDs, it would be wise to seek a reliable, powerful, and secure Clone CD alternative. We will now introduce two such substitutes.
CloneCD Review and Alternatives
Best CloneCD Alternative to Decrypt and Copy DVD - DVDFab
DVDFab, with more than 20 years of disc processing software development, is an excellent replacement for CloneCD when you're looking to decrypt and copy DVDs. Considered a top-tier solution in the industry, its DVD Copy module safe and reliable software allows you to easily decrypt, copy, clone, or burn your DVDs while maintaining the original quality. It is known for its user-friendly interface, quick processing speed, and superior functionality.
DVDFab DVD Copy
DVDFab DVD Copy
DVDFab DVD Copy allows you to losslessly decrypt and copy a DVD to computer as an ISO image file or folder, and backup or compress any encrypted DVD disc to a blank disc directly.
Features:
  • Remove any old and new DVD copy protection from commercial DVDs
  • Support to copy the latest-released DVDs
  • Copy or compress DVD to DVD 5/9, ISO image file, or Folder
  • Provide 6 copy modes: Full Disc, Main Movie, Customize, Split, Clone/Burn, Merge
  • Copy DVD in batch at GPU-accelerated speed with highest quality
  • Allow you to choose the titles, chapters, audio tracks and subtitles for free
  • Free experience Blu-ray Copy module to decrypt and copy your Blu-ray
Win Download
100% safe&clean
Mac Download
100% safe&clean
How to Use the Best Reliable CloneCD Alternative to Decrypt and Copy a DVD
Step 1: Download and Install DVDFab DVD Copy for free. It is completely safe and clean.
Step 2: Open DVDFab software and choose the "Copy" module to enter the copy panel. Load the source DVD you want to copy. The software is smart enough to immediately analyze and decrypt the DVD after you insert it into your DVD drive.
Step 3: On the main interface, there is a copy mode switcher in the top left corner. Click on it and you can choose the copy mode you desire. Whether you want to copy the whole DVD or only a certain part, DVDFab gives you the freedom to choose.
Step 4: After you've selected the copy mode, you can customize your DVD further using advanced settings and options offered by the software. You can either make changes to the volume label, save it to your specified directory, or select the type of output as DVD 5 or DVD 9.
Step 5: Once everything is set, click on the "Start" button to initiate the process. A progress bar will display the ongoing operations, and update you on remaining time.
Best CloneCD Alternative to Copy CD - CDBurnerXP
CDBurnerXP is a free alternative to CloneCD. It is a versatile tool that can burn CDs, DVDs, HD-DVDs and Blu-rays. It supports ISO and MDS image file creation and burning. It's compatible with many Windows versions, including the latest Windows 10.
Key Features:
  • Multi-language interface: English, German, French, Spanish, and more.
  • Burn and create ISO files.
  • Data verification after burning process.
  • Create bootable discs.
  • GUI to replace Explorer-style.
  • Burn on-the-fly and with buffer-underrun protections.
  • Create audio CDs with or without gaps between tracks.
Unlike CloneCD, CDBurnerXP is not designed exclusively for CD or DVD copying, so it doesn't provide some advanced features like "Raw" mode or game copy protection bypass. However, for general use, it is sufficient and easy to use.
RedFox CloneCD Overview: Pros, Cons, and Download
Produced by Slysoft, CloneCD establishes itself as a cutting-edge tool permitting users to create reliable, 1:1 copies of their music and data. With a primary focus on offering an ideal solution for creating backups, CloneCD stands high above the competition due to its unrivaled ability to clone CDs, independent of the presence of any copy protection.
Pros of CloneCD
CloneCD is noteworthy for its intuitive user interface, which enables any user to quickly and effortlessly copy almost any CD with just a few mouse clicks. Further adding to its potent repertoire, since its release of 5.0 version, CloneCD extended its domain, bringing its advanced copying capabilities to DVDs as well.
Its compatibility with a vast array of DVD formats alongside CDs, which includes DVD-R, DVD-RW, DVD+R, DVD+RW, DVD+R Dual Layer, and DVD-RAM, makes it a must-have program for preserving your favorite media. Moreover, CloneCD is exceptional, as it ensures that movies copied are not compressed or altered, but remain in their original, unmodified form.
RedFox CloneCD
CloneCD version 5.3.1.4 brings forth surprising enhancements, showcasing the program's commitment to continuously develop. It embraces burning of .dvd files created via AnyDVD software and defaults to create ISO images when reading DVD media. Simultaneously, notable improvements have been made to rectify the security vulnerability present in the driver interface.
But there's more to CloneCD than just CDs and DVDs. It is adept at working with other formats such as ISO and UDF files, extending its usability and proficiency. Interestingly, the non Red Book standard music CDs that don't play on your car audio? CloneCD ensures that the backup it creates will.
Cons of CloneCD
Despite the various functionalities of CloneCD, there have been several critiques and concerns raised by users on authorized websites like download.cnet.com and videohelp.com. Here are some of the cons highlighted:
Inability to Overcome Copy Protection: Some users noted that the software could not handle certain copy protection, thus failing to make backup copies of particular games or CDs.
Limited Functionality: A few users lamented the lack of additional features beyond cloning CDs. The software does not offer ripping or tagging capabilities.
Perceived High Price: The cost of the application was seen as quite high by a few reviewers, causing them to question its value for money.
Customer Service: A user reported that they wrote to the company with a query, but never received a response, pointing to potential issues with customer support.
Inconsistent Performance: While some users found it is usually successful, others highlighted that CloneCD does not always manage to create successful copies.
Payment Issues: A reviewer pointed out that the company refused to accept their payment after the 21-day trial period without giving any reason.
How to Download CloneCD
Then, let's discuss how to download CloneCD. Kindly note that the official website of RedFox, the manufacturer of CloneCD, is currently unavailable rendering it impossible to directly purchase or download the software from its official source.
However, the absence from RedFox does not eliminate CloneCD from the internet entirely. When you search for "CloneCD download" on Google, several pages from third-party websites and channels appear offering downloadable versions of the software.
Instead, wait out until the official RedFox website is back up or look for reliable alternatives to CloneCD that meet your criteria. In this way, you can ensure that you are securing and protecting both your device and your data.
Considering the abrupt disappearance of the RedFox official website and the subsequent inaccessibility of its software including CloneCD, a pressing need for alternatives emerges. DVDFab DVD Copy Software and CDBurnerXP serve as excellent alternatives, allowing users to continue cloning CDs and DVDs with ease, efficiency and security.
