How to Convert 2D Blu-ray to Side-By-Side 3D?
You have professional 3D glasses but not enough 3D videos to enjoy? Just use DVDFab 2D to 3D Converter and Blu-ray Ripper to convert 2D Blu-rays to side-by-side 3D videos for great 3D effect. Get started with this simple tutorial and try out yourself. It’s darn easy.
Step 1: Download and install the DVDFab 13
Download and install the latest version of DVDFab 13 onto your computer
Step 2: Launch DVDFab 13
Choose Ripper option at the Option Interface (or from the Option Bar at the Main Interface), then load the regular DVD you are about to convert;
Step 3: Choose a Video Profile
Click the down-triangle button and click "Choose Other Profile", open profile library on the top left corner of the main interface and go to Format to choose a video profile from the "Format">"Video">"3D" column, according to what video format your 3D device is able to play back;
Click Advanced Settings button on the main interface, go to 3D tab, then choose side-by-side 3D as the 3D Format. Besides, you can set the 3D effect by changing the Gain value and Visual Depth. You can also go to the Video tab and Audio tab to set video and audio parameters.
Step 4: Start to Rip
Hit Start button to start conversion. During the process, you can view all detailed progress info and preview the progress with real time images.
What You Need to Know about SBS 3D?
SBS 3D, or Side-by-Side 3D, is a method used to create a three-dimensional effect in visual media. In this format, two images—one for each eye—are displayed side by side. Each image is slightly different, mimicking the way human eyes perceive depth. This technique is commonly used in 3D films, gaming, and virtual reality. When viewed with appropriate 3D glasses or on a compatible display, the brain combines the two images, creating the illusion of depth.
- Full SBS: This format displays two full-resolution images side by side. Each image retains its original resolution, which means the 3D effect is more detailed and immersive. Full SBS is ideal for high-quality viewing on larger screens.
- Half SBS: In this format, the two images are compressed horizontally, meaning each image is half the width of a full image. This results in lower resolution for each eye, but it reduces the file size, making it easier to stream or store. While the 3D effect is still present, it may not be as sharp as full SBS.
Converting 2D Blu-ray content to SBS 3D enhances the viewing experience by adding depth and immersion. This transformation allows audiences to engage with familiar scenes in a dynamic way. While the conversion process has technical challenges, the resulting 3D effect elevates storytelling and visual impact, appealing to both casual viewers and cinephiles. As technology advances, enjoying classic 2D content in 3D opens up exciting possibilities for filmmakers and audiences alike.
