Blu-ray to audio refers to the process of extracting audio tracks from a Blu-ray disc, typically containing high-definition sound formats. This allows users to enjoy high-quality audio files, often in formats like Dolby TrueHD or DTS-HD Master Audio, which provide superior sound fidelity compared to standard audio formats. The extracted audio can be used for personal listening, creating playlists, or incorporating into multimedia projects. Specialized software or Blu-ray players with audio extraction capabilities are usually required for this process.
How to Rip Blu-ray to Audio with Blu-ray Ripper?
Sometimes you may want to extract the audio from a Blu-ray movie so that you can listen to the audio file on your MP3 or iPod. If you are in need, you can try DVDFab Blu-ray Ripper, which is able to extract the entire or part of video and audio from your encrypted Blu-ray discs/iso/folder into popular digital formats playable on any meidia device. Now let’s take a look at how to rip Blu-ray to audio.
Part 1: To extract the entire audio from your Blu-ray:
Step 1: Run DVDFab Blu-ray Ripper and Load Source Blu-ray
Download the software on your Windows or Mac and run it. Once it's done, choose the "Ripper" module and navigate to the source file by clicking the "Add" button or simply dragging it into the main page.
how to rip blu-ray with the best blu-ray ripper
Step 2: Choose an Audio Profile and Customize Your Audio
Click "Choose Other Profile" to navigate to the profile library.
On the pop-up interface, click "Format" - "Hi-Fi Audio" or "Audio" to choose an audio format you want. DVDFab Blu-ray Ripper supports almost all digital audio formats, including MP3, MP4, M4A, WMA / WMA10, WAV, AAC, DTS, OGG, PCM, AC-3/E-AC-3 5.1, etc., with up to 7.1 channels. Here let's take MP3 as an example.
Then go back to the main interface and choose the titles (the main movie title is already selected by default) and the audio tracks, define the title names, and do advanced settings according to your needs.
Note: DVDFab Blu-ray Ripper can work with DVDFab Blu-ray Cinavia Removal to completely eliminate cinavia protection from your Blu-ray discs. By doing so, it can generate a clean audio backup without Cinavia that can be smoothly played on all the affected playback devices.
Step 3: Define the Output Directory and Start Blu-ray Ripping
Click the "Inverted Triangle" or "folder" button to select a directory to save the output audio file. And then you can click the "Start" button to start the Blu-ray to audio ripping process.
Part 2: To extract part of the audio from your Blu-ray:
Step 1: Run DVDFab 12, choose the "Ripper" module and load the source.
Step 2: After the source is loaded in, the longest title, namely the main movie, will be selected by default. But here you can choose other titles. Then click "Choose Other Profile" to navigate to the profile library and choose a video format randomly.
Click the “Editor” icon to go into the editing panel and choose the “Trim” tab. Here you can drag the start tab and end tab to decide the length of the video, which in fact is the length of the output audio. After you finish the work, click "OK" button.
Step 3: Go to the profile library again and choose the audio format you want.
Step 4: Then you can choose the audio track, define the names of titles, and do advanced settings. Finally, select an output directory and click the start button to initiate the Blu-ray to audio ripping process, as we mentioned above.
Final Words
DVDFab Blu-ray Ripper is an excellent tool for rip Blu-ray into audio and video formats. Whether you want to rip the entire audio track or just a specific part of it, this software provides a user-friendly interface and various customization options to meet your needs. With its fast ripping speed and high-quality output, you can enjoy your favorite music, sound effects, or dialogue from Blu-ray movies on any device or media player.
