Enhanced Viewing Experience: Best Blu Ray Player Apps
Summary: We have reviewed the best blu ray player apps and Software for Pc and Mac that allows you to play DVDs and Blu for an enhanced viewing experience. However, not all players work the same, speaking of performance and quality. However, there are some free and paid players that work beyond expectations. It is better to compare available options before making a purchase.
- • Play DVDs, Blu-rays, and 4K Blu-rays with Menus and HDR10 effect
- • Avalibale to Discs, ISO Files, Folders and 3D videos with Hi-Res audio output support
- • Import DVD & Blu-ray Discs to local media library as ISO files with just one click
If you are looking for the “best blu ray player”, you probably have already discovered that Windows does not play DVD unless it is equipped with a Blu-ray drive. As an uncommon fact, the basic resolution for DVD format can be increased from 480p to 520p. On the other hand, blu ray players provide high-definition, 1080p picture quality, which results in a clean and crisp video display
What is a Blu Ray Player Software?
The Blu-ray refers to the blue laser that is used to read DVD discs. Unlike normal DVDs that use red laser technology, Blu-Ray uses a blue laser, which operates on shorter 405nm wavelengths, allowing it to read information more closely and accurately than other types of laser. It offers better storage and HD image and video quality in comparison to DVDs.
Blu-ray Player Software allows compatibility with different operating systems that do not offer Blu Ray playback otherwise. While looking out for the best blu ray DVD player there are a few factors that must not be overlooked for an enhanced viewing experience on the whole. For instance;
- DVD upscaling
- Regional support
- System requirements
- Format support
We have created a complete guide with our top picks for the best 4k blu ray player 2022, based on performance, functionality, and ease of use.
Best Blu Ray Player 2022
If you are looking for the best buy blu ray DVD player apps or software, here are some recommendations. Some of these players offer free access, while others require a paid plan to play your Blu Ray DVDs in HD.
1. PlayerFab Ultra HD Player
Best For: UHD and 4k Blu-ray Discs, folders, and ISO Files on Windows and Mac.
Price: Free version and pro version available at $79.99 annual subscription. PlayerFab Ultra HD Player offers lifetime access at $99.99. If you are looking for the best buy blu ray DVD player, PlayerFab All-In-One comes at $169.99 with a lifetime for online streaming from all famous platforms like Amazon, Hulu, Netflix, and more.
PlayerFab Ultra HD Player is the best blu ray player under $100 for a 4K Ultra HD playback with a menu, HDR10 support, and EAC3 5.1 audio quality. Unlike other blu ray players, this is a platform for local and online streaming that bring together all popular streaming sites in one place.
Pros
- Compatible with Windows and Mac.
- Support 1000+ formats.
- It is a free media player that is both powerful and all-encompassing.
- Support all common formats like H.264, H.265/HEVC, MKV, MOV, MP4, and M2TS.
- Easy-to-use interface.
- Offer full control in users’ hands.
Cons
- Bit expensive for novices.
Watch Blu Ray With PlayerFab Ultra HD Player
Your search for the “best blu ray player 2022” ends with PlayerFab as it offers the most efficient media player features. Not to compromise on the quality and ease of use, it allows you a wide range of features from creating your own library to playing variable formats and hotkeys for quick navigation.
Here are a few simple steps you can follow to download and install DVDFab PlayerFab Ultra HD player.
Download and Install PlayerFab Best Blu Ray Player
With the above-provided link or by visiting DVDFab website, you can instantly download the setup file. Once the file is downloaded, click the “click to install” button to start installing the application.
Launch PlayerFab
After the installation process is done, it gives you the option “Start PlayerFab” to launch the software.
Installation Settings
In the top right corner, you will see a “downward arrow” sign that opens a dropdown menu. You can choose the settings to automatically launch the app when you start your system. You can either enable automatic startup or disable it as per your requirements in the “general” settings tab.
Play Local DVDs and Blu Ray DVDs
In the “Library” menu, you choose “Discs”. If you have any devices connected or DVD in the drive, it will automatically fetch the files.
In addition to playing Blu Ray DVDs, this software is power packed with numerous other benefits that you do not want to miss out on, including;
Custom Video Settings
In the settings tabs, choose “Video” settings from the menu. It gives you various options to set the final output for your videos.
Best Region Free Blu Ray Player
It's hard to find the best region free blu ray player to play all kinds of DVDs. PlayerFab allows users to change or select region settings as per their requirement in the “Blu Ray” tab.
Customized Subtitles
Moreover, unlike other alternatives, PlayerFab gives a wide range of options to customize your subtitles. Go to the “Settings” tab and click “Subtitle” from the menu. Here you can customize how your subtitles will look on screen. You can choose the desired size, position, and offset for subtitles.
Create Personalized Collections
Moreover, it allows you to create a playlist or have your own collection of movies arranged with proper tags for artists, genres, and order. Once you register a movie or your favorite TV show in the library, the PlayerFab automatically downloads the metadata and poster to organize the library.
TV Shows Library
Keeping user experience a priority, DVDFab PlayerFab offers the best solution to organize your movies and TV shows for quick and convenient playback at any time.
Play Queue Settings
The PlayereFab offers you the best user experience for quick navigation and an uninterrupted viewing experience. You can adjust the “Play Queue” as per your requirements by adding multiple tracks or videos and changing the order.
PlayerFab Ultra HD Player 7 Main Features
- Play local and online videos in Full HD 1080p video quality and EAC3 audio quality.
- Skip advertisements to save valuable time.
- Support high-resolution audio output, including Dolby Atmos and DTS:X surround sound.
- It allows you to create a custom queue for playback.
- All-round 3D playback for all types of 3D content.
- Play high-definition 4K UHD video with the HDR10 effect.
- Poster Walls are used to managing the local media library.
- Hardware Decoding on AMD, IQS, and Nvidia PC and TV Playback Modes
- The finest viewing experience is provided by a user-friendly design.
- PlayerFab Ultra HD Player is a free-to-use media player.
- Hotkeys for quick navigation.
Hence, to watch DVDs or blu rays in HD you do not have to look for the best 4k blu ray player, but a good media player that offers complete access to all essential and advanced tools without costing a hefty amount.
PlayerFab DVD player is the best blu ray player under $100 for all the essential features from playing multiple formats to creating and organizing your library. However, if you wish to get access to full features including online streaming from all the famous sites like Amazon, Netfilx, Hulu, and more, you can get PlayerFab All-in-one lifetime access.
2. Leawo Blu-ray Player
Best For: Blu-ray discs, folders, and ISO files on Windows 8 and 10.
Price: Leawo Blu-Ray Player is completely free.
Leawo Blu-ray Player is the greatest media player software for Windows operating systems. It plays all Blu-ray and DVD discs, as well as common movies and 1080 HD videos, without lag or stutter. It is capable of playing all Blu-ray discs, Blu-ray folders, and Blu-ray IOS files that are stored on your Windows computer. This Blu Ray DVD player comes free of cost without compromising on quality.
Pros
- User-friendly user interface.
- Leawo provides up to 1080 HD resolution.
- It only takes up 4 percent of the processing power of your computer.
- Compatible with touchscreen monitors and displays
Cons
- Does not support DVD upscaling
- No Blu Ray Discs live feature
3. CyberLink PowerDVD
Best For: Blu Ray DVDs, UHD DVDs on Windows
Price: Risk-free trial available. CyberLink PowerDVD offers a 100GB Cloud storage space with a 12-month license for PowerDVD 20 Ultra at $69.99, which includes backup discs for $7.14 and an Extended Download Service for $10.03.
PowerDVD, presently at version 19, is the most well-known DVD playing programme for Windows. In addition to playing DVDs and Blu-ray discs, it allows you to enhance video quality via its TrueTheater function, cast video to dozens of various devices, and "pin" YouTube videos to watch later when you're not connected to the internet.
Pros
- Works in offline mode.
- It is really simple to use.
- Allows you to share movies with your pals.
Cons
- Not compatible with Mac operating system.
- Relatively higher in price.
4. Macgo
Best For: UHD DVDs, Blu Ray DVDs on Mac and Windows
Price: Risk-free trial available. MacGo's Pro versions, such as Mac Blu-Ray Player PRO, start at $39.95 and Mac Blu-Ray Player, starts at $29.95 with a lifetime license.
Macgo is the best blu ray DVD player since it provides high-definition special graphics as well as an impressive DTS5.1 audio presentation. Using its SpyHunter malware removal tool, the Macgo Blu-ray player software gives the highest picture and graphic quality effects available. It also removes spyware, malware, and other undesirable applications from the computer's hard drive. It makes use of it to recover the lost iOS data and to present you with a variety of iOS recovery options.
Pros
- Outstanding Blu-ray visual quality.
- It is simple to use.
- Compatible with all multimedia formats.
- BluFast MX technology accelerates hardware accelerations on both Mac and Windows.
- Impressive DTS5.1 sound.
Cons
- It consumes a lot of resources.
- No 3D upscaling.
5. Blu-ray Master (BD-MA)
Best For: Blu-ray disc, folders, and IOS image files on Mac and Windows operating systems.
Price: There are free and paid versions of this programme available for download. Pro edition cost $3.75 for full features and advanced settings.
Blu-ray discs, Blu-ray folders, and IOS image files can all be played with no restrictions, and users can watch videos without any restrictions. You can conveniently use it on both Mac and Windows operating systems. The Blu-ray Master allows its users to view and playback Blu-ray discs, Blu-ray folders, and IOS image files. You can also play DVD folders and DVD discs with video resolutions of up to 1080 HD.
Pros
- Movie theater-like experience at home.
- Compatible with all formats.
- Play subtitles.
Cons
- Quite expensive as per the features.
We have reviewed the best blu ray players for your convenience. Amongst a wide range of options, these players are the best choice for everyone from beginners to pro users. They are highly efficient when it comes to performance, functionality, and ease of use. Moreover, choosing the best player depends on personal preferences as well. For instance, how much and where you will be using it. If you want to fined more free blu ray player windows 10, then read this article.
Most of the existing Blu ray players do not play 4K Blu-ray discs. Therefore, in order to play 4K Blu-ray discs, you need to get an update 4k player. Moreover, the best blu ray DVD player apps offer region free playback with universally applicable region codes.
It is possible to store a 4K Ultra HD Blu-ray disc with Ultra HD quality since it has a significantly larger capacity than a conventional Blu-ray disc. Normal Blu-ray discs look fantastic, but their maximum resolution is just 1920 x 1080 at the highest quality setting. Whereas, a 4K Ultra HD Blu-ray disc has a resolution of 3840 x 2160 pixels, which is the highest possible resolution. That's a fourfold increase in the number of pixels.
If you are not sure your system can play Blu Ray DVDs, you can check it in the device settings. Open the “Device Manager” by pressing the “Windows key”. Go to DVD/CD ROM drives in the Device Manager window and click the “+” sign next to the devices in question to see the description of your system is capable of playing blu ray.
