DVDFab DVD Copy
Lossless backup or compress any DVD
Copy DVD to blank disc directly or save as ISO/Folder on HDD
Windows
Mac
Try for Free
100% Safe & Clean
Last Update: Feb 18, 2025
DVDFab DVD Copy
Best DVD Copy Software to Remove Any Old or New Protection
DVDFab DVD Copy can automatically detect and remove any copy protection without any hassle before copying DVD, such as CSS (Content Scramble System), APS (Analog Protection System), RC (Region Code), DADC, etc.
Moreover, DVDFab’s exclusive Cloud Decryption Service ensures that even newly purchased encrypted DVDs can be decrypted timely and efficiently in the cloud server. This DVD copy software has you covered to open any old or latest DVDs in 5 to 10 seconds.
dvd copy
Duplicate or Compress Any DVD in 1:1 Quality
  • Lossless Backup
  • Compress in High Quality
  • Output Multiple Formats
1:1 Copy DVD-9 to DVD-9 and DVD-5 to DVD-5
DVDFab DVD Copy is designed to create a lossless DVD-9 to DVD-9 or DVD-5 to DVD-5 backup. The quality of original video and audio streams can be cloned in a 1:1 ratio. Besides, you can play the backup copies seamlessly on any home media server or media player like PlayerFab.
dvd copy software
Compress DVD-9 to DVD-5 with high quality
This DVD copier can also compress a DVD-9 to a DVD-5 for the sake of storage capacity, while enabling seamless playback for compressed DVD-5 disc on any standalone home player. You won't have to worry about the issue of playback compatibility.
copy dvd
Copy DVD to Blank Disc or as ISO/Folder for Playback
DVDFab DVD Copy enables you to copy any DVD to a blank DVD disc for later use. If you don't have a blank disc at hand, you are also free to copy and save DVD as ISO image file or VIDEO_TS folder saved on HDD.
Note: DVDFab supports 2 burning engines when copying DVD to DVD, including ImgBurn and DVDFab Burning Engine.
dvd copier
Copy DVD with 6 Copy Modes to Meet Diverse Needs
  • Full Disc
    Full Disc
    Copy all the DVD content with or without compression.
  • Main Movie
    Main Movie
    Copy the main movie title of DVD with or without compression.
  • Clone/Burn
    Clone/Burn
    Clone DVD in a 1:1 ratio with no quality loss.
  • Merge
    Merge
    Merge multiple DVD content into one DVD.
  • Split
    Split
    Split one DVD-9 into two DVD-5.
  • Customize
    Customize
    Copy any titles/chapters you desire from the DVD.
To suit your different DVD copying needs, DVDFab DVD Copy offers 6 different copy modes, including Full Disc, Main Movie, Clone/Burn, Merge, Split, and Customize. Each copy mode performs its own functions to facilitate perfect backups of your DVD collections.
More Features in the Smart DVD Copier
  • Copy DVD at Fast Speed
  • Generate Friendly Metadata
  • Remove Cinavia Watermark
Copy Any DVD in Batch at Lightning-fast Speed
DVDFab DVD Copy software allows copying multiple DVDs simultaneously, be they DVD discs or ISO files. You can add all the DVDs you want to back up to the task queue, letting DVDFab complete the task on its own.
Meanwhile, this DVD cloner delivers high-speed burning performance. Writing speed to disc depends on your optical drive, but copying to an ISO file or folder takes only 3-5 minutes.
burn dvd copies
Make Friendly Meta Info & .nfo File Generation Possible
When you open the DVD source, the Meta Info feature exclusive to DVDFab will give it its full play. All the meta info from the source will be synchronized automatically with the server. You can check the movie title, cast, and cover.
Meanwhile, the .nfo file will be generated by default so that the meta info of the source will be fully displayed on media managers like PlayerFab and Kodi.
free dvd copier
Remove Cinavia and Copy DVD as Clean Audio
When copying DVDs that contain Cinavia Watermark, DVDFab DVD Copy works with DVDFab DVD Cinavia Removal to remove Cinavia protection completely and permanently.
In this way, the clean audio featured by AC3 5.1 will be generated instantly. Thus, the frustrating moment when Cinavia Error Message Code 3 pops up is gone forever.
copy dvds to dvds free
Functional Comparison of DVDFab Products
DVDFab DVD Copy
DVDFab DVD Ripper
$42.50
Buy Now
$59.49
Buy Now
Supported Discs
Newest Commercial, Rental or Recorded DVDNewest Commercial, Rental or Recorded DVD
Output Format
DVD/ISO Image File/FolderOver 1000 video and audio formats including MP4, MKV, MP3, etc.
Support Adult DVDs
Remove Newest DVD Protections
Lossless Backup to DVD9
Compress to DVD5
Supported Copy Modes
Full Disc
Main Movie
Customize
Clone/Burn
Split
Merge
Burn ISO image file to DVD
Output Video Resolution
LosslessLossless
Upscale to 1080P
Hardware GPU Acceleration
How to Copy DVD via DVDFab DVD Copy
  • Launch DVDFab and load the DVD source.
    Open DVDFab 13 and choose the Copy option. Insert your DVD into the optical drive, or navigate to it through the Add button. If the source is an ISO or a folder, you can simply drag and drop the file onto the main page.
    Select a Copy mode and customize the output DVD.
    Start to copy DVDs free and fast.
80+ Million People Like Our DVD Copy Software
System Requirements
  • Windows 11/10/8.1/8/7 (32/64 bit)
  • Pentium 500 MHz
  • 2GB of RAM
  • 20GB of free hard disk space
  • A DVD-R (W) or DVD + R (W) Drive
  • Live Internet connection required
Input
DVD-Video disc, DVD folder, DVD ISO image file
Output
Frequently Asked Questions
  • Is it legal to copy a DVD?
    It depends on the laws of your region. But if you want to copy or create a DVD for personal use, it doesn't matter. So, there is no need to worry about legal issues.
  • Is DVDFab DVD Copy safe to use?
  • How to duplicate a DVD with copy protection?
  • Is there a free DVD Copy software of DVDFab?
  • How to copy a DVD to hard drive?
  • How long does it take to copy a DVD with DVDFab DVD Copy?
  • What is the difference between DVD Copy software and DVD Ripper software?
Can't find the answers you’re looking for? If you have other problems, don't hesitate to contact us.
Our Service Team is always ready to help. Your problem will be addressed as soon as we can.
Tips & Tricks to Copy DVD Easily
  • How to Remove Copy Protection from DVD Easily [2025 Update]
    DianaFeb 23, 2025
    DVDs have been a popular medium for storing and sharing video content for decades. However, copy protection on DVDs can be frustrating, as it can prevent you from making backup copies or transferring them to different devices. This article will show you common types of DVD copy protection and how to easily remove them for personal use.
  • How to Copy DVD to USB Flash Drive Easily & Quickly?
    WennyNov 6, 2024
    Copying DVDs to USB drive offers a convenient way to preserve your collection or enjoy media on-the-go without carrying bulky discs. This post will show you how to to copy DVD to USB flash drive on Win & Mac PC or Without Computer in just a few clicks.
  • How to Copy DVDs to Hard Drive Free on Windows 10/11, Mac and Linux?
    DianaNov 14, 2024
    Learn how to copy DVD to hard drive on Windows and Mac with DVDFab DVD Ripper, so as to store DVDs on computer or external hard drive and get flexible playback.
