StreamFab Netflix Downloader
Download movies and TV shows in 1080P from all Netflix regional sites with HDR 10 or Dolby vision and Atmos/EAC3 5.1 audio.
Windows
Mac
Try for Free
100% Safe & Clean
Last Update: Nov 22, 2024
  • Download videos from all Netflix regional sites
  • Download new Netflix episodes and movies at a scheduled time
  • Download Netflix videos in 1080P with HDR and Dobly vision
  • Explore Netflix videos with its in-built browser
StreamFab: Have for Binge-Watching Fantasy!
  • Advanced Technology
  • Reliable and Verified
Industry's leading downloader solution
Netflix offers an offline watching function, but there are certain download limitations in place. Not all titles can be downloaded, and the downloads are limited to mobile devices. Moreover, the downloaded videos usually become unavailable after 30 days, and if you start watching them, you must finish within 48 hours.
However, movies and episodes downloaded with StreamFab Netflix Downloader can be stored permanently and transferred to your devices for viewing anytime, anywhere.
netflix video downloader
Trusted by 80+ million users globally
As one of the best Netflix video downloaders, StreamFab has been downloaded 100+ million times and has become a trusted choice for 80+ millions of users worldwide.
StreamFab Netflix Downloader has received praise from numerous users on reputable platforms such as Trustpilot, G2, and Reviews.io. The download success rate for Netflix movies and episodes reaches as high as 99%.
globally used netflix video downloader
Enjoy Flexible Outputing with StreamFab Now
  • Excellent Downloading Quality
  • Multiple Format Available
  • Optional Video Codec
  • Save and Remux SRT Files
Flexible choice on Netflix video and audio quality
HDR technology enables higher image quality than traditional standard videos, therefore streaming platforms like Netflix offer a plethora of 1080P videos supporting HDR10 and Dolby Vision.
With StreamFab, you can download Netflix movies on Mac and Windows PC or laptop, and maintain Netflix 1080P quality, preserving the original HDR and Dolby Vision effects, and choose the audio quality of Atmos, EAC3 5.1, and AAC 2.0 based on your needs.
*Content in HDR and Dolby Vision can only be accessed by subscribers of Netflix’s premium package.
download netflix video in HD quality
Download Netflix movies and episodes as MP4/MKV files
The video files downloaded from Netflix are DRM protected, and can only be played through the Netflix app. However, with StreamFab Netflix Downloader, you can save Netflix to MP4 or MKV files, eliminating any compatibility concerns.
This allows you to watch Netflix offline on most devices and facilitates the transfer of Netflix videos between multiple devices, including smartphones, tablets, laptops, gaming consoles, etc.
Download Netflix videos in H.264/H.265/VP9/AV1 video codec
Netflix typically offers videos in four types of video encoding: H.264/H.265/VP9/AV1. For the same video, H.265 is smaller in size compared to H.264. When using StreamFab Netflix Downloader, you have the option to select between the H.264, H.265, VP9, and AV1 codecs. If storage capacity is a concern for you, it is advisable to opt for H.265, otherwise, choose H.264 videos.
*H.265 only supports HDR 10 and Dolby Vision. It does not support H.265 SDR streaming videos.
Save subtitles as SRT files or remux into Netflix video
When using StreamFab Netflix Downloader to download movies and episodes, you have the option not only to download Netflix subtitles in multiple languages, but also to freely choose whether to save the subtitles as SRT files or to integrate them back into the video. The choice is yours!
download netflix video with sub
Perfect Netflix Downloading Experience You Get
Schedule Mode and Auto Download
Download newly released Netflix episodes or movies automatically at a set time
Batch Mode and Fast Speed
Add multiple Netflix episodes and movies to the download task queue. Generally, a 2h full movie on Netflix can be finished within 30 minutes
Preset Audio & Subtitle Language
Pre-select audio and subtitles of Netflix movies or episodes for downloading as per the default UI language
Remove Ads
Regardless of the type of Netflix Plan subscriber you are, you can download ad-free videos through StreamFab
More Than Downloading
Download Media Server Friendly Metadata Info
You can have all the meta info such as title, cast, and cover right there when your Netflix video is downloaded. This Netflix video downloader make it effortless to create and manage your ideal Netflix library with media servers such as PlayerFab, Plex, Kodi or Jellyfin.
Import downloads to Blu-ray Creator and convert them to Blu-ray format
The Netflix videos downloaded with StreamFab can be automatically imported to DVDFab Blu-ray Creator where you can convert these Netflix videos to standard Blu-ray format so that you can enjoy them on home theatre with your family.
Free Download StreamFab Netflix Downloader and Try It Now!
Try for Free
100% Safe & Clean
80+ Millions of People Like Us
How to Download Netflix Videos with StreamFab
  • launch StreamFab Netflix Downloader
    Select the StreamFab Netflix Downloader.
    Install StreamFab Netflix Downloader and launch it on your computer.
    Play a video from Netflix
    play Netflix videos
    Start to download the video
    download Netflix videos
System Requirements
  • Windows 11/10 (32/64 bit)
  • Intel i3 or above
  • 4GB of RAM or above
  • 40GB of free hard disk space or above
  • Live Internet connection required
Tips & Tricks for Downloading Netflix Video
