How to Adjust Clips on Tiktok and Get Tiktok Video Quality Settings
Summary: How do you upload a high-resolution video to TikTok? What causes the videos on TikTok to get blurry? Or what should I do to improve the video quality on TikTok? Scroll down to find out more.
- • Upscale low-res videos into 720p/1080p/4k content
- • Enhance video clarity to a more realistic and vivid visual effect
- • Support video editing to meet your personalized demands
- • Get 50x faster speed with GPU acceleration
Introduction
Video quality is concern whether you're watching videos or uploading them to TikTok. Imagine putting in a lot of time to capture and edit movies, only to have the quality of the video decline on your TikTok profile, and it's all for naught.
So, how do you upload a high-resolution video to TikTok? What causes the videos on TikTok to get blurry? Or what should I do to improve the video quality on TikTok? Scroll down to find out more.
How to Adjust Clips on TikTok?
Using the "Adjust Clips" Feature, you can cut or rearrange specific segments of your TikTok video even if you recorded it using the built-in camera on your device. To get started, simply follow these simple instructions:
The clips on TikTok can also be downloaded easily if you have a video downloader. The TikTok video quality can be set as 720p or 1080p. But many users are curious about 4K tiktok video quality setting solution, therefore, the following content will talk about this.
Can I Get 4K Videos on TikTok?
Even if you shoot in 4K, TikTok will downscale your video to 1080p because that is the greatest resolution it can accept for uploads. You'll obtain a better 1080p than the native 1080p by first downsizing the 4K video to 1080p.
First and foremost, if you find TikTok video fuzzy when watching videos, you can also make some TikTok video quality settings to solve the low quality. Identifying the origin of such an issue will help you address it fast. In pursuit of quicker upload rates, shorter loading times, or data conservation, your TikTok may be put in "Data Saver" mode. This might be the primary reason for the bad video quality on TikTok. To repair it, you may switch off the Data Saver using the following steps:
The video quality settings for TikTok are done. However, this method is applicable for 1080P videos. If you want to get 4K videos on TikTok, you need an assistant because the max video quality set on TikTok is 1080P.
How to enhance TikTok video quality to 4K setting
Launch Video Enhancer AI
The first step involves launching the tool and adding the video file you want to enhance.
Make customizations as needed
You can now make adjustments like denoise, enlarge, sharpen, and adjust other parameters before starting the video enhancement.
Complete the conversion
Upon completion of the video conversion, you can view the final results of video enhancement.
DVDFab Video Converter is a powerful and feature-rich TikTok mp4 video converter that can read practically all video formats. A wide range of formats and devices can play videos from this software.
When you open the DVDFab tik tok mp4 converter, select the option to enable the video converter in the Converter section. Click the AVI icon in the left-hand column to get to your profile. In addition, you'll see a library of user profiles. Under the device, you may find a large list of supported mobile devices. If you'd like to peruse the options at your speed, you can do so.
To incorporate photographs into a film, you may create a slideshow. It's possible to add music or narration to your photographs on TikTok.
Here's how to create a simple slideshow:
- To add new material, tap +.
- Click Upload.
- Tap the image.
- It will allow you to select as many as you like by touching on the photographs. Tap the Next Button.
- In addition to the slideshow's music, you can change any additional parameters. To continue, use the Next button.
- When you're finished, press Post to publish your post.
You can do it like this.
- To add new material, simply tap +.
- Secondly, use the templates.
- Look through the thumbnails and see which ones catch your eye. Take a look at your images by using the Select button.
- When you've selected the photographs, you wish to use, simply tap on them. To continue, press the OK button.
- You may even change the background music or the narration if you'd like. Tap the Next Button.
- Press "Post" when you're finished publishing your post.
Using an image as an artificial background, such as a green screen, is also possible to transfer yourself to another location or create an interesting impact in your films. You can do it like this.
- Secondly, the effects of tapping.
- Tap the Green Screen tab and the Green Screen button to activate the feature. This region has a lot of buttons that appear the same.
- Select the photo you want from the list of photographs above the effects by tapping on it. 2. As an alternative, you may click the Plus button to see further photographs.
- Follow the on-screen controls to position your video where you want it and record it. Tap the checkbox to confirm your completion.
- Adjust any additional parameters that you desire. Tap the Next Button.
- Post your message by filling out the remaining fields and clicking "Post."
Go to TikTok and click on the + sign symbol at the bottom of the screen. Click the Upload button in the bottom right corner of the recording screen after you've arrived there.
To upload photographs and videos from your phone's gallery, you must first click on the "Upload" button. Then choose Select in the lower-left corner of each video you wish to add to your gallery.
The users can also repeat this process for any other movies or photographs you want to use. Once you've done that, click Next in the lower right corner of the screen to continue editing the video's duration, adding text, and applying filter effects.
Uploading high-quality videos on TikTok is not easy, especially for naïve users, as the platform supports limited features. But the above guideline will help you from start to end. Besides this, we have also mentioned some of the top software to help you in this regard. Moreover, our Fab products DVDFab Video Converter and DVDFab Video Enhancer AI are most competent in their performance to work for TikTok video quality settings.
