Are you looking for a way to entertain your passengers during long car rides? Look no further than a headrest DVD player! These convenient devices can provide hours of entertainment for both kids and adults alike. To help you choose the best option for your car, we’ve compiled a list of the 5 best headrest DVD players currently available on the market.
dvd players headrests
The 5 Best Headrest DVD Players for Your Car
Here is a comparison table for the 5 headrest DVD players mentioned:
Features XTRONS NAVISKAUTO WONNIE
PUMPKIN
SUNPIN
Screen Size
9 Inch
10.1 Inch 10.5 Inch 10.1 Inch 10.1 Inch
Resolution
800x480
1024x600 1024x600 1024x600 1024x600
Supported Formats
DVD/CD/MP3
/JPEG
DVD/CD/MP3 DVD/CD/MP3 DVD/CD/MP3 DVD/CD/MP3
Inputs
USB/SD
USB/SD/HDMI USB/SD USB/SD/HDMI USB/SD
Built-in Battery No No Yes No Yes
1. XTRONS 2 x 9 Inch Pair Car Headrest DVD Player
The XTRONS 2 x 9 Inch Pair Car Headrest DVD Player is easy to install and comes with everything you need to get started. The units attach directly to the headrests of your car seats, and the built-in speakers provide clear, high-quality audio. The screens are compatible with a variety of formats, including DVD, CD, MP3, and JPEG.
One of the best things about the XTRONS 2 x 9 Inch Pair is how versatile it is. Not only can it be used for in-car entertainment, but it can also be taken out and used as a portable DVD player. Its lightweight design and long battery life make it perfect for road trips, flights, or just lounging around at home.
best headrest dvd players
WHAT WE LIKE
  • Wireless IR/FM transmitter
  • Built-in USB port and SD card slot
  • It also has an FM transmitter
  • Dual screens for multiple viewing options
WHAT WE DON'T LIKE
  • HDMI port may be limited to certain devices
  • Touch screen can be sensitive
2. NAVISKAUTO 10.1" Dual Car DVD Players
NAVISKAUTO 10.1" Dual Car DVD Player can play two different movies simultaneously. This means that each screen can be used independently, allowing both passengers to watch their preferred content without interference. Additionally, the built-in speaker ensures that the sound quality is crystal clear, even in noisy environments.
With its anti-shock function, you don’t have to worry about bumps or rough terrain causing interruptions or damage to your discs. In terms of connectivity options, the NAVISKAUTO 10.1" Dual Car DVD Player doesn’t disappoint. It features SD and USB inputs, allowing you to play media from a variety of sources. And with its support for multiple file formats, you won’t have to worry about converting your files before hitting the road.
WHAT WE LIKE
  • Large screen size
  • Supports DVD/CD/USB/SD
  • Multiple media options
  •  Clear picture quality
WHAT WE DON'T LIKE
  • Limited connectivity options
  • May not support all file formats
3. WONNIE 10.5" Dual Portable DVD Players
The WONNIE 10.5" Dual Portable DVD Players are a set of two compact and lightweight DVD players that are perfect for on-the-go entertainment. Each player features a 10.5-inch LCD screen with a resolution of 1024x600, providing crisp and clear images.
These DVD players come with a built-in rechargeable battery that offers up to 5 hours of continuous playback, making them ideal for long road trips or flights. They also have a variety of playback options, including DVD, CD, USB, and SD card compatibility, so you can enjoy your favorite movies and music wherever you go.
WONNIE: best headrest dvd players
WHAT WE LIKE
  • Adjustable viewing angles
  • Can be used as standalone players
  • Supports multiple disc formats
  • The dual screens allow to watch different movies
WHAT WE DON'T LIKE
  • It has limited playback controls
  • Limited storage capacity
  • No Wi-Fi or streaming capabilities
4. PUMPKIN 10.1 Inch Dual Headrest DVD Player
This top-of-the-line device boasts a full HD 1080P display, which delivers crisp and clear visuals that are sure to keep everyone in the car entertained on long road trips. Plus, with its dual screen design, you can connect two separate headphones and enjoy hassle-free viewing without disturbing others in the vehicle.
The touch buttons of PUMPKIN headrest DVD player allow for convenient and straightforward control of features such as volume, playback, and more. You can also connect external devices such as USB drives or SD cards to play back your favorite multimedia files.
WHAT WE LIKE
  • Supports a variety of media formats
  • Provide a enjoyable viewing experience
  • Comes with headphone jacks
  • Easy to install and set up in most vehicles
WHAT WE DON'T LIKE
  • Limited compatibility with newer media formats
  • Limited adjustability in terms of screen angle and position
5. SUNPIN Portable DVD Player with 10.1" Dual Screen
SUNPIN Portable DVD Player features a user-friendly menu that allows you to navigate through different options effortlessly. You can also control the player using the included remote control, making it convenient for both kids and adults.
The 10.1-inch display comes with a resolution of 1024x600 pixels, which delivers sharp and vivid image quality. When it comes to power, the SUNPIN Portable DVD Player won’t disappoint you. The device comes with a built-in rechargeable battery that lasts up to five hours on a single charge. It also includes a car charger and an AC adapter, allowing you to charge it at home or in your car.
SUNPIN: best headrest dvd players
WHAT WE LIKE
  • Quality screen resolution
  • A 270-degree swivel screen
  • Supports various multimedia formats, such as CD, DVD, USB
  • Comes with an AV output and a headphone jack
WHAT WE DON'T LIKE
  • The built-in speakers may not provide the best audio experience
  • Does not have built-in Wi-Fi or streaming capabilities
Rip Your DVD for Playback on Any Device Without a DVD Player
Are you tired of carrying DVDs and a DVD player around just to watch your favorite movies or TV shows while on the go? Fortunately, there is a solution that can eliminate the need for a physical DVD player altogether. With DVDFab DVD Ripper, you can easily rip any encrypted DVDs and convert them into digital files that can be played on any device, whether it’s a smartphone, tablet, laptop, or even a smart TV.
DVDFab DVD Ripper
DVDFab DVD Ripper
DVDFab DVD Ripper allows you to rip and convert any DVD/ ISO file/ Folder to any digital video & audio format playable on any device, media player, or home theatre.
Win Download
100% safe&clean
Mac Download
100% safe&clean
 Key Features
  • The ONLY tool that can decrypt the newly purchased encrypted discs.
  • Rip and convert any DVD to MP4, MKV, MP3 WMV, and other 1000+ formats.
  • Support over 260 preset output devices, such as iPhone, and Huawei.
  • Offer customization and video editing tools.
  • Support batch DVD to digital conversion at GPU-accelerated speed.
  • Maintain the original quality or enhance the resolution using Enlarger AI.
How to rip a DVD with DVDFab DVD Ripper for Playback on Any Device?
Step 1: Simply insert your DVD disc into your computer’s DVD drive, launch the software, and select the option to rip your DVD.
Step 2: The software will scan the disc and present you with a list of titles that you can choose to rip. Please click on Choose Other Profile to choose a desired output format. You will have the option to customize audio tracks and subtitles, adjust video and audio settings, and more.
Step 3: Click on “Start” to begin the ripping process. Once the conversion is complete, you can transfer the digital file to any device of your choice and enjoy your movie or TV show on the go. No more lugging around a bulky DVD player or worrying about scratched discs. With DVDFab DVD Ripping software, you can take your entertainment with you anywhere.
Rip Your DVD using DVDFab DVD Ripper Without a DVD Player
After researching and reviewing a range of options, we have shortlisted the top 5 best headrest DVD players for your car. Each of these headrest DVD players has its unique strengths and caters to different needs. No matter which one you choose, you can rest assured that it will provide an enjoyable viewing experience for your passengers.
