Is Xbox Series S Disc Drive Compatible With DVDs?
Summary: The Xbox Series S is a popular gaming console, but is its disc drive compatible with DVDs? This article answers that question and explains how to play DVDs on the Xbox Series S. Read on to learn more.
Does the Xbox Series S have a disc drive?
In simple terms, no. With no disc drive on this device, no physical disc-based content will be compatible with this device. Disc-based TV and movies as well as games will not be supported. On the other hand, Xbox Series X shows support for DVD and 4K Blu-ray playback. Rather, Xbox Series S users must use the combined Xbox Store for entertainment and games, or on-demand streaming platforms with the apps for this device.
The elimination of Xbox Series S external disc drive indicates that backward compatibility for Xbox Series S is restricted to its Xbox Series X peers. But the elimination of the disc drive comes with its advantages, such as lower cost as compared to the Xbox Series X. The company first tested a disc-less device earlier with the Xbox One S All-Digital, cutting the retail cost by $50, just closing the external slot and eliminating the disc reader.
How to Play DVD Discs on Xbox Series S? — Digitize DVD
Since the Xbox Series S have no disc drive, there must be another way to do so. Xbox Series S supports video formats such as MP4, M4V, MP4V, MOV, AVI, MPEG-4, and WMV. Hence, users can convert DVD discs to one of these video formats and then play on the device.
Digitize DVD with DVDFab DVD Ripper
The best way to convert files in to use DVDFab DVD Ripper. The tool can convert videos to over 1000 video and audio formats supported by popular devices, including the Xbox Series S. Below are some features of the tool that will give you a basic idea about the capability it has. Have a look.
- 1000+ supported formats: This tool converts DVDs to over 1000 audio and video formats for devices like the Xbox Series S and supports burning and ripping for 260+ devices, including Apple and Samsung.
- Quick DVD ripping: Advanced GPU acceleration enables ripping a DVD in minutes.
- No quality loss: Convert DVDs to various formats with no loss in quality, perfect for lossless playback.
- Video editor: The built-in editor lets you crop, trim, merge, and add watermarks or subtitles while ripping.
- OCR technology: Customize subtitles with OCR, extracting to SRT files or rendering them directly in videos for seamless playback.
- Multitasking mode: Add multiple ripping tasks to the Task Queue for consecutive conversions.
- Upscale video: Enhance video from 480p to 1080p without quality loss, with MP4.AI or MKV.AI as output formats.
How to Digitize DVD with This Tool:
Step 1: Download and install DVDFab 13.
Step 2: Click the Ripper module on the main screen. And then click the + button to upload the source file, or simply drag and drop the file to upload it. You can also insert the DVD you wish to rip into the drive.
Step 3: Click Choose Other Profile option and select Device. Now, select Microsoft from the list to choose the Xbox as the profile. If you wish to convert the DVD to a specific format you want, you must click the Format option.
Step 4: Once done, you can now personalize the video as per your needs. The movie title of the source will be selected by default. Yet, users can still select other titles here. Users can also tweak the title name by selecting the chapters, subtitles, and audio tracks as per their needs.
Step 5: While ripping the DVD to be compatible for PS4, users can also click the Wrench logo to personalize their settings such as frame rate, codec, and resolution, among others.
Step 6: In addition to this, users can also use the in-built editor to trim and crop the video, customize the aspect ratio, adjust picture values, and add watermark and subtitles, among other things.
Step 7: Now, on the main interface at the bottom section, tap the Folder logo to choose a path to save the end result. Next, click the Start option to begin the conversion process.
No, Xbox Series S does not have a disc drive. Microsoft earlier launched Xbox Series S, its secondary next-gen Xbox console together with Xbox Series X. The device offers a more reasonable entry point into the Xbox future, borrowing different features from its earlier flagship, but weakening the competition at a $299 cost. The Xbox Series S has its drawbacks, without weak graphical performance, but offers a lucrative cost for those selecting a new device.
To offer a console at less than $300, Microsoft took the Xbox Series X foundations but scaled back its features to the next-generation core values. It offers a console with the latest GPU and CPU architecture from AMD, the same personalized NVMe SSD technology, and many advanced features delivered at a higher cost. But the Xbox Series S has feeble hardware, in line with the cost. The device provides up to 1440p resolution at 120 FPS, instead of 4K baseline provided by Xbox Series X.
Yes. Microsoft made it obvious from the very beginning that the Xbox Series X shows support for a huge amount of backward compatibility for earlier Xbox games, particularly those for Xbox One. A 4K Blu-ray drive as a fraction of the hardware, indicates that users have got a very high probability of their Xbox One discs working without any trouble on their Xbox Series X, and in fact advantaging from possibly superior performance and faster loading times due to the enhanced hardware.
In summary, we looked at Xbox Series S queries. While it doesn't have a disc drive, you can play DVDs by converting them with DVDFab DVD Ripper, which supports over 1,000 formats. It allows customization via Profile Filter and Advanced Settings while preserving original sound and image quality. For Blu-ray content, DVDFab Blu-ray Ripper is also available.
