Does Xbox 360 Play Blu-ray? And How? [Solved]
Summary: Does Xbox 360 play Blu-ray? Is there any Xbox 360 Blu ray player available? This article will show you how to convert Blu-ray discs to an Xbox-compatible format for high-quality indirect playback. Continue reading to discover better solutions to the problem "X360 doesn't play Blu-ray".
Can Xbox 360 Play Blu-ray?
Xbox 360 was the seventh-generation video game console that was released back in 2005, which directly competed with Sony’s Playstation 3 (PS3) and Nintendo’s Wii. Nevertheless, Xbox 360 doesn't play Blu-ray just as the PS3 does. The Xbox 360 was designed before Blu-ray technology became commonplace. Microsoft chose to support HD DVD, but the format quickly lost out to Blu-ray in the format wars. As a result, the Xbox 360 doesn't have the hardware needed to read Blu-ray discs. It can only play DVDs, CDs and HD DVDs (using an external HD DVD drive). Currently, only the Xbox One and newer models can play Blu-ray natively.
Don't worry if you can't upgrade to the Xbox One, there are ways to make the Blu-ray player compatible with the Xbox 360. In this article, we'll explore two practical ways to enjoy Blu-ray content without a dedicated Xbox 360 Blu-ray player.
How to Make the Xbox 360 Play Blu-rays?
Solution 1: Rip Blu-rays to Xbox 360-Supported Formats
Although the console can't play Blu-ray discs directly, you can convert Blu-ray videos to make them suitable for playback on Xbox 360. DVDFab Blu-ray Ripper serves as an all-in-one disc ripping tool that can convert Blu-ray discs to Xbox 360-compatible formats for playback on a variety of portable devices.
The Best Xbox 360 Blu-ray Ripper from DVDFab
- It provides built-in video profiles for Xbox 360 and other devices
- Processes Blu-ray discs quickly with Intel and Nvidia CUDA hardware acceleration technologies
- Maintain original video and audio quality during conversion, with options for 1080p or even 4K
- Customize the output file, e.g. adjust resolution, bitrate, subtitles, audio tracks, etc
- It can work with NVIDIA AI Enhancer to upscale video from SDR to 4k HDR10
How to Play Blu-ray on Xbox 360 Using DVDFab Blu-ray Ripper
Follow the tutorial below to rip Blu-ray to Xbox 360-supported video formats.
Step 1: Download and install the latest version of DVDFab software. Open the program and click the ‘Ripper’ tab. Now load your Blu-ray disc in the optical BD drive. You can also load a BD ISO/folder if you don’t have any discs at hand.
💡You can also rip 4K Blu-ray using Ripper mode of DVDFab.
Step 2: After loading the ISO/disc click the ‘Choose Other Profile’ button and click the ‘Device’ tab. From this list select ‘Microsoft’ from the left side and then click ‘Xbox 360’ on the right side.
Step 3: Now check whether you need to select chapters, audio stream, and subtitles. Please click the ‘Choose Other Titles’ button to select all the videos on the Blu-ray disc. Then, click the ‘Advanced Settings’ to check whether you need to modify the video settings or they are just perfect.
Step 4: After checking the settings you can click the ‘Video Edit’ button to launch the built-in video editor. The DVDFab video editor provides all the basic video editing tools with several advanced video editing tools like multi trim, add subtitles, and adding background music, and watermark. Besides, brightness, contrast, and saturation are all at your disposal.
Step 5: Finally click the ‘Start button'. Then DVDFab Blu-ray Ripper will rip Blu-ray to MKV or other Xbox 360-compatible formats. Once the ripping process finishes you can transfer the ripped videos to your Xbox 360’s storage for watching them on the TV.
Solution 2: Use Xbox360 Blu-ray Player to Play Blu-rays on Computer/TV
Instead of ripping Blu-ray to Xbox-compatible video formats, the second option is to use external player software. PlayerFab, one of the best 4K media players, comes highly recommended because it includes PC and TV Mode for both small and larger screens, as well as being a good Xbox 360 Blu-ray player.
PlayerFab is an all-in-one media player with a clear menu navigation support for 4K Ultra HD Blu-rays, (3D) Blu-rays, and DVDs. Whether you're watching 4K UHD Blu-rays, (3D) Blu-rays, DVDs, or streaming from popular platforms, PlayerFab is equipped to meet all your entertainment needs. Here are some features of this software.
- Support for 44K UHD/Blu-ray/DVD discs with clear menu navigation.
- Allows to create personalized playlists with customization options.
- Offers a free DVD player mode to manage your unique video library
- Support for popular streaming platforms like Netflix, Hulu, Amazon Prime Video, etc
- High-Res 7.1 channel audio output with support for Dolby Atmos, Dolby TrueHD, etc
- Supports all kinds of 3D content like 3D Blu-ray discs, and SBS or top & bottom 3D videos
As we mentioned at the beginning, the Xbox 360 doesn't directly support Blu-ray playback. However, you can enjoy Blu-ray content on Xbox 360 by ripping it to digital format. Alternatively, if you're looking for a direct solution, PlayerFab can also solve the problem of playing Blu-ray on your console.
And as we previously stated, the Xbox One, the successor to the Xbox 360, does support Blu-ray playback. If you're planning on upgrading to the Xbox One, you may want to check how to play Blu-rays on Xbox One.
