DVDFab Passkey: Decrypt Your Protected DVDs and Blu-ray Discs
Summary: DVDFab Passkey is a reliable solution to decrypt DVDs and Blu-ray discs. This post will introduce all the DVDFab Passkey programs and their working.
- • A free version of Passkey for DVD + Passkey for Blu-ray & UHD
- • Remove some DVD/Blu-ray protections;
- • Copy or rip some DVDs/Blu-rays to ISO images or folders;
- • Work with other software to access to DVD/Blu-ray content
If you have got your hands on your favorite movie DVD or Blu-ray, but the copy-protection is restricting you from playing it on your device, DVDFab Passkey is here to unprotect encrypted DVD discs. The program is known to help you access your chosen DVDs and Blu-ray movies without any limitation or restriction.
This article will explore the detailed offerings of DVDFab Passkey, like DVDFab Passkey for DVD, DVDFab Passkey for Blu-ray, and DVDFab Passkey Lite, with their comprehensive overview to deeply understand their functions and workings. Let’s take a look.
What Is DVDFab Passkey
Passkey All-In-One (Lifetime) includes 5 products, offers the most comprehensive solution to decrypt commercial DVDs, Blu-rays, 4K Ultra HD Blu-rays, and BDAV Blu-rays and 4K BDAV Blu-rays recorded from (4K) Blu-ray broadcasts, including support for downgrading UHD unfriendly firmware for regular backup.
Five Products in All-In-One:
- Passkey for DVD
- Passkey for Blu-ray and UHD
- Passkey UHD Drive Tool
- Passkey for Blu-ray Recorder
- Passkey for 4K Recorder
Review of DVDFab Passkey Series Products
Product 1: DVDFab Passkey for DVD
DVDFab Passkey for DVD is a Windows-based driver that works on-the-fly to unprotect encrypted DVD discs. It can remove almost all known DVD copy protections and region codes in just seconds to help you freely access and watch any DVD movie with no limitation.
It can work with a lot of software like DVDFab DVD Copy, DVDFab DVD Ripper, PowerDVD 7/8/9/10, TotalMedia Theatre 3, WinDVD 8/9/2010, ImgBurn (Read Mode), etc. Besides, you can also rip the decrypted DVD to hard disk or Image for your later use.
Key features:
- Makes all DVDs readily accessible to watch by decrypting them
- Works with a massive range of software to easily access and edit DVD content
- Constantly updated to meet the industry standards
- Offers flexible settings to provide the best user experience
How to use DVDFab Passkey for DVD:
Step 1: Download and run the DVDFab Passkey for DVD software
Tap twice on DVDFab Passkey and launch it. Then, click DVD from the welcome screen and tap Start DVDFab Passkey at the interface’s bottom-right corner to run the program. The software will minimize into the system tray and search for the DVD disc in the drive to recognize it.
Step 2: Load the encrypted DVD
Now, put the source DVD into the drive, and the program will automatically run to decrypt the DVD and remove any protection (excluding Cinavia and new protection 2.0) and region code restrictions within a couple of seconds. You can access the detailed source disc information from the main screen, such as the embedded protections (removed) and status.
Step 3: Play the source DVD
Once your decryption process is completed, play your source DVD with any device. You can also rip the DVD to any hard disc. Simply right-click on the DVDFab Passkey icon (minimized into the system tray), choose the Rip to Hard Disk or Rip to Image option, and select the output target in the popup window that prompts.
Product 2: DVDFab Passkey for Blu-ray and UHD
DVDFab Passkey for Blu-ray and UHD is a robust Windows-based driver designed to swiftly bypass nearly all known BD/UHD protections and region codes, enabling you to freely access and watch any Blu-ray and 4K Ultra HD Blu-ray movies with no limitation.
Key features:
- Efficiently removes Blu-ray and UHD protections (except for Cinavia)
- Seamlessly works with a vast range of software to copy, burn, clone, and so on
- Updates itself constantly to meet and remove new Blu-ray and UHD protections
- It provides flexible settings to remove any PGCs or change the Blu-ray playback order and do much more
How to use the DVDFab Passkey for Blu-ray:
Step 1: Download and launch the DVDFab Passkey for Blu-ray
Tap twice on DVDFab Passkey and launch it. This time, choose Blu-ray on the main screen. Then again, tap Start DVDFab Passkey at the screen’s lower-right corner. DVDFab Passkey will automatically minimize into the system tray and see if you have loaded any media in the Blu-ray drive.
Step 2: Insert the source Blu-ray for decryption
Insert the BD to decrypt in the Blu-ray drive, and the software will run to recognize it automatically and remove any protection (excluding Cinavia) and region code restrictions within seconds. Get all the information on the source disc and status from the main screen, including the kinds of embedded disc protection.
Step 3: Play the decrypted Blu-ray
Once your decryption is complete, you can play the decrypted Blu-ray easily with any player and rip it to your hard disc or image.
All you need to do is right-click on the DVDFab Passkey icon (minimized into the system tray), choose the Rip to Hard Disk or Rip to Image option, and select the output target in the popup window that prompts.
Product 3: DVDFab Passkey UHD Drive Tool
DVDFab UHD Drive Tool is a utility designed to help users downgrade the UHD-Unfriendly firmware and present you a backup-friendly UHD drive.
Key features:
- Downgrade UHD Unfriendly Firmware for Normal Backup
- Support All Types of 4K Blu-ray Drive and USB Drives
- Truly One-Click Mode Made it Easy for Everyone
How to use DVDFab UHD Drive Tool:
Step 1: Launch DVDFab UHD Drive Tool
First, double click to run Passkey 9 and press the "Start Passkey" button. The program will minimize itself to the system tray. Then, right-click the Passkey icon from the system tray and select "Downgrade Firmware".
Step 2: Select your UHD drive from the available drive list
Choose your 4K UHD drive from the drop-down menu. All the listed 4K UHD Drives are supported by this are supported by this 4K UHD Drive Tool.
Step 3: Hit "Downgrade Firmware"
Tab Downgrade Firmware to proceed with the downgrading task. A successful report will pop up when the friendly firmware is flashed. Once done, reboot your PC.
Product 4: DVDFab Passkey for Blu-ray Recorder
Passkey for Blu-ray Recorder helps users remove the encryptions on the recorded Blu-ray discs (known to many as BDAV discs), so that they can freely access the decrypted contents with 3rd party backup tools to make backup copies, or watch them with other media player applications.
Decryption aside, this BDAV decrypter still offers basic backup function to copy recorded Blu-ray discs to computer HDDs as ISO files, or BDAV folders.
key features:
- Decrypt recorded BDAV/Blu-ray discs
- Output ISO images or BDAV folders
- Compatible with 3rd party backup and playback tools
How to use DVDFab Passkey for Blu-ray Recorder:
Step 1: Run Passkey for Blu-ray Recorder
Double click Passkey 9 to run it, and choose Blu-ray Recorder from the welcome window. Then, click the "Start Passkey" button. Afterwards, Passkey will automatically minimize itself into the system tray and detect whether the disc exists.
Step 2: Load the source and start the decryption
Insert the recorded BDAV disc into your optical drive, Passkey will begin the decryption task quickly. In the system tray area, a small decryption window pops up. When the green bar reaches the end, it means the decryption is complete.
And you can get the detailed info regarding the source disc and status from the interface when you open Passkey, including what kind of protections embedded in have been removed.
Step 3: Post-decryption operation
After the decryption is finished, you can play the decrypted BDAV disc or rip it to your hard disc or image by right-clicking on the icon of Passkey minimized into the system tray, and clicking "Rip to Hard Disk" or "Rip to Image" from the options. Then, choose the output target in the following pop-up window.
Product 5: DVDFab Passkey for 4K Recorder
With the advancement of 4K broadcasting technologies from BS4K channel of NHK, CS4K channel of SKY PerfecTV and others alike, 4K recording devices are also getting popular among consumers, as they can record 4K Blu-rays from those broadcasting stations at home.
DVDFab Passkey for 4K Recorder, world's very 1st 4K BDAV decrypter, can remove the encryptions from the recorded 4K Blu-ray discs (aka 4K BDAV discs), and then copy the unprotected discs to computer HDDs as ISO files, or BDAV folders.
Key features:
- 4K Recording Gets Popular as 4K Broadcasting Advances
- Support Recorded Discs by Major Recording Devices
- Output ISO Images or BDAV Folders
How to use DVDFab Passkey for 4K Recorder:
Step 1: Run Passkey for 4K Recorder
Double click Passkey 9 to run it, and choose 4K Recorder from the welcome window. Then, click the "Start Passkey" button. Afterwards, Passkey will minimize itself into the system tray.
Insert the recorded 4K BDAV disc into the drive, Passkey will automatically start the decryption task. In the system tray area, a small decryption window pops up. When the green bar reaches the end, it means the decryption is complete.
After the decryption is finished, you can play the decrypted 4K BDAV disc or rip it to your hard disc or image by right-clicking on the icon of Passkey minimized into the system tray, and clicking "Rip to Hard Disk" or "Rip to Image" from the options. Then, choose the output target in the following pop-up window.
Discard DVDFab Passkey Crack - It Is Unsafe!
As you now know the harmful effects of cracked software such as DVDFab Passkey crack 8.2.2.8, we would never recommend you opt for DVDFab Passkey crack. In fact, you must download the software from the official website only. Instead, you can try the free version of Passkey Lite for basic decryption needs or try the authorized DVDFab Passkey for DVD and Blu-ray for higher decryption needs.
Hidden Risks of DVDFab Passkey Crack
DVDFab Passkey crack version is available for users who cannot afford the top-notch features and functions of the original software but look forward to availing the functions through other means. Cracked software versions are illegal and offer complete functionality without any charges or subscriptions. However, it is unsafe due to many reasons. Let’s find out what makes them risky.
Using cracked versions of software calls for potential threats. Here are the possible dangers and threats of using DVDFab Passkey crack 9.
Risk 1. System Crashes
When you use DVDFab Passkey crack 9, it may reduce the system performance, causing instability or even making your system crash, followed by a blue screen.
Risk 2. Invisible Viruses and Fake Links
Unauthorized vendors and hackers usually modify the cracked software, and it may have several hidden bugs or redirect to malicious links, causing a nuisance for the users.
Risk 3. Data Breach
DVDFab Passkey crack 9 exposes the device to multiple viruses, malware, and spyware. Such unauthenticated sites usually redirect users and visitors to malicious sites, infecting systems with adware, ransomware, and bots.
Malicious programs can also access your private and sensitive information, like trade secrets, financial credentials, etc., leading to data breaches.
Risk 4. Outdated Functions
Crack software is not updated, unlike the regular DVDFab Passkey , which is updated regularly to enhance the features, add new functions, and fix any bugs to improve the user’s experience. As a result, you won’t be able to copy the latest DVDs as they won’t be upgraded professionally.
You can try the free version of DVDFab Passkey , DVDFab Passkey Lite, or get a subscription at USD 28.99 for a month, at USD 49.99 for a year, or for a lifetime at USD 74.99.
No. DVDFab Passkey for DVD/Blu-ray runs only on Windows PC 7 and above.
The Final Wrap
DVDFab Passkey is a wonderful solution to decrypt protected DVDs and Blu-ray movies. The software helps remove various protections from the DVD discs, enabling them to run freely on any device and player. One must refrain from using DVDFab Passkey crack and instead try the free version, DVDFab Passkey Lite, to remove some protections and change the region settings of Blu-ray players.
