Top 3 Best Blu-ray Copy Software Programs: Reviews & How-to
Summary: Sometimes you may need to copy or burn your Blu-ray movies for backup. To do that you have to turn to a Blu-ray copy tool. Here we have reviewed 3 best Blu-ray copy software programs to help you make Blu-ray copies easily.
Don't we all prefer watching Blu-ray movies and videos over and over again? But what if your DVD and the Blu-ray movies get affected by scratches, fingerprints, loss, damage etc.? In such situations, having a backup of the Blu-ray movie is beneficial.
Blu-ray copy software aids in creating a copy of the original file that can be played on any popular Blu-ray player or saved on your computer's hard drive. But with so many Blu-ray copying software available online, choosing the best one can be challenging. In this article, we list the best Blu-ray copy software programs to help you make a choice.
3 Best Blu-ray Copy Software Reviews: Pros and Cons
DVDFab Blu-ray Copy
DVDFab Blu ray Copy software is known to be the first fully-featured Blu-ray copier, that is strong enough to remove any Blu-ray copy protection (including AACS, BD+, BD-J, RC, Region Code) and copy any kind of Blu-ray video or movie to any kind of Blu-ray output (DVD/AVCHD disc, ISO image, or folder).
An important characteristic of DVDFab is that it completely supports any 3D or 2D Blu-ray. You can copy any BD 50 3D to BD 25 3D in the very original format. You can also copy 3D Blu-ray to 2D Blu-ray or Blu-ray SBS 3D while also maintaining the 3D effects.
💻Available on: Windows 11/10/8.1/8/7 & Mac 10.10 - 14
Pros:
- Bypass copy protection from any Blu-ray disc, both old and new releases.
- 1:1 copy Blu-ray to blank Blu-ray/DVD, or save as an ISO file or folder.
- Copy and burn ISO files or folders onto Blu-ray/DVD discs.
- 5 Blu-ray copy modes: Full Disc, Main Movie, Customize, Clone/Burn and Merge.
- Allow selecting chapters, titles, audio tracks, subtitles, and add external subtitles.
- Offer batch Blu-ray copying mode at GPU-accelerated speed.
- Remove Cinavia to offer clean audio when copying Blu-ray
Cons:
- The free version only support two Blu-ray copy modes: Full Disc and Main Movie.
Leawo Blu-ray Copy
Using Leawo Blu-ray Copy software, Blu-ray can be backed up to ISO image or folder in order to save on your computer hard drive. It makes way for you to copy Blu-ray disc content to blank BD50 or BD25 disc or your hard drive in the form of ISO image or folder. Discs originating from various places can also be backed up.
Moreover, it also has the capacity to copy 3D Blu-ray movies without having to let go off the 3D effect. The resultant audio quality and image quality are kept as far as possible, similar to the original quality. You can bring about 1:1 disc duplication without compromise on the quality. There are also many more customization options like subtitle and audio track options etc.
💻Available on: Windows 7/8/8.1/10/11 & macOS 10.13/10.14.../13/14
Pros:
- Copy Blu-ray disc released in different places.
- Perfect 1:1 Blu-ray and DVD copying without quality compromise.
- Support to copy Blu-ray with 2D and 3D effects
- 3 Blu-ray Copy Modes: Full Movie, Main Movie, and Custom.
- Select and retain subtitles and chapters from discs.
- Instant ISO image burning to discs.
- Good Blu-ray copying and compression speed.
Cons:
- It can't bypass advanced Blu-ray copy protections.
- Limited features in free trial version.
- No subtitle converter to upload external compatible text.
- The software sometimes leaves residue on the disc after copying, indicating an unfinished task and requiring users to take additional steps.
Blue-Cloner
Blue-Cloner was created by a company known as Open Cloner, specializing in digital media distribution. It is mastered at making a perfect 1:1 Blu-ray copy, a complete movie copy, movie-only copy, split and customized copy.
This Blu-ray copy software is also capable of copying Blu-ray movies to DVD and AVCHD disc. It is good at removing region codes, hence letting you play the copied Blu-ray version in any region. The company introduces constant updates and as a result, Blue-Cloner 5 can copy any Blu-ray movie in the market. The copy speed is also enhanced up to a large extent.
💻Available on: Windows 7/10/11
Pros:
- Dual UI Modes: Express mode for one-click Blu-ray copying and Expert mode for advanced copy tasks.
- Bypass various protection protocols and remove Cinavia watermarks.
- Copy Blu-ray to blank BD-R/RE (DL) discs or to hard disk as folders or ISO files.
- 4 Blu-ray copy modes: Complete movie, Movie-Only, Split, and Customized.
- Support to select audio tracks and subtitles.
- Split a 50G movie into two 25G discs.
- Leverage advanced technologies for faster Blu-ray copying.
Cons:
- The trial version lasts for 7 days but allows only a single Blu-ray copy.
- No support for 3D Blu-ray copying or maintaining 3D effects.
- Some Amazon users have reported difficulty with the installation process, with frequent failures noted.
How to Copy Blu-ray Disc with the Best Blu-ray Copy Software?
After critically reviewing the three best Blu-ray copy software, we highly recommend DVDFab Blu-ray Copy. This software is widely recognized for its robust Blu-ray decryption and copying capabilities. Moving forward, we will use this product as an exemplar to guide you on how to burn a Blu-ray with ease and efficiency.
Step 1: Lauch DVDFab Blu-ray Copy software and load the source file
Free download DVDFab 13 and choose the "Copy" module when it runs. Insert your Blu-ray disc into the attached Blu-ray drive, or click the "Add" button to load the source. You can also drag or drop the source ISO file or folder onto the main interface.
Step 2: Choose one copy mode and customize the output Blu-ray disc
Go to the left pane and click the Copy Mode switcher to choose your desired one. Then customize the volume label, output size, and other advanced settings.
Step 3: Let the best Blu-ray copy software to copy your Blu-ray
Finally, click the Start button to start the copying process. You can learn the detailed progress info or cancel the Blu-ray copying task any time as you want.
Yes, it is generally considered legal to use Blu-ray copy software programs for personal use. This would include creating backup copies of discs that you already own. However, selling or distributing copied Blu-rays for commercial use would be illegal. Please note, while the best Blu-ray copy software programs itself is legal, how it is used must comply with the law.
Yes. You may use DVDFab Blu-ray copy to clone your Blu-ray disc into a digital ISO file or folder. Or, you can use Blu-ray ripper software to rip your Blu-ray disc into a digital video format. DVDFab is a versatile program that can meet your Blu-ray copying and ripping needs.
In conclusion, we have reviewed the top three best Blu-ray Copy Software to help you understand their strengths and weaknesses. With the right software, copying Blu-ray disc can be a breeze, ensuring high-quality duplicates for your enjoyment.
