The best way to enjoy your entire DVD collection of movies, homemade clips, or learning videos anytime on any device is to rip them to your computer and get a digital copy of the entire DVD collection. DVDFab and MakeMKV are the two most powerful rippers, allowing you to rip any DVD with maximum flexibility to ensure seamless streaming of the ripped DVD on any device, media, or player. So, let's see what is the best DVD ripper between DVDFab Vs MakeMKV.
What are DVDFab and MakeMKV?
DVDFab and MakeMKV are both Windows and Mac-compatible software that allows you to rip any DVD disc with flexibility and customization. Using these rippers, you can get ripped DVDs in all device-compatible formats. Therefore, they are playable and compatible with all OSs, devices, and media players.
What is DVDFab?
DVDFab DVD Ripper
DVDFab DVD Ripper
DVDFab DVD Ripper is one of the trending DVD rippers available in the market. It can make a digital copy of your entire DVD collection in the blink of your eyes. It offers lossless conversion of the file with 1:1 quality to ensure the original quality streaming with the ripped video. Along with ripping DVD discs, you can also rip DVD ISO image files or folders at your convenience.
If your DVD is copy-protected, DVDFab can instantly remove any kind of latest or old encryption. It lets you rip any DVD format, including DVD-9, DVD, etc. So, let's see what the major DVD-ripping functions of DVDFab are. Despite being a DVD ripper, DVDFab has other modules, such as a Blu-ray ripper and a UHD ripper.
👍Futuristic Functions
  • Using this service, DVDFab can remove any advanced encryption, such as RC, CSS, APS, etc., from any DVD with a few clicks.
  • With this extensive audio-video file format support, such as MP4, MKV, FLAC, M4A, WMA, etc., you can rip your DVD to any desired format according to your streaming device, platform, or storage requirements.
  • When ripping DVDs, DVDFab maintains the original quality of the ripped content with a 1:1 ratio while keeping all the essential information. All the metadata, like cast, title, cover, etc., will be synchronized with the source DVD, and eventually, the ripped DVD will have all the essential metadata.
  • No matter how long your DVD content is, you can fit multiple DVD content in one file by reducing the original file size without compromising the content quality. Using this lossless compression function, you can store multiple ripped DVD content in your device's limited storage.
  • DVDFab lets you enjoy digital copies of your DVDs in 5.1 AC3 audio quality with theatrical sound satisfaction.
  • DVDFab can rip any 2D or 3D content, as it has dedicated profile filters for ripping. It also lets you enjoy output video in HDR10 quality.
  • You can rip multiple DVDs simultaneously using the queueing function. You can keep multiple DVDs in the queues one by one, and they will be ripped one after another automatically to save time.
  • DVDFab offers exclusive video editing options with cropping, trimming, adding subtitles, watermark, etc, to give a personal touch to your ripped DVD for your flexible streaming.
❌Cons
  • DVDFab is not available on Linux OS
  • Technical support is available only in the paid version
What is MakeMKV?
What is MakeMKV?
MakeMKV is a free and open-source program for ripping DVDs to MKV format, one of the most common and device-compatible container file formats. MKV contains all types of multimedia content, so using MakeMKV, you can rip any DVD containing media content including audio, video, or images.
While ripping, this ripper preserves all the essential information, metadata, and multiple audio-video tracks in the ripped DVD without making any changes. This Windows, Mac, and Linux-compatible ripper is also very easy to use with its user-friendly interface and functions. So, let's see the most useful DVD-ripping functions of this tool.
👍Futuristic Features
  • The Ripped DVD file can be played on any media player or device
  • Decrypt DVDs having any latest and advanced encryption
  • All audio-video tracks, chapters & metadata will be preserved in your ripped DVD
  • Malware, spyware & virus-free DVD ripping tool
  • Fast & hassle-free DVD ripping process
  • It lets you rip multiple DVDs in batches
❌Cons
  • MakeMKV has only one output format, MKV format
  • There is no video editing or output parameters customization option
From June 16 to 19, 2025, MakeMKV official website was inaccessible due to a domain issue. Although it restored on June 20, this accident triggered discussion and concerns on various forums. Notably, some long-term users on Reddit pointed out that this was not an isolated incident. If reliability and stability are important to you, we suggest trying DVDFab, which offers a 30-day free trial version for DVD ripping.
How to use DVDFab and MakeMKV?
To decide what to choose between MakeMKV and DVDFab to improve your experience, you must know and compare the steps to comprehend both software from their practical usability.
Steps to Rip DVD using DVDFab
Step 1: Launch, open, and run the DVDFab program > go for the "Ripper" Module > put the DVD in the optical drive for ripping. Otherwise, hit the "+" option to load the video source. You can also go for the drag & drop option to load the video source to the main interface if the source video is an ISO image file or folder.
Step 2: Move to the "Profile Selection Box" > from the built-in library, and select the output profile format, such as MP4, MKV, etc., per your requirements.
Step 3: Go to the "Advanced Setting" to select the output parameters, such as subtitles, chapters, audio, etc., according to your choice. You can also try the built-in editor to edit the content with multiple options.
Step 4: Next, move to the Folder > choose directory to save your output ripped DVD > opt for the "Start" option to begin the DVD ripping process.
Steps to Rip DVDs using MakeMKV
Step 1: Go to the MakeMKV website and select the appropriate downloading link compatible with your system OS to launch the program.
Step 2: After launching the program, insert your preferred DVD into the optical drive. MakeMKV will automatically detect and show it. Select the DVD drive icon and the drive will be scanned automatically.
Step 3: MakeMKV takes a few minutes to detect and remove if there is any encryption, error, or unwanted file. After this process, you can see all the chapters of the inserted DVD
Step 4: The larger file refers to the main movie, and the other refers to the other content on the disc. You can rip the entire disc or any specific file as per your choice. Now, right-click anywhere in the chapter box > remove "Unselect All" to remove all the "Tick" signs from each chapter.
Step 5: Now, select the specific file that you want to rip and tick the relevant box according to your choice. Then select the "Title" option to open the drop-down menu and select your desired language for the movie. While scrolling through the subtitles, you can also select the subtitles.
Step 6: On the right side, you can see the "Output Folder," where you will save the ripped DVD. You can also change the location if you want. Select "MakeMKV" on the right side. Wait for a few minutes, and you will get the ripped DVD in MKV format.
The Main Difference Between DVDFab and MakeMKV?
To make the right choice between DVDFab Vs MakeMKV, you must first take a quick look at the most comprehensive comparison of the two based on their DVD-ripping functionality and flexibility.
DVD Ripping Dynamics DvDFab DVD Rippier MakeMKV
Compatible OS
Windows & Mac Windows, Mac & Linux
Ripping Speed
5 minutes for standard video 15 minutes for standard DVD
Output Format Support
Multiple formats (more than 1000 video and audio formats, such as MP4, MKV, AVI, MOV, etc.) Only MKV
Output File Size
Reduced size with lossless compression Large file size
Batch Processing
Yes Yes
Decryption
Full support (CSS, APS, RCE, Sony ARccOS, etc.) Built-in support for CSS and most standard protections
Video Resolution
HD to 8K output support
irrespective of source DVD resolution
Output in 480p
Audio Quality
5.1 AC3
DTS-HD MA Stereo
DTS-HD MA-AAC Stereo
Vedio Editing
Yes No
Device Presets
260 + No
Watermark Adding
Yes No
Meta Info & Subtitles Saving
Yes No
Is MakeMKV legal?
MakeMKV is legal as long as you use this program for personal and non-commercial purposes. If you own the disc you are ripping and are not sharing or misusing the ripped DVD files, it's legal to use MakeMKV. The legality also varies depending on the type of disc's encryption and the country where you have used the software. Before using, you should also check the disc terms and local laws.
Does DVDFab remove encryption?
Yes, using DVDFab DVD Ripper's Cloud Decryption Service, you can remove any type of old or latest encryption from any DVD disc. It automatically detects and eliminates the encryption from any DVD.
While comparing DVDFab Vs MakeMKV to select the best DVD ripper you must know that the more functions and customization will add more flexibility to your DVD ripping experience. You definitely need maximum output format support to compress and reduce file size with maximum device and OS compatibility. So, to compare the overall performance of MakeMKV Vs DVDFab, I think DVDFab will stay ahead with its unparalleled functions, customization, editing features and regular website maintenance.
