Get the Ultimate Viewing Experience with Portable Blu Ray Player
Summary: Movie viewing has just become more than that. It is now a delightful experience shared with family and friends with exceptional quality video, great sound, Wi-Fi support, Alexa compatibility, and the works. With some of the best portable blu ray player and best 4K Blu ray player, this is no longer a distant possibility, nor an expensive one. We have brought to you 10 of the best portable blu ray DVD player to choose from.
Portable blu-ray player are stand-alone units and are essentially input sources for televisions or home theatre systems. It has software that plays Blu-ray and DVD discs. Apart from movies from DVD discs, they can also play music from CDs. New versions of Blu-ray players can also have inbuilt Netflix support along with other popular streaming services.
Blu-ray DVD player are different from DVD players are should not be confounded. One of the major differences lies in the capacity of the discs. Blu-ray discs come with a swaggering 25 GB capacity on single layer discs and 50 GB on double layer discs unlike with HD DVD’s 15 GB and 30 GB. The high capacity of Blu-ray discs entail storage of longer movies and at the full 1080p resolution as opposed to HD DVD.
This third generation of compact disc technology is accepted as a preferred standard and viable option with the growing amount of digitized data. The sale of Blu-ray discs soared in the United States in 2013. Many brands are introducing newer Blu-ray player models in the US to enhance your home entertainment system and make significant upgrades in the way you watch your favorite movies.
Top 10 Portable Blu-ray Players
With all the options available in the market today, finding a Blu-ray player to best suit your needs can be an overwhelming task. Here are the top Blu-ray players.
Panasonic UB420
The Panasonic UB420 4K Blu-Ray Player will give your home theatre system an instant facelift with amazing 4K pictures, high-quality sound performance, and compatibility with Amazon Alexa and Google Assistant. The device comes in a sleek design that fits anywhere and has an HDR optimizer that can adjust the HDR performance in accordance with the surrounding lighting.
Main Features
- Dimensions 10.63 x 3.74 x 14.88 inches
- 4K VOD streaming
- Connectivity Wi-Fi, HDMI
- HDR10+, HDR10, and hybrid log-gamma (hog)
- DSD (5. 6 MHz/2. 8 MHz/11. 2MHz)
Pros
- Can work with Alexa
- Dual band Wi-Fi support allows streaming of Netflix, Amazon Prime and YouTube
- Creates 4K signals with up-scaling technology
- Great sound quality with twin HDMI terminals
Cons
- Does not support Spotify
- Delays in firmware update
LG UBK90
The LG UBK90 4K Blu Ray Player is a device which will give you owner's pride as it stands out from the crows especially in the same price range. The video display is especially pronounced because of the its Dolby Vision. It comes with a remote that is equipped with scientifically laid buttons that allows quick control.
Main Features
- Connectivity USB
- Dimensions 16.9 x 8.1 x 1.8 inches
- Remote
- 4K Ultra HD Blu-ray Disk Playback
- HDR Playback
Pros
- Great value for money within the price range
- Supports high-resolution audio
- The interface is user friendly
- Comes with a USB port for connecting the digital storage device
Cons
- You may encounter occasional lock up
- Netflix and YouTube apps to start
Panasonic DP-UB820
The Panasonic DP-UB820 is one of the best options to go for especially if budget is a constraint. It is versatile and compares with the best 4K Blu ray player. This, alongside a Hollywood Cinema Experience, ensures you get amazing imaging with stunning details and colors.
Main Features
- Connectivity HDMI, WiFi
- Supports Alexa and Google Assistant
- Dimensions 8.06 x 16.9 x 2.5 inches
- Compatible with Multiple HDR Formats
- 4K VOD
Pros
- Studio Master Sound Technology churns out great audio performance even with songs of different genres
- Simple interface enables access to DLNA-enabled devices
- Comes with a full range of 7.1ch analog audio output
- Supports projector system and comes with superior level HDR optimizer
Cons
- Restricted third party apps
- Certain DVDs may require manual setting for 480p output
Sony UBP-X800M2
With the Sony UBP-X800M2 4K, you get the theatre home for next level entertainment. The Dolby Vision technology makes watching movies with family even more special with perfectly clear pictures and details. In addition, the 4K HDR to SDR conversion generates excellent color contrast even on TVs that don’t support HDR.
Main Features
- Connectivity WiFi, Ethernet, HDMI
- HDR to SDR Conversion
- 4K High Dynamic Range
- Supports SACDs, DSFs
- SACD-R not supported
Pros
- Supports major video streaming services
- Great price point makes it a best buy Blu ray player
- Comes with Bluetooth feature which allows audio streaming directly to headphones
- Has a stable in built Wi-Fi which lets you watch videos without buffers
Cons
- Firmware requires updating
- Limited streaming
Sony BDP-BX370
The Sony BDP-BX370 Blu-ray player has several admirable offerings that can make both your audio and video experience, excellent. It is designed to fit easily into tight spaces with a very compact and light design. The device also comes with built-in Wi-Fi, coupled with MIMO technology that makes browsing, streaming, and downloading, a cruise.
Main Features
- Connectivity WiFi, HDMI
- Dimensions- 9.12 x 7.75 x 1.56 inches, weight- 1.13 pounds
- Streaming HD, Screen mirroring
- Dolby Digital TrueHD /DTS
- Video Up-Scale (DVD)
Pros
- Compact design
- Allows sharing images from smartphone to the big screen with the screen mirroring support
- Outputs high-quality surround sound
- Easy to set up and use
Cons
- Not very responsive customer service
- You will require a separate high-speed HDMI cord
LG BP175
Known for its versatility, the LG BP175 is also great value for money. It also brings to you improved shadow detail which gives a well presented display of dark and light elements. The device comes with a user-friendly menu which makes accessing various streaming services, easy.
Main Features
- Connectivity Ethernet, HDMI (6′ HDMI cable included)
- Weight 1 pound
- Full HD 1080p
- Surround Sound Supported: DTS, DTS-HD Master Audio, Dolby Digital, Dolby Digital Plus, Dolby TrueHD
- DVD and Blu-Ray
Pros
- Supports premium content like Hulu, Pandora, Spotify, Netflix, etc.
- Includes high-speed HDMI cable for viewing HD videos on your high definition TV
- The simplistic design makes it occupy less space
- State of the art audio technology delivers precision sound
Cons
- Has no inbuilt Wi-Fi
- Remote is very small
Sony BDP-S6700
One of the most popular Blu-ray players, the Sony BDP-S6700 4K is known for its extraordinary performance. It is one of the best 4K Blu ray player available that comes with a strong upscaling chip. This instantly upgrades your online content enabling a seamless viewing experience. It is designed for easy storage and offers great connectivity options.
Main Features
- Connectivity Bluetooth, Wi-Fi, HDMI, Coaxial, USB, Ethernet
- DVD and Blu-Ray player
- 4K Upscaling
- 4K Ultra HD discs are not supported
- Screen Mirroring
Pros
- Easy to set up and access
- Budget-friendly
- Gives instant access to a host of apps
- Simple and highly effective connectivity
Cons
- Does not feature a sleep timer
- Has no auto-off facility
Tojock
You can hope to easily get all those features you expect from a high range Blu ray player, in the Tojock Blu-Ray DVD player. Apart from incredible video and audio performance, it comes with smart error correction technology. It also houses an anti-skip technology that allows smooth viewing without flickering and skipping. So buy your Blu-ray player cheap as well as get all the accompanying features. There're still some DVD player software, and you can try one.
Main Features
- Connectivity USB, HDMI, AV Coaxial, USB
- Remote
- Full HD 1080p
- Measures 11.8 x 11.4 x 3.5 inches
- Upgraded 2.0 cooling chip
Pros
- Comes with a six feet HDMI cord
- Pocket Friendly and value for money
- Compact and sturdy
- Error correction makes for a smart feature that remodels pictures where necessary
Cons
- No built-in Wi-Fi
- Does not support 4K disc
Panasonic DP-UB420-K
The Panasonic DP-UB420-K 4K exhibits versatility in its true sense. It is extremely user-friendly even without an LCD. It gives you great picture quality, delivering almost theatre-like imagery. It is further easy to operate as it supports Alexa and Google Assistant.
Main Features
- 4K/HDR formats HDR10+, HDR10, and hybrid log-gamma (hog)
- 4K VOD Supported
- Twin HDMI Pure AV
Pros
- It is compatible with Alexa and Google Assistant
- Outputs great sound quality
- Allows smooth streaming from OTT platforms
- State of the art video and image quality
Cons
- Remote is very basic
- Disc loading takes longer than other players
Sony UBP-X700
The Sony UBP-X700 Blu-Ray player has been able to stand the test of time and come up victorious where a lot of its counterparts have not been able to deliver. Experience immersive viewing with a great cinematic appearance where every color pops out deep and vibrant. One of the best 4K Blu-Ray players you can hope to own at the price range, this is fun and easy to use. For a better watching experience, you can try these 4K blu ray players.
Main Features
- Connectivity HDMI, WiFi, Bluetooth
- Remote
- 4K Ultra HD Blu-ray (w/HDR)
- Dolby Atmos, Dolby Vision
- 4K UHD Up-Scale, 3D Playback
Pros
- Sleek design
- Intuitive menu and interface makes searching a breeze
- Great Dolby Vision
- Comes with a wide range of apps and channels
Cons
- Gives the best output only with high-speed HDMI cable
- Wide power adapter
Why Do I Need Software for My Blu-ray Player?
If you want a great movie viewing experience on your home computer or laptop, you will need superior quality Blu-ray player software. This is usually applicable when you are unable to access a high-definition TV or are on vacation and would like to watch HD content.
DVDFab Ultra HD Player
PlayerFab Ultra HD Player is the best software that will do the job for you. It enables you to easily play Blu-ray and 4K Blu-ray discs along with ISO files and folders with Menus and HDR10. It comes with a host of amazing features and advantages you will not find anywhere else. The software is one of the most popular of its kind across the globe with almost 80 million users worldwide and over 100 million downloads.
Key Features
- You can play any DVD, Blu-ray, and 4K Blu-ray, notwithstanding the countries and regions of their origin
- Features a Menu Mode
- Features a Simple Mode to jump straight to the actual content
- Plays ISO files and folders apart from discs
- Hardware decoding
- High-resolution audio output support
Pros
- Gives a 30-day money-back guarantee
- Easily imports content from DVD or Blu-ray disc to local media library and keeps it updated
- Supports all formats
- Allows automatic downloading of all metadata from the internet
- Analyses metadata information and arranges serials
- Multiple display language option
Sunpin Portable blu ray DVD Player, which is budget-friendly; UEME 9-Inch Portable DVD Player which is best for children, Sylvania 15.6-inch Portable DVD Player for excellent display, Sylvania 7-Inch Portable b;u ray DVD Player for great design. These are some of the Blu-ray DVD players portable you can look at.
You can compress about 135 minutes of HD video + 2 hours SD quality on a 25-GB Blu-ray disc and about 3 hours of HD video + 9 hours of SD on a 50 GB Blu-ray disc.
Final Thoughts
Even though times are rapidly changing and audiences are inclining more and more towards online streaming, the appeal of portable Blu-Ray players continues to stay at large. Their singular sound and picture quality, make them indispensable and an absolute delight to watch your favorite videos. However, it is only one of the best and most reliable Blu-ray players that will do the job. So whether you are looking for excellent audio and visual quality, in built Wi-Fi or Alexa compatibility, we have the entire list here that is sure to fit your bill.
