How to Play DVDs on Xbox One with Fast and Easy Method?
Summary:Can you watch DVDs on the Xbox One? And how? This article shows you how to convert DVDs to Xbox One-supported videos with DVDFab DVD Ripper and how to play DVDs on Xbox One with the dedicated Blu-ray Player.
Why Won't the Xbox One Play DVDs?
If you’re wondering, “Can the Xbox One play DVDs?” you’re not alone. The Xbox One, developed by Microsoft, is one of the most popular home video game consoles available today. Designed as the successor to the Xbox 360, the Xbox One features an optical drive capable of playing not only DVDs but also Blu-rays. The latest iterations, Xbox One S and Xbox One X, even support 4K UHD Blu-rays and high dynamic range (HDR10) video playback. So, why do many users find themselves struggling to play DVDs on their Xbox One?
There are a few common reasons that Xbox One won't play DVD. One of the most frustrating problems is when the console fails to read a disc after you insert it. You might assume that playing a DVD movie would be as simple as placing the disc in the tray, but there’s an additional step. The Xbox One requires a specific app to handle DVD playback, which can lead to confusion.
Another significant factor to consider is the region code compatibility of DVDs. If your DVD is not designed for the region your Xbox One is set to, it won’t play. In such cases, you would need to convert the DVD to a format compatible with the console.
Curious about how to effortlessly play DVDs on your Xbox One? Stay tuned as we explore effective methods to resolve these issues.
Play DVDs on Xbox One by Converting DVDs to Digital
In order to avoid various Xbox One problems, it is simple and much safe to rip and convert DVDs to Xbox One compatible video formats and play them on Xbox One directly through a USB stick or your network-attached storage.
First, when you play DVD on Xbox One, there may exist some DVD copy protections such as region code, Disney copy protection, etc. that prevent Xbox One from reading the disc. Second, Xbox One S and Xbox One X can play DVDs safely in a vertical position, while the 2013 Xbox One can only play DVDs horizontally, so you are at risk of damaging your DVD if you get a disc stuck in Xbox One directly.
DVDFab DVD Ripper - The Best DVDs to Xbox One Converter
Then, the best solution to fix Xbox One not reading is to convert DVDs to Xbox One-compatible digital formats, so that you can play DVD videos on Xbox One successfully.
- It is able to automatically remove any dvd copy protection to make DVD to Xbox One possible.
- It supports DVD to MPEG 4, AVI, FLV, M2TS, MKV, MP4, TS, WebM, WMV and other popular digital formats.
- There are also built-in editors available, such as "Advanced Settings" and "Video Edit."
- It can automatically synchronize all the meta-information of DVD, making it easier to manage your converted DVD video on Xbox One.
- With advanced hardware acceleration technology, this DVD to Xbox One digital converter can output high-quality videos at a lightning-fast speed
How to Use this DVD to Xbox One Digital Converter?
Now, let's see how to watch DVDs on Xbox One by converting DVDs to digital formats like MP4.
Step 1: Download and Install DVDFab DVD Ripper on the Computer
This free DVD Audio Ripper is available on both Windows and macOS. After installing and launching this software, you can either insert the DVD disc into the optical drive or navigate to it using the Add button if it is already inserted.
Step 2: Click 'Choose Other Profile'
There are two ways to convert DVD to MP4 and other Xbox One digital formats. First, click 'Choose Other Profile' > 'Format' > 'Video' and select 'MP4'. Alternatively, click 'Choose Other Profile' > 'Device' > 'Microsoft' and choose your preferred output device - Xbox One.
Step 3: Customize Your DVD Video
The main movie title has been selected by default, but now you can click the “Choose Other Titles” to select the titles you want. You can also change the title name and select the audio tracks and subtitles you like.
There is also an “Advanced Settings Panel” for you to tweak your settings like codec, frame rate, resolution, etc., and a 'Video Edit' tool to trim, crop videos, add watermark and subtitles, adjust picture values, and more.
Step 4: Set the Output Destination and Start to Convert DVD
Move to the bottom of the main interface and click the “folder” icon to select a directory to save the output video. And then you can click the “Start” button to start the process of ripping the DVD to Xbox One.
The conversion will take a few minutes. When the conversion is complete, you can play the video on Xbox One by using a USB stick or through your network-attached storage.
Play DVDs on Xbox One with the Dedicated Blu-ray Player
The playback of DVDs or Blu-rays on Xbox One is not as intuitive as you think, and there are some extra steps involved. Microsoft doesn’t bundle a DVD/Blu-ray player with Xbox One, so you need to download and install the dedicated DVD/Blu-ray player first.
Steps on how to watch DVD on Xbox One
- Turn on your Xbox One, and hit the Xbox button on your controller to open the guide.
- Choose Home, and then go to the Microsoft Store.
- Type “Blu-ray Player” into the input field and search it.
- Select the “Blu-ray Player” to open the store page.
- Click the “Install” button to download and install the Blu-ray Player to your Xbox One.
- Hit the Xbox button to return to the main dashboard.
- Insert your DVD disc, and then you can click the “Play disc” title to play the DVD movie.
You can also install the Blu-ray player by inserting disc into the optical drive. The steps are as follows:
- Insert a DVD disc into the disc tray of your Xbox One console.
- The Blu-ray player app will show up on the screen.
- Select it to open the app page and hit “Install” to download it to your Xbox One.
- Go back to the dashboard, and click the “Play disc” option to play the DVD movie.
Therefore, no matter whether you choose to convert DVDs to Xbox One digital formats or install the dedicated Blu-ray Player, you can easily fix any playback problems and play DVDs on your Xbox One. With the help of DVDFab DVD Ripper, it is easy to convert DVDs to digital in any format you want and play them on any device you like, such as the Wii, Xbox One, and other devices.
