10 Best AI Video Upscaling Softwares to Enhance Video Quality
Summary: Looking for a suitable AI video upscaling software to upgrade your low-resolution or old videos? Explore our top recommendations for both free and paid AI upscalers to enhance your video quality effectively.
- • Upscale to 4K/8K with intricate detail preservation
- • Convert SDR videos to HDR10 or Dolby Vision
- • Noise reduction, deinterlacing, and frame interpolation
- • Upmix audio to EAC3 5.1/DTS 7.1 for surround sound
- • Support for 1,000+ formats, lossless compression, and effortless editing
What Can AI Upscaling Video Software Do?
Thinking about reviving old VHS tapes or low-resolution videos for your modern devices? With the latest AI video upscaling software, you can restore detail and vibrancy to your old or blurred videos effortlessly.
An AI video Upscaling Software is essential because it:
- Enhances Video Quality: It improves resolution and clarity, making low-resolution or old videos look sharper and more detailed.
- Restores Detail: AI algorithms recover and enhance intricate details that may be lost in lower-quality footage.
- Boosts Visual Appeal: It refines colors and reduces blurriness, giving videos a more vibrant and polished appearance on higher-resolution devices.
- Adapts to Various Formats: It supports multiple video formats and resolutions, making it versatile for different types of content.
- Saves Time: It automates the upscaling process, saving you time compared to manual editing and enhancement techniques.
Top 10 AI Video Upscaling Software
Check out our recommended AI video upscaling software to elevate the quality of your low-resolution and old videos, making them more appealing to your audience.
#1 Unifab All-in-One
Unifab AI Video Enhancer is a leading software for upscaling videos with ease. It uses advanced deep learning algorithms to train its AI for recognizing, analyzing, and enhancing video content. The software employs neural networks to predict and refine details, boosting clarity and sharpness while maintaining intricate features. With its universal and new animation models, UniFab delivers exceptional results across all video types on both Mac and Windows.
How to use UniFab to upscale video? Follow the steps below:
Launch UniFab and choose the module you want.
Install UniFab on your device and open the interface
Customize the restoring video file
Customize the AI video upscaling choice, including the enhanced resolution, frame rate, codecs, etc. After that, you can click 'Start'.
- Comprehensive Tools: Provides video and audio enhancement, editing, converting, and compressing features.
- Versatile Enhancements: Boosts quality for all types of video, including black-and-white films, animations, low-res graphics, portrait videos, etc.
- GPU Acceleration: Speeds up editing by up to 50 times with advanced GPU and neural network tech.
- User-Friendly: Intuitive interface with customizable options for ease of use.
- Batch Processing: Handles multiple videos at once to save time.
- Currently not supported on Linux.
💡Related reviews: UniFab review
Pricing Plan:
- Paid to get the lifetime plan, however, you can also enjoy the 30-day free trial for 3 videos. For the free AI upscaler trial, all the function is open to use without limits.
#2 Neural.love
Neural.love is an ai upscaling video online free option designed to upscale your low-resolution videos to 4k. It uses a trained algorithm to enhance video quality. This AI upscaler allows a selection of AI filters for upscaling and restoration to a desired rate. It also helps improve images and audio to provide you with a complete user experience.
- Improves quality along with the resolution of video
- Facial enhancement facility
- Creates slo-mo videos
- Acquires no space on the device
- Limited credits are available in the free plan
- Minor enhancement and improvement options
Pricing Plan:
- Free plan available with limited credit option
- $30 for 300 credits per month
#3 Aiseesoft
Aiseesoft is ai video upscaling software that boasts powerful features for enhancing and giving your pictures and videos a new life. Aiseesoft AI upscaler also enhances the videos' contrast and brightness and removes noise from them.
- It helps in rotating and flipping videos
- Allows adjustment to brightness/contrast in videos
- Allows adding watermark to videos
- Converts videos up to 4K
- It comes with a resolution limit
- Not beginner friendly
Pricing Plan:
- $25 for one month
- $49.95 for a lifetime license
- $149.85 for Business license
#4 VideoProc Converter
VideoProc Converter helps with ai upscale videos to 1080p or HD quality up to 4k, providing crystal clear quality. This AI upscaler uses your PC's GPU or CPU and offers fantastic processing speed to give instant results. It also seamlessly positions and generates 4k image samples using its pixel scaling algorithm and producing upgraded videos.
- Lightweight and provides faster speed
- Upscales video four times without loss of details
- Utilises AI models of advanced level for providing video compression with precision
- Unique features like frame interpolation, video stabilization, etc
- At times, the software needs to catch up when rendering videos
- Navigation makes it difficult to add different modes
Pricing Plan:
- Free trial version.
- $45.95 for a lifetime license of the software.
#5 AVCLabs Video Enhancer AI
AVCLabs Video Enhancer AI is an ai video upscaling software That also helps enhance video quality and its resolution to produce remarkable results. It uses a robust algorithm for analyzing and extrapolating data from the original footage and helps increase the definition and visual clarity of the video.
💡Related reviews: Pros and Cons Review: Is AVCLabs Video Enhancer Worth It?
- Beginner-friendly program with good user interface
- Provides HD videos in 4k, 8k,etc
- Good extra features like scratch removal, face, etc
- Allows various video formats
- Requires higher PC configuration
- Limited control and customization option
Pricing Plan:
- $39.95 for a monthly plan
- $119.95 for one year
- $299.90 for a lifetime license
#6 Video2X
If you are looking for a free AI upscaler, then Video2X emerges as a free and open-source option. It can also be used for frame interpolation other than video upscaling. You can turn all your lower-resolution videos to a higher resolution of up to 4K.
- Available as a free and open-source option
- Easy to use for beginners
- Uses advanced algorithms for upscaling low-resolution videos
- Great for upsizing images and gifs, too
- Available only for Windows
- Works sluggishly in upscaling more extensive videos
Pricing Plan:
- Available for free as an open-source
#7 Hitpaw Video Enhancer
Hitpaw Video Enhancer offers ai video upscaling free trial to bring a new life to your lower resolution videos. It uses algorithms that meticulously provide training for filling data gaps int, producing minute details, and eliminating noise from the videos. It offers four types of AI models and a model for general denoise features for reducing noise.
💡Related reviews: HitPaw Video Enhancer review
- Simple tas required for upscaling videos
- Allows previewing in real time for AI upscaling videos
- It uses four different AI models to enhance facial details
- Allows video upscaling in batch mode
- It does not provide manual adjustment for videos
- Not affordable for beginners
Pricing Plan:
- Free trial
- $42.99 per month
#8 Pixop
Pixop is a good ai video upscaling free trial online option That can be used for upscaling your videos to HD and 8k format. It uses machine learning to create fantastic video resolution and provides features like deinterlacing, a more profound restoration facility, AI-based denoising, etc. It includes elements related to collaboration and video storage as well.
- Allows De noising, sharpening along with frame rate changing of video
- Provides AI video upscaling in an automatic way
- Beginner-friendly user interface
- Restores old videos for remastering them in 4k quality
- Upscales videos in a sluggish way
- Supports limited formats like M2TS, MP4, MOV, and MXF
Pricing Plan:
- Pricing is levied as you use the software, and no subscription fee is charged.
#9 PikaVue by GDFLab
If you are looking for a web-based option for ai upscale videos online, then pikaVue by GDFLab can be significant. Using this software, you can revamp the quality of your TV shows or old movies and enjoy them in high definition. It also offers features like AI denoise, a boosting engine for faster processing of upscaling videos, etc.
- Available for a free trial as a free ai upscaler
- Does not have any hardware limitation due to online presence
- Increasing video resolution up to four times
- Provides denoising and detection capabilities
- Videos are accepted if they are in an H.264 or H.265 codec
- The free version offers a limited file size
Pricing Plan:
- For a 300-second video, it uses 300 coins
#10 Topaz Labs Video AI
Topaz Labs Video AI is a decent ai upscaling video option With an AI system available as a built-in. It helps make edits using every pixel in each required video frame. It helps in upscaling your video up to a resolution of 8k. You can take a free trial of the software before buying it.
- Available for Mac and Windows users
- Allows editing your video with slow motion feature
- Allows saving of output in multiple video formats
- Boost FPS up to 120
- The watermark remains on the video
- Not apt for beginners
Pricing Plan:
- Free Trial
- One-time plan at $299
What is the best software for upscaling?
The best way to upscale a video without losing quality is to use an AI video upscaling software like UniFab, HitPaw, AVCLabs, or Topaz. These tools are able to increase video sizes, quality, and resolution, without losing the original quality or context.
💡Related reviews: best video enhancement software
As a content creator or video editor, uploading high-quality videos is crucial to attract viewers. Whether it's improving color, clarity, or detail in lower-resolution or old footage, an AI upscaler is the ideal tool to transform dull videos and add the necessary details to capture attention.
Yes, AI upscaling video is effective. It generate new, high-resolution frames that align with existing ones, resulting in significantly improved video quality with fewer artifacts and enhanced sharpness.
Yes, you can upscale a 1080p video to 4K using various methods discussed in the review article about 4K upscaling software. These methods include advanced software solutions that leverage AI and deep learning to enhance video resolution and detail.
Video upscaling is worth it if you want to improve the quality of lower-resolution videos. It enhances clarity, sharpness, and detail, making videos look better on high-resolution displays. It’s especially valuable for preserving and revitalizing older or lower-quality content.
