Top 5 Best DVD Players with Screens in 2026: Reviews and Buying Guide
Summary: Among these five portable DVD players with screens, WONNIE W-BR146 is the only Blu-ray option, ieGeek IK-703 and BOIFUN BFN-161 have the largest 15.6-inch viewable screens, and VANKU BR1093B-V08 is designed for car-headrest use. Product labels such as 16.9 or 17.5 inches may refer to the chassis or bezel rather than the LCD itself, and battery times are manufacturer claims rather than independent measurements. For most buyers, actual screen size, rated runtime, disc support, and power options are the main differences to compare.
Picking a portable DVD player sounds straightforward until you read the product listing fine print. A 16.9- or 17.5-inch product name does not always mean the LCD itself is that size, and battery figures are usually manufacturer ratings rather than independently measured runtime. Screen size, battery life, disc support, and how you plan to use the player are the main differences worth checking.
I compared five models sold or listed for US buyers, focusing on their actual display size, rated battery life, disc support, and travel or car use. Here is the breakdown.
Top 5 Best Portable DVD Players with Screens
WONNIE 16.9" Portable Blu-Ray DVD Player
The WONNIE is the only model in this list that plays Blu-ray discs alongside standard DVDs. That single capability separates it from the other four: if you have an existing Blu-ray collection or want 1080P content from disc rather than software upscaling, this is the portable option here designed for it.
The W-BR146 is marketed in the 16.9-inch size class, but its actual LCD viewing area is 14.1 inches with a native 1920×1080 resolution. Its 5000mAh rechargeable battery is rated for about 4–5 hours of playback, while the included AC adapter and car charger cover longer sessions when external power is available. For buyers whose libraries are primarily standard DVD, the Blu-ray capability matters less, and the shorter rated runtime compared with some DVD-only models becomes a more visible trade-off.
What it does well:
- Plays Blu-ray, DVD, CD, and supported USB/SD media from a single device.
- Native 1920×1080 resolution on the actual 14.1-inch LCD.
- 5000mAh rechargeable battery rated for about 4–5 hours of playback.
- HDMI output connects to a compatible TV or monitor when one is available.
- Supports Blu-ray Region A/1 and standard DVDs from all regions.
Where it falls short:
- Its 4–5-hour rated runtime is lower than the six-hour claims of some DVD-only models in this group.
- If your collection is limited to standard DVDs, the Blu-ray hardware may add cost without adding much value for your use case.
ieGeek 17.5" Portable DVD Player with 15.6" Screen
The ieGeek IK-703 is commonly sold as a 17.5-inch portable DVD player, while its actual viewable LCD is 15.6 inches with a 1280×800 resolution. The larger screen is sized for shared rear-seat or tabletop viewing rather than compact solo use.
Its 5000mAh battery is rated for up to six hours of playback. Dual built-in speakers, headphone output, AV output, USB, and SD support provide the main connections needed for travel or home playback.
What it does well:
- 15.6-inch 1280×800 viewable LCD suited to shared viewing.
- 5000mAh rechargeable battery rated for up to six hours of playback.
- 270-degree swivel and 180-degree flip screen for different viewing positions.
- Dual speakers with headphone and AV output.
- Supports DVD, CD, VCD, MP3, MPEG, AVI, VOB, USB, and SD media.
- Region-free DVD playback.
- The larger body takes more bag and seat space than compact 10- to 12-inch players.
- It does not play Blu-ray discs.
VANKU 10.1" Car Headrest DVD Player
The VANKU BR1093B-V08 is purpose-built for car use rather than general portable playback. Its 10.1-inch 1024×600 screen attaches to a headrest with the supplied mounting bracket. HDMI input, AV in/out, USB/SD support, and region-free DVD playback give rear-seat passengers several ways to play media.
Unlike the rechargeable players in this list, the VANKU has no built-in battery and relies on external power. A car charger is the natural option on the road, while the included wall charger allows indoor use as well.
What it does well:
- 10.1-inch 1024×600 screen designed for rear-seat viewing.
- HDMI input and AV in/out add more connection options than a disc-only headrest player.
- USB port and SD card slot support compatible digital media.
- Includes a headrest mounting bracket for vehicle use.
- No built-in rechargeable battery; it must remain connected to car or wall power.
- The 10.1-inch screen is considerably smaller than the large-screen portable players in this list.
BOIFUN 17.5" Portable DVD Player
The BOIFUN BFN-161 uses a 5000mAh battery rated for up to six hours of continuous playback. It is marketed as a 17.5-inch player, but the actual LCD viewing area is 15.6 inches with a 1280×800 resolution. The screen rotates 270 degrees and flips 180 degrees for different seating positions.
The included AC adapter and car charger make it easier to keep the player running when an outlet or vehicle power source is available. For buyers who prioritize a large viewable screen and long rated battery time together, it remains one of the stronger combinations in this group.
What it does well:
- 15.6-inch 1280×800 LCD inside a 17.5-inch bezel.
- 5000mAh battery rated for up to six hours of playback.
- 270-degree rotation and 180-degree flip screen.
- Supports DVD, CD, AVI, VOB, MPEG, MP3, WMA, JPEG, USB, and SD media.
- Includes an AC adapter and car charger.
- No Blu-ray support; it is a standard DVD and digital-media player.
- The large chassis takes more travel space than compact portable players.
JEKERO 16.9" Portable DVD Player
The JEKERO 1703 is sold in the 16.9-inch product class but uses a 14.1-inch 1280×800 LCD rather than the previously listed 1366×768 panel. The screen rotates up to 270 degrees and flips 180 degrees for different travel, tabletop, or rear-seat positions.
Its rechargeable battery is rated at approximately five to six hours. Connectivity includes USB, SD card, headphone output, and AV input/output, so the player can also use supported digital media when you do not want to load a disc.
What it does well:
- 14.1-inch 1280×800 LCD with 270-degree rotation and 180-degree flip.
- Rechargeable battery rated at approximately five to six hours.
- USB port and SD card slot expand playback beyond discs.
- Headphone jack enables private listening in shared spaces.
- Includes AC and car power options.
- It does not support Blu-ray discs.
- The advertised 16.9-inch product size is larger than the actual 14.1-inch viewing area.
How to Choose the Right DVD Player with Screen
Quick Comparison Table
| Model | Actual Screen | Battery Life / Power | Format Support | Best For |
| WONNIE W-BR146 | 14.1", 1920×1080 | About 4–5 hours claimed | Blu-ray, DVD, CD, USB/SD | Blu-ray playback |
| ieGeek IK-703 | 15.6", 1280×800 | Up to 6 hours claimed | DVD, CD, VCD, USB/SD | Large-screen shared viewing |
| VANKU BR1093B-V08 | 10.1", 1024×600 | Car or wall power | DVD, USB/SD, HDMI input | Car headrest use |
| BOIFUN BFN-161 | 15.6", 1280×800 | Up to 6 hours claimed | DVD, CD, USB/SD | Large screen + long rated battery |
| JEKERO 1703 | 14.1", 1280×800 | Approx. 5–6 hours claimed | DVD, CD, USB/SD | Large portable display |
Buying Tips
1. Battery life: If you plan to use the DVD player on long drives, flights, or in places without an outlet, compare both the rated runtime and the included charging options. The battery figures in this guide are manufacturer or seller claims unless a measured test is specifically stated; actual runtime varies with brightness, speaker volume, battery age, and disc use.
2. Format compatibility: Most users need standard DVD, CD, and common USB/SD media support. If your collection includes Blu-ray discs, the WONNIE W-BR146 is the Blu-ray-capable model in this group.
3. Screen size and quality: Check the actual viewable LCD rather than relying only on the number in the product title. Several models marketed as 16.9 or 17.5 inches use 14.1- or 15.6-inch displays. Native resolution also matters when two players have a similar physical size.
4. Audio Requirements: If you're in a noisy environment or need privacy, make sure the player has a headphone jack. AV or HDMI connections can also matter for home use when you want to connect the player to a larger screen or external audio setup.
How to Digitize Your DVD for Playback without a DVD Player
If you prefer not to carry a portable DVD player, you can convert DVDs you own or are authorized to copy into local video files before a trip. A laptop, tablet, phone, or compatible TV can then play the saved file without needing the original disc each time.
To get started, you'll need a computer with a DVD drive and conversion software such as DVDFab DVD Ripper.
Key Features:
- Convert protected DVD discs, ISO images, and VIDEO_TS folders to MP4, MKV, MP3, and other formats from a library of 1000+ video and audio profiles.
- Choose from 260+ preset device profiles for phones, tablets, TVs, game systems, and other playback devices.
- Select the title, audio tracks, subtitles, and output settings before conversion.
- Use supported NVIDIA, AMD, Intel, or macOS hardware acceleration for compatible encoding tasks.
- Crop, trim, merge, add subtitles or watermarks, and adjust basic picture settings with the built-in editor.
Use discs you own or have permission to copy, and follow the copyright and anti-circumvention rules that apply where you live.
How accurate are the battery life ratings on portable DVD players?
Battery figures in this guide are manufacturer or seller claims unless a measured result is explicitly stated. Actual playback time varies with screen brightness, speaker volume, battery age, disc condition, and other settings. If you expect to watch for several hours away from an outlet, check whether the player also includes a car charger or AC adapter rather than relying on the battery number alone.
Can any of these portable players handle Blu-ray discs?
Of the five models in this guide, the WONNIE W-BR146 is the Blu-ray-capable option. It uses a 14.1-inch 1920×1080 display and supports Blu-ray Region A/1 as well as standard DVDs from all regions. The other four models are standard DVD players rather than portable Blu-ray players.
Do these players work with DVDs from other countries?
Region support varies by exact model. WONNIE W-BR146 lists all-region DVD playback but Blu-ray Region A/1. ieGeek IK-703, VANKU BR1093B-V08, BOIFUN BFN-161, and JEKERO 1703 list region-free DVD playback. Check the exact model or SKU before buying because retailer listings can mix different product revisions.
Most buyers are making one of two decisions: they need a battery-powered player for travel, or they need a car-mounted player for long drives. For travel, the choice comes down mainly to whether Blu-ray matters, how large the actual LCD is, and how much rated battery time you need.
For car use, the VANKU is designed around a headrest mount and external power rather than a rechargeable battery; it can use car power on the road and a wall adapter indoors. For family or shared viewing, ieGeek and BOIFUN provide the largest actual screens in this group at 15.6 inches, while WONNIE is the choice when portable Blu-ray playback is the priority.
![How to Rip Audio from DVD with 5 Best Free DVD Audio Extractors [2026]](https://images.dvdfab.cn/media/how_to_rip_audio_from_dvd_5r8iyw.png/public)
![How to Rip a DVD: 8 Tested Tools With Step-by-Step Guide [2026]](https://images.dvdfab.cn/media/how_to_rip_a_dvd_vlh4iu.png/public)
