As a movie enthusiast, you must understand the importance of preserving the high quality of your Blu-ray collection. Blu-ray discs offer exceptional video quality, immersive audio, and large storage capacity—perfect for HD and even 4K Ultra HD content. If you own a large-screen TV or a Blu-ray player, creating your own Blu-ray movies is a great way to enjoy and preserve your favorite videos. This guide shows you how to burn high-quality Blu-ray discs using reliable Blu-ray burning software for Mac and Windows.
How to burn blu-ray discs?
How to Burn Blu-ray Disc Compatible with Any Blu-ray Player
DVDFab Blu-ray Creator: burn blu-ray disc
With this powerful Blu-ray Creator, you can create a Blu-ray disc, ISO image, or folder from any type of video, as well as create your own Blu-ray menu using stylish templates and customizable options.
Features of DVDFab Blu-ray Creator
  • Burn 200+ formats of videos to a high-quality Blu-ray disc, ISO file or folder.
  • Choose the output as BD-R, BD-RE, BD-50, BD-25, BD-9, BD-5.
  • Synchronize the metadata information of the source videos on the Blu-ray menu.
  • Boast multiple free and stylish menu templates and allow you to customize them.
  • Allows you to select audio tracks and subtitles, as well as add external subtitles.
  • Burn multiple videos to one Blu-ray disc and arrange their playback order.
  • The burning speed is quite better with GPU acceleration.
How to Burn Blu-ray Movies using DVDFab Blu-ray Creator?
Step 1: Download DVDFab Blu-ray Creator, and install it on your PC.
Step 2: Launch the software and you will see the clean user interface with options such as Copy, Ripper, and Creator. You need to click on "Creator" and go to "Creator Mode" to choose Blu-ray Creator. Then, click the "+" icon to load the video file or simply drag it to this interface.
can you burn blu ray discs using DVDFab Blu-ray Creator?
Step 3: Now, you can customize the output Blu-ray disc by clicking "Advanced Settings" and "Menu Settings". You can also choose the audio tracks and subtitles, or add external subtitles.
How to burn blu ray movies using DVDFab Blu-ray Creator?
Click on Menu Settings and you can set the Blu-ray disc's menu page. Here you can personalize all the element and widgets in the menu templates, including background art and music, thumbnails, text font, color, and size, as well as playback buttons such as Play/Pause and Previous/Next.
How to burn a Blu-ray disc using DVDFab Blu-ray Creator?
Step 4: Now, select the directory for the output Blu-ray. If you want to burn your video to a Blu-ray disc that can be played on a physical Blu-ray player, you must select your optical drive in the directory. If you want to convert the video to a Blu-ray ISO file or folder, just click the "ISO" icon or the "folder" icon to select a directory. Finally, click "Start" to initiate the burning process.
How to Burn Blu-ray discs using DVDFab Blu-ray Creator?
How to Burn a Blu-ray Disc with Free Blu-ray Burners
If you only needs basic burning capabilities and do not require advanced features or customization options, a free Blu-ray burning software may be sufficient for your need.
How to burn blu ray movies for free?
ImgBurn is a popular free software used for burning image files to physical discs, such as CDs, DVDs, and Blu-ray discs. This Blu-ray burner allows users to create high-quality Blu-ray discs from image files, such as ISO, BIN, and IMG files. You can also write data directly to Blu-ray discs, or create ISO files from Blu-ray discs.
ImgBurn supports a wide range of Blu-ray disc types, including single-layer and dual-layer discs, as well as BD-R and BD-RE discs. It also offers some options for customizing the burning process, such as setting the burning speed, verifying the disc after burning, and creating bootable Blu-ray discs.
PROS
 A free option for burning Blu-ray discs
 Supports a wide range of disc formats
 Allows users to control the burn speed
 ImgBurn has a user-friendly interface
CONS
 Lack of advanced Blu-ray authoring features
 Does not come with technical support
 Additional adware may be installed
 Only Windows operating systems are supported
How to Burn a Blu-ray Disc on Windows 10 with ImgBurn?
Step 1: Download and install ImgBurn from the official website on your Windows computer. Insert a blank Blu-ray disc into your Blu-ray burner drive. Then open ImgBurn and select the "Write image file to disc" option.
How to burn a blu ray disc with ImgBurn?
Step 2: Click on the "Browse for a file" button and select the Blu-ray disc image file (.ISO or .IMG) that you want to burn to the disc.
How to burn blu ray disc with ImgBurn?
Step 3: Set the burning speed and verify that the Blu-ray burner drive is selected as the destination. Click on the "Write" button to start burning the Blu-ray disc.
How to Burn Blu-ray Disc from Blu-ray Disc/ISO/Folder
While DVDFab Blu-ray Creator converts videos into Blu-ray format, its sibling Blu-ray Copy specializes in precision duplication. This tool clones existing Blu-ray disc/ISO/folder to blank discs with surgical accuracy, preserving every menu animation and Dolby Vision enhancement.
DVDFab Blu-ray Copy
DVDFab Blu-ray Copy
Allows you to losslessly backup or compress any encrypted 2D/3D Blu-ray to blank disc directly or save them as ISO or folder. It offers five copy modes to meet your diverse needs, which include Full Movie, Full Disc, Customize, Clone/Burn, and Merge.
Features of DVDFab Blu-ray Copy
  • Remove any copy protection from old or latest Blu-rays to enable backup.
  • Copy any Blu-ray to blank disc or save it as ISO file or folder for playback.
  • Losslessly backs up a disc to BD-50 or compress it to common BD-25.
  • Clone and burn your Blu-ray in a 1:1 ratio with no quality loss.
  • Copy any 3D Blu-ray disc and better preserve the 3D effects.
  • Get faster Blu-ray copying speed with GPU-accelerated technology.
  • Work with Blu-ray Cinavia Removal to process Blu-rays that are protected by the Cinavia watermark.
How to Burn a Blu-ray to Blank Disc with DVDFab Blu-ray Copy?
Step 1: Download the DVDFab Blu-ray Copy, and then install it on your PC.
Note: Both DVDFab Blu-ray Creator and Blu-ray Copy are installed in one package, DVDFab 13. Download once, and you can freely explore all the function modules of DVDFab.
Step 2: Launch the software and you will see its clear user interface. Click on the "Copy" option and then choose the "Clone/Burn" copy mode. Next, click the "+" icon and locate the Blu-ray disc. If it is an ISO file or folder, just drag it to the UI to load it.
How to Burn Blu-ray on mac and windows 10?
Step 3: After the source is loaded, you can go to Advanced Settings to set the volume label and choose to keep protection or not. You can also click the Play button to preview your Blu-ray video.
How to Burn Blu-ray movies with DVDFab Blu-ray Copy?
Note: Under the Clone/Burn copy mode, your Blu-ray disc will be burned in a 1:1 ratio, so there are no customized options. If you want to copy Blu-ray disc with more customized settings, just choose the Main Movie mode. As the following main interface shows, you can choose the titles, chapters, audio tracks, and subtitles you want to burn. You can also add external subtitles.
How to Burn Blu-ray with DVDFab Blu-ray Copy?
Step 4: Finally, select your optical drive as the output location and click "Start" to begin the burning process. You will see the progress window, and in some time the Blu-ray will be copied. Once the process is done, you can go ahead, and check out the copied Blu-ray at the output location, and you will find that it’s done successfully.
How to Burn a Blu-ray to a Blank Blu-ray Disc with DVDFab Blu-ray Copy?
What do I need to burn a Blu-ray Disc?
To burn a Blu-ray disc, you will need:
  • A Blu-ray Disc Drive: This can be either internal or external and is necessary to burn Blu-ray discs.
  • Blu-ray burner software: This program enables you to burn videos onto a Blu-ray disc. It improves the accuracy of the burning process and makes it more efficient.
  • A blank Blu-ray disc: There are different types of Blu-ray discs, such as BD-R (write-once) and BD-RE (rewritable). Choose one that suits your needs.
  • Data to burn: This could be video, audio, images, documents or any other type of digital content.
  • Computer with enough processing power and storage space: The exact requirements will depend on the size of the data you're burning and the software you're using.
Which Blu-ray disc should I choose for burning?
When choosing a Blu-ray discWIKI for burning, you have several options, such as:
  • BD-R (Blu-ray Disc Recordable): This is a one-time use disc where data can be written onto it but cannot be erased or rewritten.
  • BD-RE (Blu-ray Disc Rewritable): Data can be written to this type of disc, erased, and then rewritten. They are helpful if you need to change or update the content regularly.
  • BD-XL: These discs come in two varieties: BD-R XL and BD-RE XL, which are recordable and rewritable versions respectively. They have larger capacities of 100GB and 128GB compared to the standard 25GB (single-layer) or 50GB (dual-layer).
Is it possible to burn 3D Blu-ray movies?
Yes. First, you need to find software that supports the 3D format you are using (e.g. side-by-side, top and bottom), such as DVDFab. In addition, please prepare a Blu-ray recorder and a blank Blu-ray disc that supports the 3D format.
Remember to test your 3D Blu-ray movie on a compatible 3D Blu-ray player and TV to make sure the 3D format plays as expected.
In short, burning a Blu-ray disc is an easy task once you are equipped with the right tools. DVDFab Blu-ray Creator and Blu-ray Copy are two such powerful software that can help you achieve this with ease. Whether you want to burn Blu-ray movies or duplicate an existing Blu-ray file, these tools provide a streamlined and efficient process.
