How to Clean DVDs
How to Clean Scratched DVDs
how to clean dirty dvd discs
  • Using Toothpaste
    • All you have to do is take a little bit of toothpaste and rub it on the DVD. Smear it in a circle to make sure that no stones are left unturned. With the help of water, clean the toothpaste.
  • Using Furniture Polish
    • Furniture polish can do wonders when it comes to cleaning DVDs. When using polish, all you have to do is rub the disc with the polish to make sure that every area is covered.
  • Using Repair Kits
    • The kits are able to get rid of most surface scratches on CDs and DVDs. A complete set kit often comes with a bottle of disc repair liquid, a bottle of disc cleaning liquid, and a soft cloth.
  • Using Banana
    • All you need is a banana and nothing else. Slice the peeled banana and smash a couple of slices. Smear the mashed banana onto the surface of the DVD in circles. Next, take out the peel and repeat the same process.
  • Using Vaseline
    • Rub a little bit of the Vaseline jelly on the scratched DVDs. Spray some cleaner or water on the disk and use a soft cloth to remove all the jelly. Do this until no Vaseline and water is left.
How to Clean DVDs with Heavier Grime and Stains
Materials You'll Need:
  • Soft microfiber cloth (or a lint-free, soft cotton cloth)
  • Distilled water (to avoid mineral buildup)
  • Isopropyl alcohol (preferably 70% or higher)
  • Mild dish soap (optional for heavy stains)
  • A soft-bristled brush (optional for stubborn grime)
  • Compressed air (optional, for removing dust)
Step-by-Step Cleaning Process:
  • Dust Off the Surface:
    • Before using any cleaning solution, blow off any loose dust and dirt from the surface of the disc. Use compressed air or gently wipe with a dry microfiber cloth in a straight line from the center to the outer edge (never in circular motions).
  • Prepare Cleaning Solution:
    • For mild grime, mix a small amount of mild dish soap with distilled water.
    • For more stubborn stains, you can use a mixture of isopropyl alcohol and distilled water (roughly 70% alcohol to 30% water ratio).
    • Avoid harsh chemicals like window cleaners or products with ammonia, as they can damage the disc.
  • Clean with a Cloth:
    • Dampen a soft microfiber cloth with the cleaning solution (don't soak it, it should be damp, not wet).
    • Wipe the disc gently from the center outwards in a straight line. This reduces the risk of leaving streaks or causing scratches.
    • Be sure to avoid circular motions, as these can damage the data layer over time.
  • Dry the Disc:
    • Use a dry, clean microfiber cloth to gently wipe the disc, again working from the center to the outer edge to dry it completely.
DVDFab DVD Ripper : The Best Solution to Clean DVDs
It is a good thing to back up physical DVDs by ripping the data somewhere safe. Ripping DVDs to an external hard drive or your computer can be very handy, thereby providing you with an easy way to get back your files in case your discs are scratched. This allows you to skip the usage of physical discs overall. And the best way to rip DVDs is using DVDFab DVD Ripper. The tool is an ideal choice to rip your DVDs. It can convert any DVD to different formats to save them digitally. The output format is compatible with different devices as well. Below are some noteworthy features of this tool. Have a look.
  • The tool provides out in less size but high quality
  • It helps to remove DVD protection easily
  • The tool comes with an in-built video editor that can be used to edit your videos
  • The tool works swiftly and performs ripping quickly using GPU acceleration
  • The tool supports more than 1000 formats
  • The tool helps to rip DVDs without quality loss
  • It users OCR technology to convert DVD subtitles to SRT file
  • The tool comes with multitasking mode to convert DVDs easily
  • It can upscale video using the AI enhancement
How to Rip a DVD with DVDFab DVD Ripper?
1. Download and install the tool on your PC. Open the tool and select Ripper module.
How to convert DVD to MP4 with DVDFab DVD Ripper
2. Insert the DVD into the drive. Allow DVDFab to access the disc automatically from your drive.
3. After the disc is loaded, click the Folder option at the output selection box to select your USB drive as the output folder. Go to the profile library through the Choose Other Profile button.
4. Next, select the desired format from Format >> Video >> General section. Choose the output video directory and tap the Start option to begin copying the DVD to the selected USB drive
Bonus Tip: Copy Your DVD Using DVDFab DVD Copy
Apart from ripping you can also copy your DVDs. This can be done easily with the help of a DVDFab DVD Copy. The tool can be used to copy DVD to different operating systems. It can be used for lossless backup and to compress any DVD. Also, the tool can also be used to export files to blank disc directly or save DVD as ISO/Folder on HDD. Below are some features of this tool:
  • The tool can easily backup DVDs for a great experience
  • It can help you remove any DVD copy protection for easy backup
  • It can get access to newly encrypted discs easily
  • It can easily copy DVDs with different modes
  • It can copy DVD as ISO/folder or to blank disc
  • It can compress any DVD to DVD-5
  • It supports batch copying with quick speed
How to Copy a DVD using DVDFab DVD Copy?
1. Download and install the tool on your PC. Select the Copy option on the main UI.
2. Add the DVD disc you want to back up into the drive.
how to clean an old dvd discs
3. Go to the left pane and tap the Copy mode as required. Select the output DVD size.
how to clean scratched dvd discs
4. Click the Start option to copy DVD as needed. The DVD Copy software will finish the DVD copy process with top quality and quick speed.
how to clean dvd/blu ray discs
Can a scratched DVD be repaired?
This entirely depends on where the scratch is located on the surface of the DVD. If the scratch is on the shiny top section of the disc, it is almost next to impossible to repair it. If the scratch is on the plastic bottom part of the disc, there is a chance for you to repair it.
Does toothpaste really fix scratches on a disc?
Actually, yes! Toothpaste can be used to get rid of scratches on DVDs. You can also use soap, warm water, and a cloth to clean the discs.
How do you fix a DVD that skips and freezes?
You can always use any of the methods mentioned above to solve the issue.
Having said that, you just had a look at different methods that can be used to know how to clean DVD discs easily at home. You also had a look at some precautions that can be take to avoid your DVDs from getting scratched. Using a ripper tool such as DVDFab DVD Ripper can be handy to backup your DVDs. Also, using DVDFab DVD Copy can help you copy your DVDs on your local machine or external hard drive.
