Can Xbox 360 play Blu-ray? How about the Xbox 360 Blu-ray player? First, let’s face reality. Xbox 360 was the seventh-generation video game console that was released back in 2005, which directly competed with Sony’s Playstation 3 (PS3) and Nintendo’s Wii.
Nevertheless, Xbox 360 doesn't play Blu-ray just as the PS3 does. So, does Xbox 360 play DVDs? Yes, Xbox 360 could only play DVDs, CDs, and HD DVDs. At present only Xbox One can play Blu-rays. But if you can’t afford the upgraded Xbox One, then read the article till the end to find possible shortcuts. You will master how to make Xbox 360 play Blu-ray with or without an Xbox360 Blu ray player. Here are two methods provided.
Solution 1: Rip Blu-rays to Xbox 360-Supported Formats
Can the Xbox 360 play Blu-ray? NO. Can Xbox one play Blu-ray? YES! Thus, how to face the question "Xbox 360 doesn't play Blu-ray"? The best shortcut is to turn to DVDFab Blu-ray Ripper to rip your Blu-ray discs to Xbox 360-compatible video formats.
The Best Xbox 360 Blu-ray Ripper from DVDFab
Available on Mac and Windows, this Xbox 360 Blu-ray Ripper can rip your Blu-ray discs/ISO/folders to mainstream video format in diverse resolutions and peak quality. Meanwhile, you can customize video/audio parameters and edit the output video with its built-in video editor for the purpose of enhancing video quality.
This Blu-ray ripping software has a built-in video profile for Xbox 360, so you can select it to load the pre-configured settings for the best quality. It processes Blu-ray discs fast supported by Intel Quick Sync and Nvidia CUDA hardware acceleration technologies. Follow the tutorial below to rip Blu ray to Xbox 360-supported video formats.
Tutorial: Play Blu-ray on Xbox 360 Using DVDFab Blu-ray Ripper
Step 1: Download and install the latest version of  DVDFab Blu-ray Ripper. Open the program and click the ‘Ripper’ tab. Now load your Blu-ray disc in the optical BD drive. You can also load a BD ISO/folder if you don’t have any discs at hand.
💡You can also rip 4K Blu-ray using Ripper mode of DVDFab.
Step 2: After loading the ISO/disc click the ‘Choose Other Profile’ button and click the ‘Device’ tab. From this list select ‘Microsoft’ from the left side and then click ‘Xbox 360’ on the right side.
Step 3: Now check whether you need to select chapters, audio stream, and subtitles. Please click the ‘Choose Other Titles’ button to select all the videos on the Blu-ray disc. Then, click the ‘Advanced Settings’ to check whether you need to modify the video settings or they are just perfect.
Step 4: After checking the settings you can click the ‘Video Edit’ button to launch the built-in video editor. The DVDFab video editor provides all the basic video editing tools with several advanced video editing tools like multi trim, add subtitles, and adding background music, and watermark. Besides, brightness, contrast, and saturation are all at your disposal.
Edit video before using the alternative Xbox One Blu-ray player
Step 5: Finally click the ‘Start button'. Then DVDFab Blu-ray Ripper will rip Blu-ray to MKV or other Xbox 360-compatible formats. Once the ripping process finishes you can transfer the ripped videos to your Xbox 360’s storage for watching them on the TV.
Note that this Blu-ray to Xbox 360 ripping software can work with an AI-powered video upscaler to upscale video from 1080p to 4k while converting Blu-rays to Xbox 360 supported video formats with lossless quality and lightning-fast speed.
Solution 2: Use Xbox360 Blu-ray Player to Play Blu-rays on Computer/TV
Instead of ripping Blu-ray to Xbox-compatible video formats, we can also find a Blu-ray player. PlayerFab, one of the best all-in-one 4K media players, comes highly recommended because it includes PC and TV Mode for both small and larger screens, as well as being a good Xbox 360 Blu-ray player.
PlayerFab is an all-in-one video player with a clear menu navigation support for 4K Ultra HD Blu-rays, (3D) Blu-rays, and DVDs. This Xbox360 Bluray player can play any format of videos (H.264/265) and playback DVD and Blu-ray discs. Except for the free DVD player, PlayerFab contains ultra HD player, Amazon player, Netfilx player, Hulu player, and the other streaming platforms. Here are some features of this software.
The Best Xbox360 Blu-ray Player - PlayerFab
  • Fully supports 4K Ultra HD Blu-ray playback.
  • Allows for customized options to create playlists.
  • The only player that supports HDR10 playback for crystal-clear playback.
  • Fully supports navigation menu on 4K UHD Blu-ray/Blu-ray/DVD discs.
  • Built-in player settings. Customize the settings while the player plays a movie.
  • Easy to use and intuitive UI.
  • High-Res 7.1 channel audio output with support for Dolby Atmos, Dolby TrueHD, DTS:X etc.
  • Supports all kinds of 3D content like 3D Blu-ray discs, ISO files, and SBS (side-by-side) or top & bottom 3D videos.
Now you just have learned how to rip Blu-ray discs/ISOs to Xbox 360 compatible format and found the right answer to your question “does Xbox 360 play Blu-ray”. This is the only indirect way to watch and play Blu-rays on Xbox 360 by ripping them first to a compatible format. Alternatively, PlayerFab can also solve the problem of "Does Xbox 360 play Blu-ray". If you are looking for a compatible DVD/BD/3D BD/4K UHD player, PlayerFab is the best Blu-ray player.
Just as we said in the article, the successor of Xbox 360, namely Xbox One, can play Blu-rays. If you are going to replace your Xbox 360 with Xbox One, you may want to check how to play Blu-rays on Xbox One.
