DVDFab Movie Server – The Best Media Player for TV
Summary: If you need a media player for TV, you should have a look at this post. Here we recommend you the best media player for TV that comes with powerful features for you to manage and play your movies.
There are two types of movie lovers – those who enjoy seeing the latest films in theaters and those who prefer to watch them at home. For the longest time, cinemas offered a much better viewing experience than TVs or computers so it was always worth going so it was very easy to decide between the two options. But recently things have started to change. Thanks to the modern technology we now have at our disposal, it’s possible to set up home theaters systems that are just as good as those found at the cinema, if not better in some cases. In order to set up such a system, you’re going to need a few pieces of equipment, including a good media player for TV.
Let’s just assume you already have an impressive collection of movies, a large smart TV, and a quality audio system. All you need now to complete your home theater setup is a digital media player for TV. There are a few great choices available out there but if you’re looking for the best media player for TV there’s really only one real choice and that’s DVDFab Movie Server. This product offers everything you’ll ever need from a multimedia player and even comes with some nice features that might surprise you. With that in mind, let’s take a more in-depth look at the different components of DVDFab Movie Server that, when combined, make it the best currently available media player for TV.
Hardware and Specs
First, let’s take a look at what makes this product tick. DVDFab Movie Server is powered by an ARM Cortex-A53 CPU running at 2.0 GHz, a Mali-T720, 2GB of DDR RAM @ 1866 MHz, and 16 gigs of eMMC onboard storage. Right off the bat, it’s easy to see that this machine is very powerful and more than capable of handling any type of multimedia format you throw at it. In terms of connection ports, you’re looking at one USB 2.0, one USB 3.0, one HDMI, and one Bluetooth 4.0 adapter. In short, you can connect all types of peripherals ranging from keyboards and mice to headsets and game controllers and everything in between.
Unsurprisingly, the outside of this Android 5.1 powered TV media player is just as impressive as the inside. The entire device is constructed exclusively out of high-quality military grade materials that are extremely resistant to shock and give it a nice polished look to boot. The device also comes equipped with a sleek LED display that complements its look perfectly and shows useful information about the movie that’s currently playing and the device’s connection status, among other things.
A few other hardware-related things to note about DVDFab’s media player for TV is that it incorporates a wireless network adapter that allows for lightning-fast speeds when transferring data via Wi-Fi. But if you prefer the more traditional method you can also simply attach a 3.5-inch SATA hard drive to the media player directly and enjoy the content that way. This digital media player for TV features an easy to use extraction cabinet that allows you to quickly remove the HDD and add a different one if necessary. That said, the device can support hard drives of up to 8TB so chances are you won’t have to remove it that often.
Software and UI
This media player for TV was designed specifically to work alongside DVDFab’s other products such as the Copy and Ripper modules. Files, folders and converted videos created using these modules can be watched immediately on a TV that’s connected to the player. But what if you’re not using other DVDFab products? There’s no reason to worry because the digital media player for TV can also stream ISO files via other devices connected to the network. Or you could just simply attach a hard drive that contains your movie collection as we mentioned previously.
In order to enhance your home theater experience, the media player for TValso comes with full native menu support for DVD and Blu-ray discs. As for what formats the device can support, the choices are pretty much limitless. Naturally, you have all the regular ones like AVI, MKV or TS but more importantly, there’s also support for Ultra HD, 4K, and even 3D videos. Similarly, the player can output high-fidelity lossless audio like Dolby Atmos, TrueHD, DTS-HD Master and more.
It’s clear that the video and audio quality offered by this media player are both top-notch so all you need is a good movie collection and you’re good to go. You don’t need to worry about the size of the collection because the player’s software allows you to easily sort all your movies so you can always find what you’re looking for in a matter of seconds. In addition, every movie in your digital library comes with a nice poster that contains a lot of useful information like title, synopsis, genre, release date and more.
Apart from the player itself, the DVDFab Movie Server package also includes a traditional remote alongside an app that can be used to turn your smartphone into a remote. The app known as DMS remote is available on both Android and iOS devices and can be used not only to control the playback but also to browse your library and select movies.
There are plenty of reasons why DVDFab Movie Server can be considered the best media player for TV. Everything from the software and hardware to the device’s impressive format support and playback capabilities just screams high quality. Even little touches like the remote app, easily accessible hard drive cabinet and the Poster Wall feature were all designed with the user in mind. If you’re looking for a full featured media player for TV look no further because this is it.
