Top 6 Best WMA Players for Mac
Summary: QuickTime cannot be used to play WMA files, so a professional WMA player for Mac is necessary if you want to enjoy WMA files on your Mac freely. Here are top 6 Mac WMA players you may be interested in.
- • Play DVDs, Blu-rays, and 4K Blu-rays with Menus and HDR10 effect
- • Avalibale to Discs, ISO Files, Folders and 3D videos with Hi-Res audio output support
- • Import DVD & Blu-ray Discs to local media library as ISO files with just one click
WMA stands for Windows Media Audio, which means it is a format native to the Windows operating system. And as anyone can expect, there is no support on QuickTime Player on Mac to play these files. WMA files are of high compression and quality and hence it is quite common to get audio files in this format. While QuickTime natively doesn’t support WMA files, there are plugins for QuickTime which can help you play WMA files otherwise you can use a WMA player for Mac to play these audio files. Below we will introduce you to the top 6 WMA players for Mac that can play WMA files.
DVDFab Player 5 for Mac
DVDFab Player 5 for Mac has been designed to make sure that it can take the place of your default WMA player for Mac in addition to any other audio or video format you throw at it. With an extremely easy to use interface, all you need to do is drag and drop files onto its interface to start playing music or click the plus button to locate a file. You can also open the playlist and add multiple songs at one go to play in a queue.
If you have a nice acoustic system at home, you can use this professional grade application to enjoy lossless high-quality music on full blast. It can play high-res audios such as Dolby Atmos, Dolby TrueHD, DTS-HD Master and DTS:X etc at 2.0, 5.1 or 7.1 channel output support. This WMA player for Mac supports audio passthrough and has a Dolby Digital (AC3), TrueHD/DTS-HD and DTS capable receiver. It offers high stability and smoothness on a Mac computer. DVDFab Player 5 for Mac is free to download and use as your default WMA player on Mac.
In addition to supporting all major audio formats, DVDFab Player 5 for Mac supports all major video formats too starting from the lowest quality videos and ending at the highest video quality possible with the current technology - 4k Ultra HD videos. It supports a lot more functionalities like having the capability to play DVDs, Blu-rays, Ultra HD Blu-rays, ability to convert 2D content to 3D and much more! It is a complete multimedia solution that you might be looking for.
VLC Media Player
We are not going to get tired mentioning VLC Media Player in all our articles about best media players. After all, this is the go-to solution when any of the codecs is not playing in any other media player. VLC is a completely free and open source media application that is no doubt a great WMA player for Mac, Windows and Linux. Along with a big library of codecs that it holds, it comes with inbuilt video converter, video editor, online streaming channels and video downloader. You can take the volume of this player higher than 100%, sometimes even damaging the speakers. However, it lacks the stability and compatibility that DVDFab Player 5 offers.
MPlayerX
This is a free WMA player for Mac which uses FFmpeg and MPlayer, making it capable of playing any format without the need of adding any extra codec. It comes with super smooth playback controls and can easily detect and convert the encoding method of any subtitle file. If you WMA files are named in sequential order, you don’t even need to make a playlist as it will play them in the same order. If you have a home theatre, you just need to plugin the SPDIF cable and it will automatically output raw DTS/AC3 stream.
Flip4Mac
This is a software that has been specifically designed for Mac users to help them play WMA files. Once it has been installed, the QuickTime player on your Mac can play WMA files and you don’t need any extra WMA player for Mac. With this installed on your Mac, you can play both WMV video files and WMA audio files on your Mac.
Mac Media Player
This is available both as a free and paid WMA player for Mac. For playing just WMA files, you can keep using the free version. It has a DTS5.1 audio system, runs fast and is of less than 50 MB in size. You can play the WMA file directly from your local hard drive or from a disc. It also supports a wide variety of video file formats along with support for both built-in and external subtitles of all major types.
Movavi Media Player
This is again a paid software with a free version available that can be your WMA player for Mac. It comes with support for over 50 video and audio formats. In addition to WMA, it supports MP3, AAC, OGG, FLAC, WAV and M4A format. It provides the best quality that your audio file can offer without any loss of quality. You can add multiple audio files and put them on shuffle/repeat.
So this completes our list of the best WMA players for Mac that you can use for free to play WMA files on your Mac. Some of the applications listed above do come with their premium versions, but you can make use of their free versions to play any audio file including WMA without any limitation.
If you want to play audio files like MP3, WMA and more on your iPhone, you can have a look at these top MP3 players for iPhone.
