How to Copy Blu-rays to PC Free and Easily? [2025 Update]
Summary: Get ready to discover some of the easiest and free methods to copy Blu-ray discs. Whether you're a Windows or a Mac user, these handy techniques have got you covered. Read on to explore the top 3 ways of copying Blu-ray movies to PC, hard drive, or blank discs.
- Is it legal to copy Blu-ray discs to a hard drive?
- How to copy Blu-ray movies from a disc to my laptop?
- What is the best Blu-ray copy software?
These are a series of questions on Blu-ray copy are posted on Quora. In this article, we will go over these Blu-ray copying questions in order to help you find your solutions.
What Do You Need Before Copying Blu-ray Disc?
Before copying Blu-ray discs, there are several crucial things you need to prepare in order to perform this task successfully.
Top 3 Ways to Copy Blu-ray Discs on Windows and Mac
If you're a movie lover with a large collection of Blu-ray discs, you might want to make the most of them by making backups for watching on other devices. With the right software, coping Blu-ray can be easy and stress-free. Now, let's take a deeper dive into the best ways to copy Blu-ray on Windows and Mac.
Way 1: Copy Blu-ray to PC/Hard Drive with DVDFab Blu-ray Copy
With its user-friendly interface, this copier enables you to customize your Blu-ray copy through 5 modes – Full Disc (Copy all the BD content with or without compression), Main Movie (Copy the main movie title of BD with or without compression), Customize (Copy any titles/chapters you desire from the BD), Clone/Burn (Clone BD in a 1:1 ratio with no quality loss), and Merge (Merge multiple BD content into one BD).
💻Available on: Windows 11/10/8.1/8/7 & Mac 10.10 - 14
👍Key Features:
- Remove any copy protection from old or latest Blu-rays to enable backup.
- 1:1 Copy any Blu-ray disc to blank disc or save it as an ISO file or folder to PC.
- Copy and burn any ISO files or Folders to Blu-ray disc.
- Lossless backup a disc to BD-50 or compress it to common BD-25.
- Copy any 3D Blu-ray disc and better preserve the 3D effects.
- Support batch Blu-ray copying mode.
- Get faster Blu-ray copying speed with GPU-accelerated technology.
- Remove Cinavia and copy Blu-ray as clean audio.
👎Cons:
- The trial version only support two copy modes.
How to Copy Blu-ray Discs with DVDFab Blu-ray Copy:
Step 1: Launch DVDFab and load your source Blu-ray.
Free download, run DVDFab 13, and opt for the Copy module when it runs. Insert the BD disc into the attached Blu-ray drive, then the software will recognize it automatically and show you what to do next. You can also click the Add button or drag & drop an ISO file or folder onto the main UI.
Step 2: Choose one copy mode and customize the output Blu-ray.
First, choose a mode before you get started. There are nine modes available at present, and each of them represents what kind of output you want to acquire at the end.
Then, you can define the volume label and change other Blu-ray copy options including output size, titles, chapters, audio tracks and subtitles.
Besides, you can also adjust other Settings according to your preferences. Click the "Advanced Settings" and you will see a couple of buttons which stand for various purposes such as audio option, Cinavia protection disablement, HD Audio Removal.
Step 3: Select an output directory and tart to copy Blu-rays
Finally, select your output directory as a blank disc, ISO file, or folder, and click the Start button. You can get detailed progress information or cancel the Blu-ray copy task anytime you like.
Way 2: Copy Blu-ray Disc with Blue-Cloner
Blue-Cloner is a Blu-ray copy software compatible with all Windows systems that effectively that can easily copy Blu-rays and 4K UHD movies. It offers diverse features including perfect 1:1 Blu-ray copy, complete movie copy, movie-only copy and split copy. This Blu-ray decrypter can also permanently remove Cinavia watermarks from audio tracks, enabling the backup discs to be played on various devices like PS3, PS4, Xbox One, DVD Players and more.
💻Available on: Windows 7/10/11
👍Key Features:
- Copy Blu-ray movies to blank discs or as Blu-ray folders or ISO image files.
- Bypass some Blu-ray protections and remove Cinavia watermarks.
- Allow copying entire Blu-ray disc excluding unnecessary extras.
- Enable duplicating just the main movie, smartly detecting the primary content.
- Divide a large Blu-ray movie into two smaller discs with option to retain menus.
👎Cons:
- The trial version allows for 1 Blu-ray copy only.
- Unable to select the preferred title, subtitle, or audio to retain.
- Unable to copy 3D Blu-ray movies or preserve 3D effect.
- Some users have reported on Amazon that the program installation process is complicated and often fails.
How to Copy Blu-ray Disc with Blue-Cloner:
Step 1: After installation, launch Blue-Cloner. You will by default be presented with the Express interface. If it's not visible, locate and click on the "Switch to express" icon at the top right corner.
Step 2: Insert the Blu-ray movie you want to copy into your Blu-ray drive. The software will recognize the disc and show the movie name and size in a scrolling bar. Once the source Blu-ray movie is detected, click the "Start" button to initiate the copying process.
Step 3: When data reading is finished, you will be prompted to insert a blank disc. If you're using two drives – one for reading and one for burning – you can insert the blank disk before starting the task. After placing a blank BD-R/RE, the software will initiate the burning process.
Step 4: The completion screen will be displayed once the burning process is fully completed. Enjoy your cloned Blu-ray movie.
Way 3: Copy Blu-ray Movie with BurnAware
BurnAware is another reliable Blu-ray copy software known for its user-friendly interface. Compatible with most Windows OS versions, it clearly outlines every step to copy a Blu-ray movie. Besides copying CD, DVD, and Blu-ray movies, it can also extract audio files, recover data and create image files. Not only does BurnAware back up your videos directly to your hard drive, but it also allows you to view them on any computer without loss of data.
However, BurnAware is unable to directly copy a Blu-ray disc. The process is quite intricate: Initially, the disc is copied to generate a temporary ISO image on your hard drive. Subsequently, this ISO image is burned onto a new disc.
💻Available on: Windows Vista 7, 8, 10, 11
👍Key Features:
- Copy discs to ISO and BIN disc images
- Back up multisession discs, ensuring none of your data is lost.
- Recovery from damaged or unreadable discs
- Burn ISO images onto multiple discs simultaneously.
👎Cons:
- "Copy disc" is only available in Premium and Professional editions.
- It can only copy unprotected Blu-ray discs.
- The package includes additional software.
- It doesn't support selecting titles, audio tracks, or subtitles.
How to Backup Blu-ray Movies with BurnAware:
Step 1: Open the main window and select the Disk Backup or Copy Disc icon, after that choose your drive where the Blu-ray source to be copied is located in a new window.
Step 2: Configure Copy Settings
- Copy Disc: this option allows you to back up your Blu-ray as a single ISO file on your PC, which you can mount to play directly.
- Disc Backup: this option will copy the original Blu-ray contents directly to the new disc.
Step 3: Identify the destination drive in which the copied data will be stored.
Step 4: Initiate the copying process by clicking the Copy button.
Comparison of tools for copying Blu-ray movies
In the following table, we will draw a comprehensive comparison among three selected Blu-ray copiers in terms of their main features, intending to help you scrutinize and choose the most suitable software that meets your requirements for copying Blu-ray discs.
Features | DVDFab Blu-ray Copy | Blue-Cloner | BurnAware |
Supported OS | Windows & Mac | Windows | Windows |
Copy protected Blu-ray | Support any old or new Blu-rays | Only support some Blu-rays | No |
Blu-ray Copy modes | 5 | 4 | 1 |
Copy a Blu-ray to Disc | YES | YES | YES, but the process is complicated |
Copy Blu-ray to PC / Hard Drive | YES | YES | YES |
Select title, audio, or subtitle to copy | YES | NO | NO |
Copy 3D Blu-ray | YES | NO | NO |
Copy Blu-rays in Batch | YES | NO | NO |
User Rating | 4.6/5 (Trustpilot) |
N/A | 4/5 (techradar) |
The legality of copying a Blu-ray disc varies from country to country. In general, making a copy of a Blu-ray disc you personally own for backup or personal use is often considered legal under fair use laws in some countries. However, if you're interested in making copies for commercial use or distribution, that may be illegal.
How to Duplicate a Blu-ray Disc to Hard Drive?
You can use a Blu-ray copier to copy Blu-ray discs to your computer hard drive in the format of ISO file or Folder. Alternatively, you can use a Blu-ray Ripper and rip and copy Blu-ray disc to hard drive in digital formats. Let's taking DVDFab Blu-ray Ripper as an example to show the simple steps:
- Step 1: Open DVDFab Blu-ray Ripper on your computer and load your Blu-ray movie.
- Step 2: Choose an output format compatible with your computer hard drive.
- Step 3: Customize and edit your Blu-ray movie if you want.
- Step 4: Start to copy your Blu-ray to hard drive.
What's the Difference between Ripping Blu-ray and Copying Blu-ray Discs to PC?
Ripping refers to extracting and converting the contents of a Blu-ray Disc into a digital format compatible with various devices. Duplicating a Blu-ray Disc means cloning or copying the entire disc or its file structure to a computer or another Blu-ray Disc. For details, please refer to the comparison table below.
Aspect | Ripping | Copying |
Output | Digital video and audio file | Disc, ISO image or Blu-ray folder |
Playback | Portable devices with more versatile | Requires Blu-ray player software |
File Size | Smaller (compressed, if desired) | Larger even when compressed |
Quality | Can be lossless or lossy | 100% lossless (original quality) |
In summary, you can efficiently copy a Blu-ray disc to your computer with the right tools. Although there are many options available, the three products presented here are the best solutions, especially the Blu-ray copying software from DVDFab, whose excellent performance ensures that you can accomplish the Blu-ray copying task with precision.
