[Review] Get Insights about UniFab Video Upscaler AI: Good or Not?
Summary:Get an inside look at the user experience of UniFab Video Upscaler AI. Hear firsthand accounts from users to help you determine its worth.
- Upscale low-res videos into 720p/1080p/4k
- Denoise videos for cleaner and sharper quality
- Compiled upgrade provides 200% faster processing speed
- Support video editing, converting and compressing
As a paid DVDFab Video Enlarger AI subscriber, I received a notice that I’d get a lifetime version of UniFab Video Upscaler AI, so, I quickly downloaded and tested the upgraded software.
Today, I am going to share my review of using UniFab Video Upscaler AI with my experience of some of its features that helped improve my productivity and work and the ones I loved. Here’s my experience after using UniFab Video Upscaler AI for a few days.
Introduction
UniFab Video Upscaler AI is a powerful video-enhancing software that uses AI technology to improve the quality of your videos. It works by analyzing your video’s pixels and enlarging them without sacrificing quality. Unlike other video-enhancing tools that simply stretch the pixels, UniFab Video Upscaler AI is trained by advanced deep learning algorithms, presenting you with a more realistic and vivid visual effect.
Personal Reviews of UniFab Video Upscaler AI
I uploaded an old-resolution video to see if UniFab Video Upscaler AI can detect its low-quality content and enhance the quality. And to my surprise, the software did fairly well. I found it works on advanced deep learning algorithms, and its AI models are trained to recognize, analyze, and improve video content with realistic and vivid visual effects.
What's more, I tested the software for multiple genres by uploading different media files like some low-resolution TV shows, black-and-white movies, and animations. And guess what! Even there, UniFab Video Upscaler AI surpassed my doubts by developing a general enhancement model that delivered impressive results.
Features
- AI Upscaling: Increase video resolution up to 720p/1080p/4K without and compress or convert videos without losing quality
- Detail Enhancement: Improve the sharpness and clarity of any kind of videos, no matter it is cartoons or BW movies
- Video edition function: Crop or trim the video, can customize the sound effect ot remove background noise
- Import videos from DVDFab/StreamFab: Very friendly to DVDFab/StreamFab users, make the full video workflow a convenient streamline
- Easy and clear UI design: Very simple interface, unlike other AI tools, which are outdated and complicated to use. The design and operation is simple for beignners
Cons
Overall, UniFab Video Upscaler AI is an essential video enhancement tool for me to improve my video quality. However, there are some undeniable aspects which need to be improved:
- High demand for your device hardware: considering that UniFab adopts AI algorithm, so it has a relatively high requirement for your computer configuration (see the below content for more info)
- 30-Day free trial: You have only 30 days to use it for free under the trial period
Supported systems
As we mentioned above, UniFab Video Upscaler AI has a high system demands, it is better for you to check if your devices is supported to enjoy this AI enhancer:
- * For specific system requirements on RAM, GPU, and Graphic cards, as well as test examples for processing speed, please see.
How to use UniFab Video Upscaler AI
Here are the steps you need to take to use UniFab Video Upscaler AI to enhance your videos:
Choose the 'Enlarger' module. Click the Add Video button to select the video you want to enhance in the local file.
Customize the restoring video file
Customize the enhancement choices, including the enhanced resolution, frame rate, codecs, etc. After that, you can click 'Start' and wait until the end of the enhancing procedure.
Using UniFab Video Upscaler AI to enhance your videos is a straightforward process that can help you achieve professional-level results quickly. Whether you’re a video editor or just someone who wants to improve the quality of their videos, UniFab Video Upscaler AI can help you well.
DVDFab Enlarger AI is the previous version of UniFab Video Upscaler AI. In other words, DVDFab Enlarger AI has been upgraded into UniFab Video Upscaler AI since Oct.2023. The adopted tech and enhancing model of UniFab is much better than the old one in DVDFab.
If you are previous DVDFab Enlarger AI member, you can access UniFab Video Upscaler AI for free.
The time it takes to enhance a video with UniFab Video Upscaler AI depends on several factors, such as the length and complexity of the video, the hardware specifications of your computer, and the settings you choose. The following are our test results for your reference only.
Enlarge 480p-720p | Enlarge 720p-1080p | Enlarge 1080p-4k | |
GTX 1660 | 10 times the length of the original video | 16 times | 50 times |
RTX 3070 | 5 times | 7 times | 32 times |
RTX 4080 | 4 times | 6 times | 28 times |
Anyway, UniFab Video Upscaler AI is the ultimate tool for enhancing my videos. Its advanced artificial intelligence technology allows you to upscale videos to higher resolutions without sacrificing quality or clarity.
Compared to other video-enhancing tools in the market, UniFab Video Upscaler AI stands out with its exceptional performance and ease of use. The tool’s ability to transform low-quality videos into high-definition masterpieces impressed me a lot.
