Generally, Android devices such as smartphones and tablets do not have built-in DVD drives to play physical discs. However, you can use an external DVD drive or an adapter to connect a DVD drive to your Android device and play discs. You would also need a compatible DVD player app installed on your device to play the DVD.
Alternatively, you can digitize your DVDs by ripping them to your device's storage. You have to first find a software program that can rip the DVD disc content to Android supported format, and transfer the same to your Android phone. This way, you will be able to access the content of the DVD.
Part 1: DVDFab DVD Ripper - Convert and Transfer DVDs to Android
DVDFab DVD Ripper
DVDFab DVD Ripper
DVDFab DVD Ripper is one of the best DVD Ripper software to rip and convert any DVD to various audio/video formats which can be played on almost all players. It is useful when you need to access data of a DVD on your phone. You can first rip and convert them to the format that your phone supports, and then transfer the content there, and access it.
Features of DVDFab DVD Ripper
  • Work on Windows 11/10/8.1/8/7 & Mac 10.10 - 13.
  • Rip any DVD to audio/video formats that are supported by mobile devices quickly. You can find more than 260 mobile presets to choose.
  • Customize the output content. You can choose chapters, audio tracks, subtitles, etc., and you can also use its built-in editor to edit your videos freely. Moreover, the Advanced Settings panel allows you to customize your settings.
  • Automatically synchronize all the meta info of the source DVD, including movie title, cast, and cover. All these info will be displayed on the media server.
  • Work with Enlarger AI to improve DVD video from 480p to 1080p.
  • Support DVD to digital conversion in batches at a faster speed.
Steps to Converting and Transferring DVDs to Android
Step 1: First of all, download DVDFab DVD Ripper software, and install on your computer.
Step 2: Launch the software once installed properly. Now, when it opens, click “Ripper”. You will see it asks to insert a disc or click add button to load a source. So, if you have the DVD that you want to convert, insert in the drive or have any DVD folder or ISO file, then load it here.
:How to Convert DVDs to Digital With DVDFab DVD to MP4 Converter Free
Step 3: Click on Profile Switcher "Choose Other Profile" to choose the output format. You can select Device option there, and choose the phone you are using. If your phone is not listed in the list, you can just select any format that your phone supports, and convert.
Step 4: Go to the bottom of the main interface to choose the “Mobile Device” as the output directory. Once selected, click “Start” to begin the ripping process. In few minutes ripping will be completed and the DVD source will be converted into Galaxy or other Android device you choose.
After the conversion is complete, there will be a small window for you to click the “OK” button. Once you click the “OK” button, you will be lead to a new window which will help you transfer your converted file to your Android phone. Just do as the instruction says.
Part 2: Best Android DVD Players to Play VOB Files on DVD
Real Player Beta
RealPlayer Beta is a media player app for Android devices developed by RealNetworks, Inc. It goes one step further and launched its own DVD player for Android which is in Beta but due to its name, it has already attracted so many eyeballs towards its intuitive interface and great features.
It is a free app that supports various video and audio formats, including MP4, AVI, MKV, and FLV. So it can play all the ripped file including VOB files without any issues. It also includes features such as playback speed control, equalizer, and video bookmarking. Additionally, RealPlayer Beta allows users to stream videos online and download videos from the internet.
a famous multimedia player
Mobo Player
MoboPlayer is a free media player app for Android devices, which supports various video formats, including MP4, AVI, MKV, and FLV, and provides advanced playback options such as subtitles, multiple audio tracks, and playback speed control. In any case, you have to rip and convert your DVD first, and then Mobo Player will be able to play that particular file of yours. It does support VOB file as well.
MoboPlayer also allows users to organize their media library by creating playlists and easily switching between different video folders. Additionally, the app provides an intuitive interface with gesture controls for easy navigation while playing videos.
Android dvd player
Rock Player Lite
Rock Player Lite is another Android DVD Player which cannot play the DVD directly but when you rip that off and then transfer to your phone, it will help you play that ripped video. The app features hardware acceleration for smoother video playback, subtitle support, and playback speed control. Additionally, RockPlayer Lite allows users to browse and play videos directly from their device's memory card or internal storage.
The Lite version of the app is free and includes ads, so it might be annoying at times. But a paid version is also available that removes the ads and offers additional features.
android dvd player which cannot play dvd directly
VLC Media Player
VLC Media Player is a free and open-source media player app for Android devices developed by the VideoLAN team. It supports a wide range of video and audio formats, including DVD ISOs, and provides advanced features such as subtitle support, playback speed control, and audio equalizer.
Additionally, VLC for Android allows users to stream videos from various sources, including local network drives and online services. The app also includes a widget for quick access to playback controls, and users can customize the interface with various skins.
VLC media player which can play any ripped or converted files
KM Player
KM Player is another player on our list that can play VOB files with good quality. Its simple user interface and clean UI will make you fall in love with it. It has inbuilt audio/video codecs. Apart from VOB files, it can play a wide range of file formats as well. Even it supports 3D file formats.
 The app also includes a floating screen feature that allows users to multitask while watching videos, and users can customize the skin of the interface. Overall, KMPlayer is a versatile media player app with a wide range of features and good compatibility with various file formats.
KM player which can play VOB files
There are no multimedia players for Android that can play DVDs, thus ripping the DVD and converting them into a mobile supported format is the best choice. DVDFab DVD Ripper does the job pretty well as described in Part 1. Also, a list of 5 best Android DVD players that can play VOB files is what we have shared as well. Hope you find this article useful.
