DRM Protection – How to Remove DRM Protected Files?
Summary: This article provides all you need to know about DRM protection and how to remove DRM protection. We’ll also provide the steps to check DRM content protection on various media files and how you can remove it on DVD and Apple files.
The internet has transformed many aspects of modern life, offering easy access to entertainment, art, and media. While this benefits content creators by enabling efficient broadcasting, it also increases the risk of theft. To combat this, DRM protection was developed; for example, M3U8 files include DRM. To download them offline, you need an M3U8 downloader..
Content creators often struggle to enforce their intellectual property rights, prompting developers to create technologies for protecting media files. These security solutions help prevent digital piracy and allow creators to control how their content is used. Many content creators have adopted these measures to restrict access and usage of their work.
This article provides insight into what DRM content protection is and its benefits. If you’re also wondering how to remove DRM protection, you’ll find answers in this article. On that note, let’s dive straight into it.
What is DRM Protection?
You’re probably wondering what DRM protection is. DRM means Digital Rights Management, and it applies to every file that has some restriction against unauthorized use. Usually, there’s a need for authentication before you can carry out specific actions on these files.
Most times, DRM content protection prevents copying, displaying the file on various devices, and using the media multiple times. DRM protection is coded into the file, so it can be as simple or as complex as the creator wants. Some types of DRM content protection require you to play the media file using a specific application. This allows the creator to lock the content into a single software environment. It also provides the content creator with a level of control over using and distributing the content.
Sometimes, DRM protection requires the user to provide a password before you can make specific changes to the media file. However, this is not a popular DRM content protection method amongst musicians, artists, and producers. Instead, it is far more common amongst programmers and inventors.
How to Remove DRM Protection with DVDFab DVD Ripper
Now it’s clear that most commercial DVDs are copy-protected. The goal is to prevent people from illegally copying or backing up the DVD. However, if you want to convert a DVD to a digital file, you must remove copy protection. If you’re wondering if there’s a remove DRM protection-free app, you’re in luck. The DVDFab DVD Ripper allows you to easily remove different DRM protections from a DVD.
It goes beyond removing DRM protection; it also helps you copy the DVD content and allows you to open the disc in just a few seconds. Therefore, if you purchased an encrypted DVD, just upload it on DVD ripper, and it will carry out the DRM protection removal process in very little time. It uses a Cloud Decryption Service that’s exclusive to DVDFab. The process to decrypt and rip your DVD is relatively easy and outlined below.
Step 1: Launch the Software and Load the DVD
First, download this DRM protection removal software on your PC and launch it. Then, click the ‘ripper’ tab on the homepage and insert the DVD you would like to remove DRM protection from.
Step 2: Choose a Profile and Customize the Output DVD Video
Next, click on 'choose other profile' and then select 'format'. This allows you to choose the format you would like to convert the DVD to after ripping. You can also set the audio language, subtitle, and many other options you want. Apart from removing DRM content protection, this software allows you to upscale your video or set the video and audio parameters.
Step 3: Start the DVD Ripping Process
Once you select your preferences, click the 'start' button to start the ripping process. It will show the process clearly, and the DVD Ripper will remove DRM protection from the DVD in the process.
Extension: Whether a File Has DRM Content Protection in Place
There are several ways you can check if a file has DRM protection. Usually, the checking method differs by file type. This article explores the best way to check DRM protection for different file types; let’s take a look.
Music and Video Files
It’s easy to determine if there's DRM content protection on music and video files. Below, you'll find the steps to help you discover if there's DRM protection or not in video and music files.
- Firstly, choose a media file.
- Next, right-click on the media file and select 'properties' from the options.
- On the 'properties' menu, choose the 'details tab, and find the 'protected' category on this page.
The verdict would be pretty clear if the music or video file is protected or not.
Folders
Finding out if a folder containing media files is protected is just as easy as checking DRM protection on music and video files. Follow the steps below to check folders’ DRM content protection.
- First, open the folder containing the media files.
- In the right corner of the screen, you'll find the 'details' view; click on it.
- Next, click on some of the head tables and choose 'protected' from the list of criteria.
- The 'protected' column will then appear. Every file marked 'Yes' is protected and 'No' means it is free to copy.
DVD Discs
It is much easier to find out if there's DRM protection on DVDs. You don't have to put the disc inside a player or your PC before discovering this detail. If you wrote the disc yourself, there's no protection on it.
- However, if it is a licensed disc and you bought it in an official shop, it is DRM-protected. However, if you're unsure, there are some details you can take note of that will inform you there's content protection on a disc. Some of these details include:
- The price of a licensed DVD is usually higher than that of an unlicensed DVD
- The disc comes in a gray plastic case and is sealed in cellophane.
- The inner part of the disc has the copyright inscription.
- The menu of the disc is usually professional and dynamic.
- Sometimes, there is additional footage like trailers, backstage footage, and more on the disc.
- There is a copyright notice at the start of the video.
E-books
If you purchase an e-book from online retailers like Amazon and Apple, then the e-book is DRM-protected. Most times, the e-reader software allows you to verify the protection status. All users need to do is right-click on the title and look through the properties to see if there is any DRM protection on the file. However, if you purchased the file from iTunes, you can follow the steps below to confirm if it is DRM-protected.
- Locate the book on iTunes; you can access it on your Mac.
- Next, click on 'file' and choose 'get info'.
- Click on the 'summary' tab to proceed.
- Under the 'kind' label, you'll learn if it is a purchased book or a protected book.
Purchased books are DRM-free. However, protected books have DRM protection on them. You can also check other items on iTunes in the same way.
Final Thoughts
DRM protections are relevant for artists, musicians, and producers who want to protect their content. This article answers the question 'what is DRM protection' and explains how DRM protection works. If you want to check the protection status of any file, you’ll find the steps above. Despite the encryptions from DRM protection, DVDFab is one of the best DRM protection tools you can find. Acting as an iTunes DRM removal tool, it allows you to remove protection from DVDs and iTunes files in just a few steps.
