It is widely acknowledged that DVD is vulnerable to be damaged and large piles of DVD pose a challenge for storage room. Therefore, storing your favorite videos on portable devices is also a good choice. MP4, as one of the most popular formats, is considered the top priority. If you are wondering about the best VOB to MP4 converter, you can definitely find satisfactory answers.
Best VOB to MP4 Converter
DVDFab DVD Ripper
DVDFab DVD Ripper, as one of the most advanced VOB files to MP4 converters, had owned more than 80 million users around the world, and has been downloaded over 100 million times. It is able to convert any DVD to mp4 and the other video& audio format in 5 minutes. What’s more, it also could convert VOB to MP4 Mac and convert VOB to MP4 Windows 10.
Features of DVDFab DVD Ripper
Features
  • Rip all kinds of DVDs
    • Generally speaking, all commercial DVDs have copy protection in case for any illegal backup, which becomes difficult to make DVDs in digital form. Typical DVD protections are CSS (Content Scramble System), APS (Analog Protection System), RC (Region Code), Sony DADC (Digital Audio Disc Corporation), and more. Armed with DVDFab DVD Ripper, there is no need to worry about that. Based on the Cloud Decryption Service exclusive to DVDFab, you can remove the protection from the encrypted DVDs in just a few seconds.
  • Rip DVDs to video & audio without quality loss
    • What DVDFab Ripper distinguishes itself from other similar products, is the inclusive high quality for home theater. DVDFab DVD Ripper can convert DVDs to MKV.Passthrough video and 5.1 AC3 audio, which is appropriate for home-theater level experience. Besides, whether you want to play the videos in Mobile, Theater, AI, or Web, DVDFab Ripper could accomplish all your wanted tasks.
  • Rip DVDs to 1000+ Video & Audio Formats through Customized Parameters
    • DVDFab DVD Ripper can convert DVDs to 1000+ video (MP4, MKV, AVI, MOV, WMV, FLV, M4V, TS, WebM, M2TS, 3GP, etc.) and audio (MP3, WMA, AAC, M4A, FLAC, OGG, PCM, etc.) formats for playback on popular devices. When it comes to device compatibility, DVDFab Ripper software can rip DVDs to more than 260 preset devices including Apple, Google, Huawei, Microsoft, Samsung, and Sony.
    • If you want to personalize the output video, you can turn to the Profile Filter (3D, Passthrough, 4K/5K/8K, H265, 10/12 bit, etc.) and Advanced Settings (Codec, Frame/Sample Rate, Resolution, Quality, Channels, Subtitles, etc.).
  • Multi-task mode makes conversion faster
    • Still need to wait ripping videos for a long time? DVDFab Ripper will greatly save your time. You could add multiple tasks in the Task Queue, once added, it will rip your DVDs in succession.
  • Built-in Video Editor Builds Excellent Videos
    • DVDFab DVD Ripper embodies an in-built video editor aiming to create professional-looking and personalized video while ripping DVDs. It allows you to crop, trim, merge video, add watermarks and subtitles, and even adjust video color as you like.
  • Upscale Video to 1080p with AI Enhancement
    • Have you ever felt the video resolution isn’t good enough, even though you rip your DVD videos to digital files? No worries, armed with AI Enhancement, all the issues with regard to resolution related problems. MP4.AI and MKV.AI are the two main output formats for your option.
How to Convert VOB to MP4
Step 1: Get DVDFab DVD Ripper free download on Windows or Mac.
Step 2: Open DVDFab DVD Ripper software and import the DVD source.
Launch DVDFab DVD Ripper and select the "Ripper" module. Insert your DVD into your computer's drive, and the software will automatically load the content, decrypting any embedded copy protection. If you have an ISO file or a folder, drag and drop the file into the application.
How to convert DVD to MP4 with DVDFab DVD Ripper
Step 3: Customize the DVD video output.
Then on the main interface, you can choose some titles or rip the whole DVD, select audio tracks and languages, extract DVD subtitles to SRT format, and add external subtitles. If you are curious about what kind of copy protection is embedded in your DVD, just click the option "Info" and find out.
Although you set the default profile in the previous step, you can also click the button "Choose Other Profile" - "Format" to select another MP4 profile as the output video format. You can also click "Device" to convert DVD to iPhone, Android, and other portable devices directly.
Click "Advanced Settings" to customize video, audio and subtitle parameters to meet your specific demands.
Then edit your DVD video by clicking the "Video Edit" or "Trim" button.
Step 4: Set the output destination and start to convert DVD to MP4.
At the bottom of the interface, click the "Folder" icon to save your output video: Mobile Device or Folder. Make a decision and then click the button "Start". DVDFab DVD Ripper will finish the conversion in just 3 to 5 minutes.
WinX DVD Ripper
.vob to mp4
WinX DVD Ripper Platinum is one of the most popular DVD rippers with 5.8 million users worldwide. It is known as the only such software that reached Level 3 Hardware Acceleration, which is standard by Intel (QSV) and NVIDIA (CUDA/NVENC). Besides, it supports conversion DVD (ISO images) to many formats, including MP4, AVI, MOV, MPEG, FLV, WMV, MP3 and so on. If you can’t identify the difference between those parameters, WinX DVD Ripper Platinum's best settings will be set automatically.
Pros
  • Rip various DVDs, even including the damaged or scratched DVDs.
  • 1:1 DVD ripping and conversion quickly
  • It supports even old and outdated discs
Cons
  • It only has 6 different language versions.
  • The service issue is delayed sometimes.
  • Limit on video quality.
How to convert VOB to MP4 by Winx DVD Ripper Platinum
  1. You can use physical DVDs, ISO images, or even DVD folders as a source.
  2. You will be offered the choice to rip the main parts or back them up entirely.
  3. The ready-made profiles will make your work a breeze, allowing you to quickly rip a disc to a video file in your desired format.
If you want to know more about this product, you can refer to A Review of WinX DVD Ripper and DVDFab DVD Ripper to get more detailed introduction.
Convert VOB to MP4 Online
DVDFab Online Video Converter
DVDFab has been considered as one of the most reliable and best video converters online free. It’s famous for its mature system, stable quality, competitive price and miscellaneous functions. DVDFab online video converter supports 10 files each day, and the size of a file is up to 200MB.
vob to mp4 converters
Features of DVDFab Online Video Converter
 Features
  • Popular formats supported
    • No matter you need MP4, MKV, VOB, WMV,FLV, MOV,DVDFab could cover all these formats. You can choose to convert the audio or video file to the most popular formats, no need to be bothered by the conversion of multiple formats, DVDFab can solve all these kinds of problems.
  • Fast and easy
    • Have you ever waited for the online video conversion for hours? Have you ever been perplexed by the complicated instruction manual? If yes, you will never need to worry from now. Armed with DVDFab, you won’t suffer from that anymore. After you finish the first two steps above, all you need to do is wait for the final results in just a few minutes.
  • Excellent quality
    • If you are concerned about the video quality, DVDFab must be your priority. It adopts high-quality video processing algorithms to ensure no quality losses in the process of converting. Whether you are a Mac or Windows, iPhone or Android user, you can compress the large video files into smaller sizes without any evident reduction in definition.
  • All devices supported
    • DVDFab all devices, including mobile phones, computers, tablets and others. When you want to compress a video at once but don’t have computers, no worries, DVDFab supports video compression in all kinds of devices. Just one piece of equipment can complete the whole editing job. Those days are gone when several devices work together to produce only one result.
  • File protection
    • DVDFab always considers the demands of users as a priority and especially focuses on the safety problem. Living surrounded by the Internet, everyone’s life gradually drifts into transparency. However, DVDFab always committed to privacy protection. It promises that the entire conversion process is absolutely safe. The uploaded file will be deleted to ensure no one would gain access to your privacy after the conversion mission completes.
  • Cloud conversion
    • All the conversion tasks will be conducted in the cloud, therefore, the users don’t need to install any apps, which won’t occupy computer hard disk and computing power. Besides, it is more convenient for you to finish the missions.
How to Convert VOB to MP4 Online with DVDFab Online Video Converter
  • Step 1: Click the Choose Files button to select your wanted files.
  • Step 2: Choose a target file format and click the Convert button.
  • Step 3: Click the Download button to download the converted files.
CloudConvert
CloudConvert is a powerful online file converter that supports nearly all kinds of audio, video, document, e-book, archive, image, spreadsheet, and presentation formats.
how to convert vob to mp4
Features of Cloud Converter
 Features
  • Ensure data security
    • CloudConvert is dedicated to protecting the privacy of users and promises that no one has the right to read or get your file. Since its founding in 2012, CloudConvert has gained the trust of users and customers.
  • High-quality conversion with 200+popular formats
    • CloudConvert is a powerful yet convenient conversion tool that supports more than 200 formats without any quality loss.
  • A simple interface makes your conversion easier
    • If you are not familiar with the conversion instruction or don’t know how to convert VOB to MP4, there is no need to worry. Because CloudConvert will automatically set the most appropriate parameters.
FAQs on VOB to MP4 Conversion
VOB is a video format from a DVD disc, typically stored in the VIDEO_TS folder. It contains most of the data which is stored in the disc, such as video, audio and subtitles. The VOB format is based on the MPEG stream format and is usually formatted as a MPEG-2 stream and can be opened by various video playback programs.
Compared with all the competitive products, DVDFab DVD Converter is the best DVD converter. Its excellent system, considerate design as well as powerful functions have gained the trust of a growing number of customers and users.
This passage introduces two powerful software specialized in conversion between different formats, and two online converters featured by convenience and speed. Among these products, DVDFab DVD Ripper is regarded as the top priority, which is able to solve all the conversion-related problems. Besides, cooperating with other key products including Video Enhancer AI and UHD Copy, a cinema-like viewing experience is at the touch of your finger.
