Wonderfox DVD Ripper (Pro) Review and Its Best Alternative
Summary: This article provides an in-depth and objective WonderFox DVD Ripper Pro review. It explores features, ripping speed, and overall quality of this software to give you a clear idea of how to make the most of it. It also introduces the best alternative if you have a bad experience with Wonderfox.
WonderFox DVD Ripper is a versatile program that allows you to extract video and audio files from DVDs and convert them into various digital formats. Its easy-to-use interface and robust features make it a preferred choice for anyone wanting to back up their DVD collection or watch movies on different devices.
If you're not familiar with it or are seeking a more detailed review, this section offers an in-depth and objective evaluation of WonderFox DVD Ripper. We examine its functions, performance, and overall quality. Additionally, we'll suggest DVDFab DVD Ripper as a top alternative option. Offering a comparative insight between these two software aids our readers in making an informed choice about the best DVD ripper for Windows 10 to suit your needs.
Wonderfox DVD Ripper Pro Test and Review
WonderFox DVD Ripper is an excellent DVD ripping software which can convert your DVDs to a variety of video and audio formats. It can extract audio from DVDs to MP3, M4A format and supports multiple devices such as phones, computers etc. You can even rip homemade or encrypted DVDs with it.
With WonderFox, you can get the perfect balance between file size, compression ratio and output quality. The software also features customized options, fast speed and excellent stability.
Note: The full-featured version of WonderFox DVD Ripper is called WonderFox DVD Ripper Pro, however the two are basically the same product. There isn’t a “basic” or stripped-down version of WonderFox DVD Ripper. The brand promotes the Pro version to highlight the advanced features.
Main Functions of Wonderfox DVD Ripper Pro
Supports 500+ Output Formats and Multiple Devices
WonderFox DVD Ripper Pro supports an extensive range of output profiles, allowing users to easily convert DVDs into popular video and audio formats such as AVI, MPG, MP4, MTS, WebM, WMV, MKV, MP3, WMA, WAV, OGG, FLAC, M4A, and more.
Furthermore, this best DVD Ripper for Windows 10 offers compatibility with various external devices from manufacturers like Apple Samsung Huawei HTC Nokia Sony etc., ensuring that your ripped DVDs can be played back on these devices seamlessly.
Supports Copy Protected DVDs
Wonderfox DVD Ripper Pro is able to rip and convert many types of DVDs. It allows you to remove DVD copy protections, including DVD CSS, Region Code, CPRM, Multi-angle, RCE, Sony ARccOS, UOPs, Disney X-Project DRM and Cinavia Protection.
Multiple Customization Features
WonderFox DVD Ripper Pro also offers advanced customization options before ripping DVDs. It allows you to tailor the output film settings to their specific needs, including adjustments in channel mode, audio encoder, bit rate, sample rate, volume level, resolution, video encoder, bit rate and frame rate. It also provides a built-in video editor that enables you to cut any clip of your video or add effects
Fast Speed and Excellent Quality
WonderFox DVD Ripper Pro is able to convert DVD to digital formats at GPU-accelerated speed and excellent quality. It only takes 20 minutes to rip 150-minute DVDs.
Note: WonderFox DVD Ripper Pro provides unregistered users a free version. This limited version supports only 15-minute ripping of each DVD, without 1:1 DVD to ISO cloning function and on-going technical support.
Price Plan of Wonderfox DVD Ripper Pro
| Single License (1 PC) |
29.95$: lifetime free upgrades |
| Family License (3 PCs) |
69.95$: lifetime free upgrades |
| Discount Pack |
39.95$: DVD Ripper Pro + HD Video Converter Factory Pro |
Installation
The first step is to download and launch the program from the Wonderfox website, which is a simple process and does not come bundled with third-party programs. In this test I used the full version of Wonderfox DVD Ripper Pro on Windows 11, which takes up about 50 MB of disk space.
Load DVD
Wonderfox DVD Ripper Pro supports importing DVD, DVD ISO, and DVD Folder.
In the test, I used a copy-protected DVD with the following features:
- Length: 1 hour 25 minutes
- Number of Titles: 21
- Encryption type: Sony ARccOS
After clicking the Load DVD button, the software detected and analyzed the disc in about 15 seconds, automatically recognizing the main titles.
Output Formats and Customization
The "Output Format" section provides more than 500 format profiles.
- Formats: Video, Audio, DVD/VCD, HD Video, etc
- Device: Apple, Samsung, Android, Smart TVs, etc
- Other: User-defined and Recent
It offers basic editing features: including enabling embedded subtitles or adding external subtitles, cropping the video, adding special effects, and more. I trimmed a 10-minute clip and the editing process didn't lag, but the options offered are rather limited.
Pros and Cons of Wonderfox DVD Ripper
- Can rip both homemade or encrypted DVDs
- Supports over 500 output formats and multiple devices
- Fast ripping speed, lossless output
- Customize the output video with built-in editor
- The interface is user friendly and intuitive
- It doesn't have a Mac version
- It doesn't support Blu-ray ripping
- The interface is simple but the design is outdated
- It doesn't support 5K/8K profiles
- The program often freezes when loading DVDs through an external DVD drive
Wonderfox DVD Ripper Pro is a feature-rich and efficient DVD ripper. But noting its potential drawbacks such as lacking batch processing and advanced customization, we have tested some other popular free/paid software for you to select. After testing, we conclude that DVDFab DVD Ripper is a strong alternative with more features.
Best Wonderfox DVD Ripper Alternative
DVDFab DVD Ripper is one of the best DVD ripping software programs to backup and convert your DVDs. Its main functions are as follows:
Main Functions of DVDFab DVD Ripper
Supports 1000+ Output Formats and 260 Preset Devices
This top DVD Ripper can convert your DVDs to more than 1000 video and audio formats. Also, it offers 260+ preset devices, including Apple, Google, Huawei, Microsoft, Samsung, and Sony.
Supports Old and New Copy-protected DVDs
DVDFab DVD Ripper can remove any DVD protection from your DVDs. Based on the Cloud Decryption Service, it can remove all protections from old or newly-released DVDs, such as region code, CSS protection, Sony ArccOS, APS and more.
Multiple Customized Options
Before ripping DVD to MP4, DVDFab DVD Ripper allows you to select specific video quality parameters, such as 3D, Passthrough or various resolutions like 4K/5K/8K. It also includes options for different bit depths such as 10-bit or 12-bit, and different codecs such as H265. You can also customize some advanced settings, such as Frame/Sample Rate, Resolution, Quality, Channels, Subtitles.
This software also comes with a built-in video editor that lets you trim, crop, rotate, and watermark your videos. You can also adjust the brightness, contrast, and saturation of your videos.
Fast Speed and AI-upscaled Quality
This powerful DVD ripper can batch convert DVDs, and it also features 50x faster conversion speeds thanks to GPU acceleration. It supports all popular GPUs, including NVIDIA CUDA and multi-core CPUs. Moreover, you can easily upscale your video from SDR to HDR10 with the aid of NVIDIA AI Enhancer.
Convert DVD Subtitles to SRT File and Synchronize Metadata Info
DVDFab DVD Ripper uses OCR technology to convert the subtitles of your DVDs into SRT files. It also supports multiple languages so, you can use it in your own language. Not only this, but it also saves meta info such as title, director, actors, etc. of your DVDs.
Pros and Cons of DVDFab DVD Ripper
- Can rip any old or new encrypted DVDs
- Support over 1000 output formats and 260 preset devices
- 50x faster conversion speed with GPU acceleration
- OCR technology to convert subtitles into SRT files
- Advanced customized settings to edit videos as you like
- Modern, intuitive interface with simple operation
- DVDFab is an all-in-one software suite with multiple multimedia solutions. So it may take time for beginners to learn all its functions.
Comparison of WonderFox and DVDFab
| Functions | WonderFox DVD Ripper | DVDFab DVD Ripper |
| Working System | Windows 11/10/8/7 and lower | Windows 11/10/8.1/8/7 and macOS 10.13 - 15.x |
| DVD Decryption | Remove some copy protection: CSS, CPRM, RCE, Sony ARccOS, etc | Keep updating to remove any copy protection from old or new DVD |
| Output Formats | 500+ video & audio; Multiple devices | 1000+ video & audio; 260+ preset devices |
| Video Quality | 1:1 quality |
1:1 quality & |
| Audio Quality | - | 5.1 multi-channel audios |
| Ripping Speed | GPU acceleration | GPU Hardware acceleration |
| Video Editor | Crop, Brightness, Contrast, Mosaic, Blur, Sharpen, Emboss, Noise, Old Film. | Crop, Trim, Merge video, Add watermarks and subtitles, Adjust video color, brightness, contrast, and saturation |
| Bonus Features | - |
Convert DVD subtitles to SRT file |
| Suitable for |
From beginners to power users
When selecting between WonderFox DVD Ripper and DVDFab DVD Ripper, consider their distinct capabilities.
WonderFox runs on Windows, while DVDFab also supports macOS. DVDFab is updated regularly to handle new DVD protections, which helps it cope with newer discs. For output formats, WonderFox supports over 500 options, while DVDFab works with more than 1000. Both tools can keep 1:1 video quality, and DVDFab adds AI upscaling to HDR10 plus support for 5.1 audio channels. Each program uses GPU acceleration to speed up ripping, but DVDFab also includes richer editing tools, as well as subtitle conversion and metadata synchronization.
Both programs are made for beginners and advanced users, but DVDFab’s extra features leave more room for changing or growing needs later on.
Yes, WonderFox DVD Ripper Pro is usually safe if you download it from the official website or a well-known software distributor. Getting it from unknown sites or using cracked or torrent versions, such as "WonderFox DVD Ripper Pro Crack Download" or "WonderFox DVD Ripper Pro Torrent", can expose you to malware and other security risks. For safety, always download software from trusted sources only.
DVD ripping software like WonderFox DVD Ripper is generally legal in many regions. The rules still depend on how you use it and where you live. If you use it for personal purposes, such as backing up DVDs you already own, this is usually treated as legal use.
If you plan to rip DVDs that you do not own, you should first get permission from the copyright owner. The exact laws differ by country or region, so always check the local rules before you use the software in this way
After a detailed review of WonderFox DVD Ripper Pro and its main alternative, DVDFab DVD Ripper, it is clear that each program has its own strengths for different user needs. WonderFox offers a solid set of features, while DVDFab DVD Ripper delivers more functions and better performance, especially when converting DVD to MKV and other digital formats. The right option depends on your specific requirements for DVD ripping.
![Top 3 Ways to Compress ISO Files Losslessly [2025 Updated]](https://r5.dvdfab.cn/upload/resource/en/compress-iso-Fexa.jpg)
