How to convert UHD to Blu-ray: Quick and Easy Steps
Summary: What do you do if you want to make a 4K UHD Blu-ray movie playable in your BD player? You can convert the UHD Blu-ray to Blu-ray! Check the article to find the detailed steps.
- • Convert 4K UHD Blu-rays to Blu-rays with the best quality
- • Allow you to output Blu-ray in the format of ISO file or folder on HDD
- • Make it possible to burn Blu-ray videos to a disc (BD 50/25) available on a home Blu-ray player
- • Enable you to enjoy converted Blu-ray files on a player without 4K Blu-ray support
Introduction
Just when you thought your 1080p Blu-ray movies are the ultimate in home entertainment, 4K Ultra HD Blu-ray movies sweeps into the home entertainment scene, edging out standard Blu-ray movies. But if you’re planning to buy a 4K UHD Blu-ray and pop it into your existing Blu-ray player, hold on a second. There’s bad news for you. Standard Blu-ray players don’t support 4K Blu-ray video. They support only BD25 and BD50 discs.
For your information, 4K UHD movies come in the BD100 disc format which is not supported in a regular Blu-ray player. So, what do you do if you want to make a 4K UHD movie playable in your BD player? Do you have to fork out more cash to purchase a 4K UHD Blu-ray player. The good news is there’s no need to. You can convert UHD to Blu-ray disc. In other words, you can convert 2160p to 1080p Blu-ray flawlessly.
It’s possible with the DVDFab UHD to Blu-ray Converter widely recognized as the world's first 4K UHD to Blu-ray disc converter.
Convert UHD to Blu-ray with DVDFab UHD to Blu-ray Converter
All in all, with DVDFab UHD to Blu-ray Converter you get lossless video quality which has no noticeable difference between that of HDR10. What’s more, audio quality is pristinely preserved, too.
Another bonus is once the conversion is done, you may choose one of the two output options available. Either save the conversion as a ISO file which you could use it at a later date or if you want to play the file on a non-4K Blu-ray player, you could burn it to a standard Blu-ray disc.
How to convert UHD to Blu-ray with DVDFab UHD to Blu-ray Converter
Download the latest version of DVDFab
Insert your 4K UHD disc into the Blu-ray drive upon installation of DVDFab. And select the Copy mode and choose UHD to Blu-ray option. You can also upgrade DVD to Blu-ray using DVDFab.
Customize output blu-ray disc
Select your desired titles, audio tracks, subtitles, output size, file destination, menu mode and playback mode. You are allowed to further customize your output video by clicking on the Advanced Settings.
Start to convert it
You could save it as an ISO file, copy your 4K Ultra HD Blu-ray movie to a folder, or insert a blank Blu-ray disc and proceed to choose the Blu-ray drive as the Save to option. Once done, hit ‘Start’ and wait for the final product.
Now that you know how to convert UHD to Blu-ray, you’re invited to download DVDFab Blu-ray to UHD Converter. By following the right techniques and utilizing this software, you can seamlessly transfer your high-quality UHD content onto Blu-ray discs, ensuring compatibility and enhanced viewing experiences. By the way, if you are looking for the best free blu-ray player software, read this article.
